BLURRY PICTURE I need to adjust the convergence board, HOW?if I need to repair the board with a repair kit does these kit work?how can I access this board,I have electronic as well as electric experience MAYDAY,MAYDAY,I need help Thanks
  • canadian64 Aug 04, 2009
    thanks,their is a repair kit for convergence board does 't really work??
  • 11,896 Answers
If you are able to do this, the switches woud be in the back of tv under the panel. Some tv's like most newer tv's are not adjustable except under main menu for color, tint, contrast and that is it.
This is when the convergance board needs to be replaced.
Posted on Aug 01, 2009
  • Nate Stansfield
    Nate Stansfield Aug 04, 2009
    The repair kit does work just fine. That is what most people are doing. Either buying a kit or replacing the board if there are a great number of faulty capacitors on the convergence board. People have seem to be having good luck with the kits and directions
The left side of screen is blurry.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 11, 2010 | Sony KP-51WS510 51" Rear Projection...
AV-48WP30 - Is this a convergence board issue?
yes u r right that is the problem of convergence in your televisions.and it needs to be replaced to make it proper.
thanks.
Oct 29, 2008 | JVC AV-48WP30 48" Rear Projection...
Color convergance from bottom of screen
PT-47WX53 - Visible Convergence Fault
You need to open the TV. Remove the deflection printed circuit board, access and replace the convergence ICs. Maybe some low ohm resistors are burnt as well. Change those too.
Make sure you do not do any damage to the connections or foil on the printed circuit board. Don't crack the board while breaking loose the ICs.
Also be careful to re-connect all the plugs and the inter-connects between the boards. Don't damage the plugs or connectors. Make sure you put them all back in the correct sockets.
After replacing everything and re-assembling, turn-on and stand back. Look for smoke. If no smoke, look at the picture and see how you have done. Use the auto-convergence if it is available auto-convergence should adjust the convergence grid to an acceptable level. Usually minor touch-up of user's manual convergence adjust screen is all you need to get a good picture. If the customer controls or auto-focus do not work correctly, you have not completed repair.
Do not attempt accessing and fiddling with the service screen unless it is absolutely required.
If there are still problems, get professional service help. Many of the ICs sold by the discount "Shopping Cart" One Stop Kit sites are bogus. They do not work.
Many times consumers buy the New and Improved" IC kits that are offered. Don't even think about it. All low ohm resistors will have to be changed. Many opportunities for damage and misadventure. Your Upgrade kit supplier is re-designing the TV that Panasonic spent millions of dollars perfecting.
Many consumers try to do a convergence repair and TVs become scrap. Check out the TV help blogs, most start with "I installed a set of ICs I purchased on the web, changed resistors as well, Now the TV has a poorer picture than before or it will not start."
If you have no electronics experience or training the chances of success are similar to do-it-yourself brain surgery in a Peruvian jungle with a sharpened arrowhead.
Call local service that knows your Panasonic TV. Ask for price before he comes out. If he won't give a firm estimate for on-site "convergence" repair, call someone else.
Call me in Canada, I'll give you a price.
easyab
Mar 14, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Picture is blurry and concaved
This model kp-51HW40 uses two of the STK-392-560 CONVERGENCE IC CHIPS.
Usually just both chips need to be replaced and the set adjusted with the Sony remote---You can buy a pair of the chips on Ebay for less than 14 dollars plus shipping.
If you can do this repair you can save the set and a lot of money as most shops will charge 300 or more for this kind of repair.
I can give you general instructions if you think you can do it---there are places on the internet that sell
kits for this--usually very pricey and many of the included parts are not usually needed.
IF CONVERGENCE WILL NOT ADJUST: BOTH CHIPS NEED TO BE REPLACED.
IF YOU HAVE QUESTIONS OR NEED HELP, LET ME KNOW, I am here to help people.
If this information helped you, rate this solution as I do this here for free.
SD TECH
Nov 09, 2009 | Sony KP-51HW40 51" Rear Projection...
Blurry picture on left side double image right side is ok....
Ur convergence is dead,need convergence kit.
U know how to solder right?Tries these websites for convergence kit.Tv Repair World.com,Shopjimmy.com,Ebay.com or Partstore.com
Sep 25, 2009 | Zenith IQB50M90W 50" Rear Projection...
My tv is blurry, showing green and red waves...zenith d61w25
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic2_bing.gif,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 01, 2009 | Zenith D61W25 61" Rear Projection...
3D blurry picture
The convergence ICs and resistors need replacement. The DPTV305-345 convergence repair kit works for most Phillips rear projection Tvs. The kit contains the two ICs 12 resistors and the CD with detailed instructions
http://www.tvrepairworld.com/
Jul 22, 2009 | Hitachi 43UWX10B 43" Rear Projection...
There is a picture but it is blurry with a big yellow blur.
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Dec 30, 2008 | Philips Magnavox 51MP392H Rear Projection...
Apex 51' gb5108
Just click below for convergence repair kit;
http://servicemanuals.vstore.ca/
Double images and colors are blurry .Blue,red and yellow wave coming up from the bottom of the screen on the lower left and fuzzy images this is a symptom is for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused truoble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is intallation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
Hope this may help;
Regards,
VOTIT
Oct 10, 2008 | Apex Digital GB5108 51" Rear Projection...
Too much red!
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
  • Screen looks 3D
Oct 08, 2008 | Hitachi 53SDX20B 53" Rear Projection...
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
Electro Med Services...
