Question about Dell UltraSharp 2407WFP 24" LCD Monitor
Hi Team, I have Dell Ultra Sharp Monitor which started to overheat. Need advice on how to fix. Thank you,
    Problem Solver:
  • 13 Answers
Nettiser is an idiot and should not be posting garbage like that. The 2407WFP is an LCD monitor, it does not have a CRT tube with '22000' volts. And he's hardly about to work on it live is he...?
Try this guy's suggestion:
http://www.fixya.com/support/t2149543-fix_overheating_goes_black_problem
Posted on Oct 10, 2010
    Brigadier General:
  • 4,090 Answers
If you are not an electronics tech It would be remiss to advise you to interfere with a high tension device like a monitor. take it to where it can be serviced and keep your life. Only experienced people should open up a monitor and poke around 22000 volts is involved here and if its overheating the wiring on th ecoilod ids breaking doen or has broken down.
Posted on Aug 01, 2009
  • ME Apr 04, 2014
    LCD monitors dont require 22000 volts, you are thinking about CRT monitors...
How do I connect dell ultra sharp 24 dual monitors to dell 9020 mini tower
At the back of the unit you will see a graphics card output. If you only have one then you will need to buy a second one to utilise a second monitor. You will need 2 DVI outputs to run this kind of setup.
Mar 05, 2015 | Dell OptiPlex 9020 Desktop Computer -...
How to add more backligth to Dell ultra Sharp 190FP 19" LCD monitor? The frontside brightness is full, still the monitor is dimm.
Hold down (Fn) key and press, press, press.... right arrow (----->) the right most key on your keyboard until back light brightens. If you press several time it also goes off. Just press again until brightens.
Have fun
Jun 16, 2014 | Dell UltraSharp 1901FP 19" Flat Panel LCD...
My Dell E771a on 32mb ATI Rage 128 Ultra monitor shows my screen as hour glass. How can I make my monitor return to default settings to correct? Is this a driver update maybe?
That is a monitor problem, the s correction in the horizontal deflection circuit has failed. Take the monitor to a tv repair shop to have it fixed.
Jul 10, 2011 | Dell VID ATI RAGE128 ULTRA 32MB LOW...
My dell ultra sharp 1702 monitor blinks for quite awhile before starting up when I turn it on...?
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Dell monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Replacement board: www.lcdrepair.us
May 19, 2010 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
Dell Ultra Sharp 2001FP LCD Monitor has a green horizontal bar on the screen.
This is because the LCD is not getting power through to that section of the grid. Sorry, it can't be fixed unless you have an electronics engineer you can take it to and given that it is electrical failure on the grid and not the actual crystals which are burnt out/damaged.
Feb 25, 2010 | Computers & Internet
My new Dell flat screen monitor is blank and posting a message - entering power save mode- ... when I restart it briefly displays the Dell logo and other normal display at normal startup then switches to...
You'll need to troubleshoot a little. SOmething may be broken, but you'll need to find out what. 1: Try the monitor on another computer, see wether it will work on that one. If it doesn't, the monitor's broken and you're probably going to need a new one. 2: If the monitor does work, put it back, but now use another cable to connect it to the PC. If that fixes it, your cable was broken. 3: If not, you could try to switch the graphics card in the PC with another one. Do not attempt that, however, unless you know what you're doing. If you don't, get someone you know to do it for you, or take it to a computer shop. If the PC will boot with another graphics card, the old one is broken. 4: If not, it may be your motherboard that's broken. Repeat step 3 with it. These steps should fix your problem. If not, please post back here. Regards, Yannick.
Jun 07, 2009 | Dell E193FP 19" Flat Panel LCD Monitor
Fflat screen not working on my computer
The refresh rate makes a difference, try changing the frequency and allot more RAM to the Graphics in the BIOS setting....sodeep
Mar 19, 2009 | Computers & Internet
Dell 19" Monitor - Dead
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. After it went blank, you have to check that you can see the image on the screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. Like mine, I can see window image using flashlight and check lamps inside. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Thank you,
Tan
Mar 15, 2008 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Problem with Digital Input
You may need to switch monitor selection in your Display Properties. You need to activate twin/dual view in your Display Properties. Right click on any clear area of your desktop, click on Properties, click on Settings tab, select monitor 1 or 2 depending which is your primary and which is your secondary (analog/digital). Check (or uncheck-whichever works) on box "Extend....". Apply, OK.
There is an application that is supposed to facilitate twin or dual view configuration, UltraMon. This may be better/safer way to address your concern.
Hope this be of help/idea. Pls post back how things turned up or should you have other concerns.
Good luck and kind regards.
Jan 25, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Ati Rage 128 Ultra Pro 32MB Crashed
My name is Todd and I'm with Dell's online outreach program.  Have you tried that system with a different monitor, or is that monitor working correctly on another system?   Just trying to confirm it's the video card and not the monitor itself.
Another step you can try is to go into the BIOS / System Setup of that GX 240 to see whether the problem is only happening as it tries to load the drivers.  I sort of doubt that it is from your description but you can test it pretty quickly by tapping the <F2> button when the Dell logo would first appear.  If the video is normal in the System Setup that would let you know if the basic video functions of the card are working correctly.
But to be honest it sounds like the video card is failing from your description.  I assume your system's service contract has expired?
If you would like more detailed help feel free to email us at Customer_Advocate@Dell.com.  Please include my first name, Todd, in the subject line of the email and reference this issue so I can pull up information to try to help you.
Thank you,
Todd
Customer Advocate
Dell, Inc.
http://direct2dell.com/one2one/archive/2006/11/19/3648.aspx
Oct 03, 2007 | Ultra ATI Rage 128 Pro Graphic Card
Dell UltraSharp 2407WFP 24" LCD Monitor Logo
366 people viewed this question
Alun Cox
