Question about Garden
I bought a used chain saw and do not know what the fuel mixture ratio is
    Brigadier General:
  • 4,090 Answers
Generally 150 mls to a gallon
Posted on Aug 01, 2009
What is the correct fuel/oil mixture for an older Eager ****** 16 inch chain saw?
It really depends on the model number of your Eager Beav er unit. Anything within the last 6 years is 50 to 1 older models can be anywhere from 25 to 1, to 32 - 1 up to 40 - 1. t all depends on the model number.
The usual fuel mixture is 40 - 1 or 3.2 oz. per gallon.
Your chain saw would have to be pre-1995 to use a mixture greater than 40-1. If your chain saw is other than that then use a 32 - 1 ratio. 4.oz per gal.
This is a great fuel mixture calculator:
http://www.csgnetwork.com/oilfuelcalc.html
If you know your model number you can use this page to get an owners / operators manual:
http://www.mccullochpower.com/node7877.aspx
Jun 16, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I bought a reconditioned Poulan pro PP4629AVX and I can't find a manual for it. What is the oil to gas mixture? Thanks Steve
The fuel-oil mixture ratio for all Poulan two-cycle products is 40:1. You can obtain this ratio by mixing 3.2 oz. of oil with one gallon of regular gas.
Sep 25, 2010 | Poulan Pro Chain Saw 46cc 20"
What is the oil mixture for husqvarna chain model 235
50:1 fuel to oil ratio is correct for this saw. Be sure to use modern synthetic saw oil, not a petroleum product like outboard motor oil. Premix the fuel and oil in it's own can, and shake thoroughly just before filling the saw each time. With these modern fuel/oil ratios, serious engine damage can occur if not thoroughly mixed each time. Hope this helps!
Sep 05, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Do not know what mixture or how to use
40:1 mixture for the fuel:oil ratio.16:1 will cause your saw to barely run(if at all) and if it does, will fog out every mosquito for 4 blocks. You can use any reputable 2-stroke oil, though stay away from outboard engine oil. Get the good stuff that says Stihl, or Husquavarnah, or something like that. Even the Homelite stuff is ok. The oil tank takes regular bar and chain oil.
May 30, 2010 | Homelite ZR10926 16 Chain Saw
Fuel mixture for MAC 3200 CHAIN SAW
Mix the oil to gas at a ratio of 50:1.The oil bottle will tell you how much oil and gas you need to get to that mixture.
May 11, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Ive just bought a husqvarna 34 husky is this the model number 34? its serial number is 016810 but i cannot find details of it anywhere an want a manual can you tell me mixture also its my first chainsaw,...
Get Chain lube for the chain oiler. Naturally, husqvarna recommends that you use "genuine husqvarna" oil for your mixture, I recommend a quality oil, doesn't have to be husky. Husqvarna recommends a 50:1 ratio, other manufacturers, of vertually all 2 cycle power equiptment use a 40:1 ratio. This mixture is slightly richer, but will not hurt your chainsaw. May produce a bit more smoke. Not sure what a 34 husky is...neither is Husqvarna, I visited the website and even tried to download a manual. Looked at every husky model, no 34.
Jun 21, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I would like the fuel mixture for my poulan chain saw. %oil,%fuel
If you don't know the model, then go with a 35:1 or 40:1 ratio. 40:1 seems common on most smaller saws from Ryobi and Poulan is a relation to those. The 35:1 suggestion is just for a little buffer in case. Generally it is ok to run a richer oil mix. It just means you may have to change spark plugs more often, however, your combustion chambers will be better lubricated and probably last longer!
Sometimes there is a little sticker or marking on the fuel tank cap or somewhere near it that indicates advisable oil:fuel ratio... Have a close look, it may be indicated somewhere on the saw itself.
Mar 13, 2009 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
