Back to:
Tags:
Flat Panel Televisions
Generic problem for all Flat Panel Televisions
Olevia remote control codes
posted by Jim3 on Nov 24, 2007
Can't find remote control code for Olevia TV to use with universal remote
I've had an Olevia 542 B11 TV since 12/06. We were informed that since it is a new company, not every product they have has been assigned a code for programing to a universal remote. That was 11 months ago and I still haven't been able to find a code on, or off, Olevia's site.
We have cable and the remote is a UR5U-MDVR that uses a 3 digit code. Have tried the '506' and '127' that were suggested for other units but, no success.
Should I resolve myself to using multiple remotes?
Thanks
Comment by Jim3, posted on Nov 25, 2007
Premtech - Thanks for the assist. I did try it for about 15 minutes, but I'm not sure if I gave it enough time. The instructions tell you to repeat the cycle of 'Power' and 'Channel' buttons, but they don't tell you how long to continue before your moving over the same territory again.
I'm not sure if I only covered 1/4 of the options or if I've hit the same areas four times!
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jul 30, 2008
FixYa! (100)
dthirdrail
Rank:Apprentice Apprentice
Rating: 100%, 1 votes
NO codes work for the Olevia Syntax models, and NO they did not update anything to down load like they promised.NONE- Period. Do not waste your time. I wasted 8 months. You may either get used to a few remotes, or you can go to a website (x10 products) and pick up their learning remote. I paid 50.00. Line up the old and new, and the x10 product will learn to operate your cable box, TV, DVR, DVD and everything else. ( Took about 30 minutes plus my teenager) Now I have one remote control for everything, plus it looks great with the digital screen and channel icons, as well as readable buttons so you do not have to be a teenager or put on your glasses to operate it.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Olevia remote control codes:
I don't want to Accept this solution
Solution #2
Helpful (85)
premtech
Rank:Guru Guru
Rating: 89%, 859 votes
Have you tried the code searching feature on the remote? I'll look through some service manuals I have, paper versions, for Olevia codes but it may take me a week or more.. Until then try the remote control search feature in the instruction panel that came with your remote and let me know..
Bill
Comment by premtech, posted on Nov 25, 2007
There are some 900 code combinations and the best way to find whether or not you've covered them is to try and keep some count - even if not accurate... I've done that in a few cases where it's taken 20 minutes before something worked.
Good Luck!
I'll still try and check for the manual..
Meanwhile try this site, it might help.
http://www.remotecodelist.com/remotes/
Rating Locked! (?) Jim3 has rated this solution as Helpful
Thank You!
Can you Help with these Flat Panel Televisions problems?
i need the wiring diagram or schematic i just need the...
element of database system????????????
Samsung LN-52A750 LCD TV
i have a new samsung tv as described above but sometimes...
Sanyo DP42746 42 in. Plasma Television
what happened to my tv sony trinitron, when i turned it on...
Hitachi 50VG825 50 in. HDTV LCD Television
she alway tok me you are mearid me but porblam is my age...
Loading problems.
Repair Service
Find Flat Panel TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
