Question about Whirlpool WGD5300S Dryer
Dryer works but only on medium heat. which element is bad?
    President:
  • Whirlpool Master
  • 1,922 Answers
You could either have 1/2 of the element out(check with ohmmeter) missing one leg of your 240 volts input if dryer uses 240 for operation or an input power wire ib burned off somewhere inside unit, check the "NEUTRAL" connection at the heating element center point, it carries the current im-balance and is subject to a lot of heat from element case
Posted on Nov 05, 2009
My Whirlpool duet sport dryer got hot and shut off after running 20 minutes.
Sounds like you may have a bad heating element that has grounded. You should have this looked at to make sure if you aren ot handy to open the dryer up and inspect the heating element your self. make sure the element wire has not broken and fused itself to metal inside the dryer heater housing.
Feb 02, 2017 | Whirlpool Dryers
The air blows but there is no heat. damn thing is only year and half old and samsung will not help
Unplug the dryer. Remove the control panel on the top. Look inside for a sheet of paper with the wiring diagram or service instructions. If you don't find one there, look on the back cover panel. (Every US appliance maker provides this, but I've never looked inside a Samsung dryer so I don't know about their practice.)
If you find the wiring diagram, you can use it to identify the wires going to the thermostats and heating elements. Now you can use an ohmmeter to check which part is open; the wiring colors marked on the diagram will let you find the terminals in the control panel going to the thermostats and heaters so you don't have to take everything apart for diagnosis. Note: in a typical dryer, if you get no heat on Medium, but you get heat on the Low setting, you already know the Medium heat element is burned out. High heat uses both elements.
If you don't find a wiring diagram, you will have to look for the thermostats and heater terminals. Usually there is a thermostat mounted on the door frame at or near the top of the opening to the drum. There will be a second thermostat mounted on the top of the heater pan or box. Usually these are supposed to be closed (you get continuity) when they are closed. The heaters should show some resistance, but should not be open.
If you find an open circuit from the control panel, it doesn't mean the part itself is bad; it could be a problem with the wiring terminal connecting the part. This is often obvious when you see it; the insulation at the terminal will show signs of overheating.
May 30, 2011 | Samsung Dryers
Ge profile dryer drum turns but therte is no heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 27, 2010 | GE Dryers
Dryer only heats on the highest heat setting
Some electric dryers have two heating elements. You probably have one bad heater and one good heater.
Apr 14, 2010 | GE DVLR223 Dryers
The dryer shuts off when the heat setting is on medium, medium/hot or hot but will run on low. It gives no error message when it shuts off.
it's proabably shut off due the heat element or the thermal cutoff switch. you probably have to call a proffesional
Mar 09, 2010 | Dryers
My whirlpool imperial model number LER8858eq1 has stopped heating. this first happened when the dryer was set to high, and now the dryer will not heat on medium as well. The dryer is 11 years old. Any...
FIX IT!!!!
I believe it is your theremostat, maybe the heating element,
I would use a multimeter if you have one and set it on ohms touch it to the terminals of the thermostat, and the heating element (if you don't have a multimeter walmart sells a cheap one that will work fine for what you are doing) if you do not get a reading replace, http://www.appliancepartsworldwide.com/Store_Part.aspx?Id=493992
Here is the list for all your parts
http://www.appliancepartsworldwide.com/Store_SearchResults.aspx?S=392096&ST=PBM
Sep 14, 2009 | Dryers
Whirlpool commercial gas dryer - heating problem
Check the voltage to the switch when turned to high and the power button pushed on. If you are not getting any power there then the setting switch is bad replace it at repairclinic.com
Feb 14, 2009 | Whirlpool CSP2761 Gas Commercial Dryer
Dryer Heats on High all the time
I don't think it is the heating elements. You have checked out all the important stuff. Is there power coming from the controls on medium and low. It sounds like this is the problem.
Jan 23, 2009 | Frigidaire FEQ332E Electric Dryer
KENMORE DRYERS
It could be a malfunction heating element, thermostat or both. In most of the cases it's the heating element. Check with a multi-meter for 115/220V on the heater element tags. In case you get this voltage there, you should replace the heating element. In case you can't read the 115/220V on the heater tags: - Check thermostat's for continuity (you should read a low resistance). In case you can't get any measurement. You should replace the thermostat. Good luck!
Aug 06, 2007 | Zanussi FJS1225W Front Load Washer
Frigidaire Dryer takes too long to dry.
First thing I would do is to take the drum out of the dryer and make sure the back is not all clogged up with lint. That is a very common problem with Frigdaire dryers. The back is where the dryer draws the heat from and it sounds like you have plenty of heat. The only place the heat will go is up and that may be why you are geting burn marks. I wold also clean out the front where the lit filter is that to gets blocked up. I think if you check all that ad clean it out good the dryer should work just fine.
Jan 12, 2007 | Frigidaire GLER341A Electric Dryer
Whirlpool WGD5300S Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
