I have a zenith tv hooked up to my computer and i need a monitor driver for it so i can make the settings right now it is using default driver
  • 11,896 Answers
Go to main windows screen, right click, go to properties, then go to settings,
Drag the #2 box to the LEFT side of #1 box, hit apply, then hit OK.
I use default driver and works fine.
Otherwise go to download.com or tell me what video card you have.
Posted on Aug 01, 2009
    Problem Solver:
  • 7 Answers
Make sure Your computer is upto date with the hook up as a monitor setup from the television.If so then do an online search for the drivedr to make it work.
I have a Zenith P60W26P 60" Plasma TV that the sound went out. Any ideas? and yes, I tried the mute
Check the audio settings and make sure that you did not set it to external speakers only.
Jan 14, 2015 | Zenith monitor P60W26P User Manual
LAP TOP HOOK UP TO TV
You have to have an HDMI, DVI, HD, or RGBHV input on the back of your tv. Get the proper cable to go from your computer the tv, plug into your tv, select the right input that matches where you have plugged it in. Lastly you will have to hit function 4 on your computer to change it to remote viewing monitor.
Nov 13, 2013 | Zenith R57W46 57" Rear Projection...
How do I get the sound through my LG M197WD Flat screen monitor when using it with my PC? Sound is fine when using it as a TV!
What video cable are you using between the TV and the computer? If you are using a VGA, DVI or DVI-HDMI cable, you need to connect a 3.5 mm audio patch cord between the computer's audio out and the PC audio in on the TV. The audio out on the computer will be the speaker (green) port on the back of a desktop or the headphone jack. (Make sure that this jack works by connecting a different set of computer headphones or speakers to the computer.) The audio in jack on the TV is above the RGB input; it's just to the left of the digital audio out.
Check that the correct audio output is selected. From the Hardware and Sound Control Panel, look at Manage Audio Devices and the Playback option. If your computer has an HDMI port, that may have become the default audio output device. Change this setting. (Not all TVs can accept HDMI signals from a computer but a number of video cards are encoding this as the default during install.) Try a new audio patch cable between the TV and the computer.
If another set of speakers doesn't work, you need to check the drivers for your computer. In the Device Manager (click Start > Control Panel > Hardware and Sound > Device Manager), scroll down to the section for Sound controllers and expand it. Then check for updates for the audio driver. If necessary, uninstall the driver (by right clicking on the audio driver). Then shut down the computer and restart it.
The manual for the M197WD is available from LG here: http://www.lg.com/uk/it-products/monitors/LG-tv-monitor-M197WD.jsp . Click on the support tab and the link is on the right side of the page.
My directions are for Windows 7; it's slightly different for other versions of Windows.
I hope this helps. Please post a comment with the video connection that you are using if you need additional assistance.
Apr 22, 2012 | LG Televison & Video
I have a 47 inch phillips hdtv and a hp elite cpu the hp eliute has a blue ray player there hooked up though a hdmi cord the tv starts up windows and shows safemode but when it goes to the password screen...
tv starts up windows and shows safe-mode. That right there is your problem, windows defaults the monitor down to regular 640 mode. I will cut out the hdmi since that is not a monitor. Safe-mode is used to trouble shoot your computer and it loads just barely the drivers you need to see and work with the computer. You will have to get the computer to boot up normally then proceed from there, also you will have to set up your video card to output hdmi.
Apr 25, 2010 | Computers & Internet
I am trying to hook up a 500 mhz computer and use the tv as the monitor. the plud and play driver brings it up on screen, but I can't seem to get the whole normal picture for windows on the screen and...
right click on the background of your destop and select properties. go to the settings tab and change the screen resolution till the picture is normal size. there is a box to select to make my default monitor which will move your windows bar from the computer monitor to the tv.
Apr 07, 2010 | Mitsubishi WS-65313 65" Rear Projection...
I have a z50p3 I tried to hook a samsung 1600
Sorry, man I have the same problem, with the same tv and player. Did you ever get a solution? LG Service Tech came out and his LG bluray player worked, whereas my Samsung didn't hooked to the TV. (It would spordically work going thru my HK254 AVR.)
He said either 1) the Samsung player was defaulting to a format that the Zenith being 3 years old could not decode (eg. 1080P) or that I might need to change inputs several times to get it to sync up or 3) by an LG Bluray player.
He said the Zenith was old and that newer sets are built with circuitry to help navigate the handshake easier. He couldn't find any service bulletins on it, and the one I got from LG he said didn't exist.
Feb 28, 2010 | Zenith Z50P3 50 in. Plasma TV
Im trying to hook up the computer to my flat screen and Im preaty cofussed. I plug it the Rgb)pc plug when turn computer on the tv shows no programable..What do i do?
To display a computer on a flat panel you need to match up the resolutions. go into the computer set up and make the display 720p or 1080p depending on what your tv is (the computer will read 1080x1900 and probably not say progressive unless you are using a aftermarket program instead of window). I do however recomend NOT using a plasma as a computer monitor as they WILL burn in. Even on brand new models the only brand I have found that has truely made it hard to burn in the TV is panasonic.
Mar 24, 2009 | Zenith P50W28B 50 in. Plasma Television
Tv/digital converter box & vcr-dvd hook-up
ok cable sat wire goes into input of dvd-vcr input then coming out from the dvd vcr and into the moulator then a wire out to the tv now make sure your vcr is set to the right setting ...now you can record 1 cable..2.vcr dvd..3 modulator...4...tv make sure vcr is set to monitor
Dec 04, 2008 | Philips Magnavox DVD/VCR Dual Player
Pc connection doesnt work with computer
The TV you are hooking it to is not able to show the resolution you have the computer set to. Start by setting your computer resolution to 800 x 600. If that works than try 1024 x 768. If you go too high you will get that "out of range" message. The instruction book that came with your TV has a listing of the available resolutions the TV will show.
Aug 30, 2007 | Wanlida Group LTD-1510 15 in. TV/DVD Combo
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
