Question about Dacor Preference SGM304 Gas Cooktop
My ignitor will not go off. The burner will light
My ignitor will not go off. The burner will light but the ignitor does not stop. This only happens on one of the burners. How do I fix it?
  • 744 Answers
Unplug the appliance for at least 1/2 hour and then plug it back in and see if the problem goes away. If not, you may have a defective ignition board or a bad connection somwhere.
Posted on Aug 01, 2009
BOILING WATER SPILLED OVER FROM POT INTO COOKTOP AND NOW IGNITOR KEEPS CLICKING
Hi, water is a great conductor of electricity. It is likely nothing to be concerned about in this case though, if you light the burners and allow the water to burn off/evaporate from the ignitors it should be fine. It happens all the time with gas ranges and cooktops. Once the ignitors are dry they will stop conducting/sparking unwanted. Hope that helps calm your concern. Thanks for coming to "fixya" for your solution. Please take a second after reading this to rate the info provided to you. Good luck. Macmarkus :)
May 02, 2010 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
Jenn-Air JDG8430 Ignitor won't stop sparking after burner ignites
Test the ignitor first, if the ignitor does not spark should be the ignitor itself.
Oct 12, 2008 | Jenn-Air 30 in. JGD8430A Gas Cooktop
Dacor sgm304s, Ignitor constantly snapping.
under burner control knob broken plastic cam that operates switch.
Sep 07, 2009 | Dacor Preference SGM304 Gas Cooktop
The ignitor sparking will not stop in after the
when you turn the knob or push a switch is going to the on posicion so that means that the switch is stuck in one of the knobs , you just have to see witch one is stuck
Jun 18, 2009 | Wolf Range 30 in. SCB30C Gas Cooktop
G.E Profile gas cook top #JGP640 ignitor.
It is sparking because the module does not sense the heat which would normally cause the sparking to stop.
It can be caused by a poor ground, make sure the ignitor at that burner is clean and free from any obstructions. If it is then it could either be a defective ignitor or spark module.
Mar 12, 2009 | GE Cooktops
Bad ignitor needs replacement
it may just need cleaning at where it sparks to the burner if it is sparking back down the electrode then it is cracked . Some igniters pull out others have a screw that holds them in.
Oct 23, 2017 | Jenn-Air JGC9430ADS Gas Cooktop
Gas ignitors continue to spark every 5 seconds in off position
try unplugging the unit over night, itspossible that by you cleaning the tops, the electrodes got wet, falsley sparkin, when the water dries out it should stop, and no not dangerous in any way, only annoying to listen to
Feb 13, 2009 | Amana AKS3040 Gas Cooktop
Clicking noise on cooktop even when all burners ignite
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
Dec 01, 2006 | Viking 37 in. VGSU161 Gas Cooktop
Dacor Preference SGM304 Gas Cooktop Logo
396 people viewed this question
Top Dacor Cooktops Experts
jdthefixer
Mike
Mike
Are you a Dacor Cooktop Expert? Answer questions, earn points and help others
