SOURCE: Overflowing drip pan under the fridge
for reallybsq
problem could be door seals not sealing completely and hence excessive ice formed on evaporator and excess water when it melts. however, i have found this problem many times with large larder fridges and really found no cure.
for guest.
towards the bottom of the back wall, there is a gulley with a drain hole in the middle. this drain is blocked. clear it with something flexible and make sure water flows away freely
SOURCE: drain pan under ge sideby side fridge
pull the front bottom grill off then pull the pan out to you to drain or cleas.
SOURCE: Whirlpool Fridge makes a loud dripping sound all the time G56SHE
Erin,
The water you hear sounds like it's coming from the automatic defroster in the freezer compartment. It runs down a drain tube into the pan you describe under the fridge. The pan is heated and evaporates the water.
Just some possible explanations if you are hearing "lots" of water"
* You may be in a warmer, more humid climate
* The temperature and humidity in your dwelling is elevated
* The door gasket on the freezer may be leaking
* The freezer is too full
* The freezer door is not closing properly
* The freezer door is being left open for extended periods
* There is a problem with the defrost cycle
If you are hearing water running all the time, check the ice maker water line and fill valve (if you have an ice maker) - there could be a leak or other malfunction.
SOURCE: water puddles front left of side by side ge profile fridge
If you clear the drain, the water will not fill up again. (try hot, but not boiling, water, forced into the drain hole with a turkey baster) When drain is clear, water will run into the drain pan located near the compressor. The fan will cause that water to evaporate.
SOURCE: Particles floating in whirlpool filtered water.
okay - we have had this same problem for around 6 weeks - We called a service repairman to come out and he said that these "floaties" are harmless bacteria. We should disconnect the filter and flush the system by using 1 gallon of water a day (wasting it) after the chlorine in the water is allowed to build up again then the "floaties"- bacteria- will go away---- gross :-( We will see if it works---
Hi Raul Carmenate, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Please add your specific MODEL number?
Hi Anthony,
Here is the info:
Model - VCSB483DSS
Serial: 111006R00002913
Also, i'm I supposed to remove the pan completely to clean it?
Thanks
--Raul
