Out of balance, drum feels very loose and easy to move/tip around, machine gets out of balance very often
  • 32 Answers
Spindle cap is loose
Posted on Aug 01, 2009
WASHER SPINS LIKE ITS OUT OF BALANCE ALL THE TIME
Rex, probable broken balancing springs. Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
GE Washer Top Loader Out of Balance Shaking Repair Tutorial
http://forum.appliancepartspros.com/washer-repair/6812-spin-cycle-badly-out-balance.html
How to Fix Shaking Washing Machine
How To Fix And Stabilize An Unbalanced Washing Machine
Mar 09, 2016 | Washing Machines
The drum on my servis easy logic has become very stiff and the machine makes a lot of noise. What do I do?
Sounds like the drum bearings have gone. If you open the door and put you hand inside the top of the drum and push up, does it move up and down and feel loose. If so it needs new bearings. Unless you feel confident enough to repair it yourself you will need an engineer.
Feb 19, 2015 | Washing Machines
Out of balance washing machine
Hi, your question does not give me any hints so I will try to give you some general tips. If you wash things that can not spread out evenly inside the drum, like mats pillows etc. Disable the high spin and drip dry you items or squeeze out the water by hand.
If the drum swings from side to side when rotating, one of the shock-absorbers inside the machine may be worn out, broke or loose.
If you open the lid, grab the drum and move it a bit back and forth and side to side (not rotating) it should not swing easily but with a damped resistance when the absorbers are ok.
An other experience I have made is the balancing of the feet. I had a new machine that alway moved around during the high spin, even thou I have made an extra flat surface for it to stand on. I could recognize a bumping noise from the feet.
When I pressed down the left or the right front corner with my hand a little, the bumping stopped. Then I adjusted the corresponding foot down and fine tuned it until the bumping disappeared while spinning.
Since then my machine has not moved an other mm (= 1/25").
So equal down force from the feet and no play under any of them is essential to deep it from moving around.
Hope this can help you too.
Jan 24, 2015 | Washing Machines
My wash machine is make a knocking sound in the back of the tub in spin cycle. I took the back cover off and a piece of the plastic cover around tube broke off something between the tub and cover hitting...
Hi, I will try to give you some general tips. If you wash things that can not spread out evenly inside the drum, like mats pillows etc. Disable the high spin and drip dry your items or squeeze out the water by hand.
Washing machine banging noise
It could be the main shaft on the drum or misalignment. There is some flexibility, but not a lot. Check for worn belts, pulley wheels, and other attachments.
Feb 26, 2014 | AEG Washing Machines
What would the cost be to tighten drum in washer
Sounds like the concrete weight is broken. It stabilises the unit while spinning.If the drum moves inside the tub, the bearing has collapsed
May 09, 2012 | Whirlpool duet Washing Machines
Why does my hoover wmh168d bang so loudly at the start of the spin cycle it is that loud you can here it all around the house?
It could be a problem with the balance of the machine. Make sure it's level on the floor. Could also be a problem with the suspension that supports the drum. Usually there are springs at the bottom of the drum and a lump of concrete at the top to keep the machine stable. They could be loose or broken. Also, when you open the door just have a look at the drum, see if you can lift it around the entrance, if it feels easy to move up and down without moving the rest of the machine then the drum bearings could be broken / loose.You really need an engineer to take a look, unless you know someone like a friend who could look for you.
Feb 19, 2012 | Hoover Washing Machines
When the machine goes into spin cycle there is excessive vibration as if something was loose in the drum. Other wise the machine cycles fine. Is there someway to check for bolts or nuts loose on the drum....
Move the drum around by hand and listen carefully. There should be no loose bits or rattling, if there are it is possible that something has slipped in between the drums. It sounds as if the drum bearing may be failing. Grip the inner drum and move it up and down at the front while feeling for play relative to the outer drum. i.e hold outer drum and lift inner drum relative to where you are holding. There should be virtually no play.
Jan 05, 2011 | Kenmore HE2 Plus Front Load Washer
My hoover galaxy washing machine stops when clothes are not balanced properly.i have to even out the clothes then start the machine.if the clothes are balanced it finishes its cycle.if not the machine...
Hi
It is normal for the drum to sway excessively and hit the balance switch if the load is not evenly distributed around the drum or if you have excess cloths.
Once the balance switch is trigerred, you can reset by openning and closing the door. It is a safety mechanism which stops the spin cycle if the drum sways excessively.
If this tends to happen often, then you need to make sure the machine is properly balanced and not leaning too much to the back.
Also the drum suspension rods do tend to wear out over time and loose their firmness, causing the drum to sway excessively. You can check this by opening the lid. Pushing down and from side to side onto the agitator, and seeing if their is a firm bound on the drum. Also making sure the drum returns to centre position. If the suspension springs feel loose and wayward, then they will need replacement.
Regards
Ash
Nov 08, 2009 | Washing Machines
I keep replacing the dryer belt, due to it keeps getting stretched out, how can i prevent it stretching?
There are only two things that I can think of, both related. 1. The drum is turning with difficulty. 2. The drum is dropped down in the cabinet letting the belt be loose. Open the dryer door and feel around the opening just inside the opening. Feel for the felt seal. Is the gap even top and bottom? My guess it's not. If not, he top part which is the support for the front of the drum is worn out, letting the drum tip down and loosen the belt. Check the rear bearing. With the belt loose, pull up on the back end of the drum. Does it move up and down in the bearing. If it does the rear bearing needs replaced. Both are simple to do.
Jun 06, 2009 | Maytag ADE7005AYW Dryer
Washing Machines Logo
124 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
