Question about Panasonic Lumix DMC-TZ1 Digital Camera
Turn Camera off then On Again
I dropped my Lumix camera recently and now when I turn it on, the view is blurry. After a few seconds it says "Turn camera off then on again". I can view my stored pictures just fine. What should I do?
  • 4,102 Answers
It sound like you have damaged the focus part of the lense i am not to sure if you can replace this part as i have never come across this problem with a camera before but the problem could be either the lense focus has become damaged or it could be that a chip on the board has been damaged without taking the camera apart and looking to see if the lense and lense motors can be replaced or do come out their might even be a way of adjusting the lense once the camera is apart to get it back in focus their is nothing you can do yourself as the equipment will cost a fortune to buy. you would need to test the board and all chips and also im sure if your camera can be adjusted you will also need a special tool to do this. i do know on some of the top end cameras you can adjust the focus from inside the camera to bring it back into view but at the end of the day you need to think is it cheaper to repair or to replace also if you take it in to get repaired you might also get problem sources the spares. but at least you know the screen and memory is working fine so it could just be that it need adjusting it is not worth taking the camera apart yourself as their is an order to undo the screws so as not to warp the board also when you put it back together these need to be done in order and torqued up to the right tension else the board will get warped i suggest you take it into a good camera shop and these will tell you of a repairer in your area im sorry but their is nothing you can do yourself witch isnt much help i know but im sure you just need to get the lense auto focus adjusting this will be cheaper than replacing the whole unit at least they can take the cases off and look at it witch i cant do from here so i am advising you the best i can from where i am sorry cant help you more but im sure other experts will tell you the same answer good luck but choose a good camera shop as you are less likely to gut stung on the price of the parts.............................
Posted on Nov 25, 2007
Suddenly I keep getting the message "please turn camera off and back on again" but nothing happens when I do I just get the message again. I can turn the dial to view pictures but if the dual is turne
did you try to wait several seconds before turning the camera back on?
When it happens again, after turning off the camera please remove the battery for a few seconds and put it in again. then switch on.
If the problem persists goto the repairshop or your dealer.
Dec 23, 2012 | Panasonic Lumix DMC-FZ20 Digital Camera
Panasonic Lumix DMC-TZ3 stopped working
Hello
Thank you for using
FixYa for your problem
Your camera is faulty. It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 30, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Have Panasonic Lumix DMC-TZ5. get message turn camera off
Did you drop the camera on the lens?
You have to replace the barrel (cost around 175,00 euro)
try to find a cheap second hand camera en replace the lens unit...
Jun 17, 2009 | Panasonic Lumix DMC-LZ2 Digital Camera
Camera was dropped. Now it will turn on, but after a few seconds, lens begins to move in and out for about 3-5 seconds, then a messag is displayed: Pleaase turn camera off then on again". Doing this r
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 17, 2009 | Panasonic Lumix DMC-LZ3 Digital Camera
Lumix lens retracts and extends
Belikes, any external object is trapped in between your Lens Motor and Camera Body. You should consult Authorized Service Personnel to handle this trouble.
Jul 28, 2008 | Panasonic Lumix DMC-FX9 Digital Camera
Turn Camera Off error message
hi
I have the same error code if you can help me please let me know
thanks a bunch
Jun 29, 2008 | Panasonic Lumix DMC-FZ30 Digital Camera
Problems with my Panasonic Lumix Digital camera
let me explain to you guys, these cameras are slim line cameras and if dropped or mishandled it is going to give problems. you cant blame the camera if you are not handling it corectly.
Jan 01, 2008 | Panasonic Lumix DMC-FX7 Digital Camera
No longer staying on
hey same thing happened to me today differnt type camera but, when it does it i shake the camera or tap it on a counter top and it fixes it
Jul 27, 2007 | Panasonic Lumix DMC-LC70 Digital Camera
Panasonic Lumix DMC-TZ1 Digital Camera Logo
42 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
