Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
The compressor is making different noise when it comes on. Just for a couple seconds.
    Sergeant:
  • 269 Answers
I think one of the spring holding the motor inside the compressor got lose. it's time for you to replace the compressor.
Posted on Aug 01, 2009
2006 honda momentary hissing noise when compressor comes on
This is a common characteristic of Hondas. Some even whistle. Not a whole lot you can do to remedy the noise.
Apr 26, 2014 | 2006 Honda Accord
GE Monogram side by side model z1s420nmc is making a ratlling noise once in a while
Just to give you an idea about what might make that noise check my video out. A list You will see how compressor mounted and check Your own fridge from where noise might come from.
Jan 04, 2012 | GE Monogram Side by Side Refrigerator
I have H. Bay model HB40F dehumidifier. It does not seem to ever actually start the compressor. There is a plastic box on the side of the compressor that contains a couple of coily looking things. It...
It is probably the start device(the coil looking things), as long as you don't hear the compressor humming. A loud hum is a lock compressor and the cost would be far greater than a new unit.
Jun 17, 2011 | Soleus Dehumidifiers
Side/side #msd2142arw not cooling. evaporator fan fine. compressor comes on for 3 seconds and shuts off and repeats aprox. every 30 seconds. the compressor does get warm. help!
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Aug 17, 2009 | Refrigerators
Kenmore Coldspot 69182990 - knocking noise
check te rubber mounts at the bottom of the compressor
the rubber rots after some time and the compressor moves on shutting down as the knocking could be that noise
May 20, 2017 | Kenmore Refrigerators
Refrigerator makes fairly loud noises of a clunking kind but runs and stays cold.
Clunking noises usually comes from the rapid stop of the compressor. It will not hurt a thing. The rubber grommets which the compressor sit on for cushioning, have most likely hardened and are transferring the noise to the frame or casing. The compressor runs at 3600 rpm's and when you tell it to stop on a dime, it can't. The result is a couple of clunks or so. Also check the drip pan for improper positioning. I have seen them make noise also.
May 04, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
KitchenAid Side by Side
if you hear a clicking like the compressor is trying to start, like a clicking on and off this sounds like it could be your start run relay trying to kick your compressor on. if this is bad it will continue to click, and your compressor won't start. unless your mechanically inclined this might be the time to call a service tech. the start run relay switch sits on the compressor behind the fridge.
Mar 12, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Condensor sounds like it moans for a couple of seconds instead
Hello aeruslady1,
Do you mean the compressor? I'm sure you do. The condenser is the hot refrigerant line that comes off of the compressor.
It just sounds like you have an old compressor. I have seen them make noises for years before they take a dump. If it continues to run loud even after it starts however, then you may need to clean the condenser coil or replace the condenser fan motor. Another thing that might make it run loud is some refrigerant lines may be rubbing against something. This can be remedied by bending the lines.
Hopefully this helps.
Sincerely,
shays5415
Dec 03, 2008 | Refrigerators
Loud buzzing noise from inside Jenn Air 2389G fridge
i don't know jennair specifically being from england.
however, there is often a fan inside the back panel and the noise you heard was the fan hitting ice. the reason now not heard and fridge not working may be that the ice has built up so much the fan is jammed
Jun 25, 2008 | Jenn-Air JCB2388G Side by Side...
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
66 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
