Dvd, video player and xbox play in black and white while tv plays in colour
    Scholar:
  • 113 Answers
I had this issue awhile back. Make sure your connections are in the correct AV slots. I had this problem with an xbox with a monster cable that had five different cables to hook up into the back of the tv. It took some trial and error, but was able to figure it out. Just simply move them around and I think you will find there is a correct combination. Hope this helps.
Posted on Aug 01, 2009
Magnovox dv220 mw9 plays in black and white only
Hello
The output signal's colour system to this player is NTSC. Just look whether your TV is NTSC system compactable. Check whether the disc is recorded in any other colour system, like PAL or SECAM. These are the reasons for absence of colour to the picture. Check whether the colour control of the TV is at minimum.
Nov 28, 2011 | Televison & Video
When I play a DVD, it is in black and White. When I play the tv it is in colour. Can't get the DVD to play in colour!
You have one of several possible problems, ranging from best case scenario to worst case scenario:
A DVD video that is supposed to be black and white - try a different disc.
Some setting on the DVD player is set to monotone - check manufacturer's instructions
A bad set of cables connecting the dvd player to the tv - test a known good set of cables
A bad output on the DVD player - test DVD player with a different TV.
A bad input on the TV - try another input if possible, test TV with a known working video input.
Sep 17, 2011 | Computers & Internet
My lg video is only playing black and white films, the tv is still playing colour. It used to play colour videos at one time
try changing the colour options in the menu.
they are PAL,SECAM and others.try all of them till you find the one that matches your videos
Feb 14, 2011 | LG V271 DVD Player/VCR
DVD ONLY PLAYS IN BLACK AND WHITE
figure out if yout tv and your dvd is using the same color system, check also if you installed your rca connector on proper video output of your dvd dont interchane yuv to video out connectors ,check also your dvd's video out setting ,like interlace, pc,yuv, rgb, if you are using video in on your tv you should select s-video or interlace if you are using yuv on your tv you should select yuv on your dvd
Oct 14, 2009 | Panasonic DMRES30V DVD Recorder/VCR Combo
VHS plays in colour and DVD plays in black and white.
there is a circuit in the color section to put the tv to black and white if the color subcarrier is missing from the broadcast signal.
it is called a color killer and needs to be adjusted.
it is for a technician to do.
it operates off the 3.58mhz color subcarrier.
Aug 18, 2009 | Jwin Electronics JD-VD138 DVD Player
DVD player only plays DVD in black and white - what's wrong?
Ok,
I'm not sure what you mean by digibox. Under what conditions are you able to see things in color? Is a digibox a seperate device you can get to work with the same connection as your player? If one device displays color on the same connection and another doesn't then that seems to rule out the television being the problem. Can you clarify a little more?
Jan 11, 2009 | Sony DVP-NS330 DVD Player
No Colour on my TV
maybe there is a problem with you tv
Dec 07, 2008 | Panasonic DVD-S54K DVD Player
FUNAI drvr-b778
Use a head cleaner to clean the heads on the vcr.
Jan 09, 2008 | Funai PY90VG DVD Player/VCR
Picture only shows in black & white when playing DVD
Same problem with an older JVC player. One end of the S-video cable was loose. Pushed in in tight and everything ok again. Cheap fix if it works for you.
Dec 21, 2007 | Televison & Video
Televison & Video Logo
95 people viewed this question
Top Televison & Video Experts
