Question about Microsoft Windows XP Home Edition with Service Pack 2b for PC
Problem started when I tried to right click a folder. It locked up PC(hour glass just kept turning) I have to go to task manager to shut it down. Now it seems to happen almost anytime I click a folder to open it. I've run my malware programs and advanced window care, and CCleaner. Still not working. I have WinXP sp3.
  • 3,267 Answers
Use a genuine antivirus because your PC is showing classic symptoms of being infected with virus which has been running for quite long and is resident in the windows system files. Either use a antivirus to clean your PC else take a backup of your IMP data and reformat reinstall your programs. Be carefull when adding your backed up data, screen it with the antivirus before transfering back to the PC...........................sodeep
Posted on Aug 01, 2009
  • 17 Answers
Have you tried using System Restore? Just set your computer back to before the problem started. You'll lose anything you downloaded or installed since then, but your files will be fine.
How can I shut down my computer?
The setting is in the APM (Advance Power Management) in BIOS. Select the correct power management in BIOS
Sep 05, 2014 | Microsoft Windows 7 Home Premium 64BIT...
My acer aspire 4750g did not show anything once on after repairing windows 7 startup
A virus or infection has hidden your desktop or files and folders.
If your desktop icons are missing try the steps below.
Click Ctrl+Alt+Del to get to Task Manager. Hold the Ctrl key, plus Hold the Alt Key then hit the Del key while holding them. Once the task manager opens Clcik the Processes tab then click the Image Name Column heading on the left to get them in alphabetical order. Scroll down and look for explorer.exe. If you see it click it to highlight it then click End Process.
Next, click the FILE tab at the very top left of the window and select New Task (RUN). When the Create New Task window opens type explorer.exe and press ok. Your start menu, task bar and desktop icons will start appearing and populating. if not that means a virus has hidden your files and folders.
If your files and folders are missing then try the steps below.
Open the Task Manager by clicking Ctrl+Alt+Del. Press and Hold the Ctrl key and the Alt Key, then hit the Del key. Run the Task Manger.
In the upper left hand corner of the Task Manager window click File then select New Task (Run...). When the Create New Task window opens type: explorer.exe and press OK. Look for My Computer on the left when explorer returns the results. Don't click the + sign to the left of My Computer, instead click directly on the words My Computer, then look to the right and you will see Local Disk C. Click on Local Disk C one time just to highlight it, you don't want to open it. Once you have it highlighted in blue go to the top of the window and click Tools/Folder Options/View and look down and select Show Hidden Files and Folders.
Things should start appearing if not you can open the Local Disk C drive and click Documents and Settings (Windows XP) or Users (Windows 7) and look down and find the userid or user folders and Right Click on the Folder and select Properties. Look down for the Attributes near the bottom and if the Hidden has check in the box Remove the Check and click Apply. When Prompted apply the setting to all subfolders so that they too will not be hidden. Depending on the of the folder this might take a few minutes. This should restore you back to being operational.
You should download and run MalwareBytes to get rid of the infection.
Go to www.google.com and in the search box type:"Download cnet Malwarebytes" (without the quotes). Download andinstall malwarebytes from the sites download.cnet/malwarebytes. When thesite opens up click on the Green Download button on the left. Do notclick the Red Download button, that's junk. When it finishes installing the GuiInterface will open up with an offer to Accept a Trial Version or Decline. CLICK DECLINE you want the totally free version. Run a QUICK SCAN. As it scans, if it finds infections the number will be in red. When it finishes scanning, click SHOW RESULTS. A notepad text document will open up showing you the results. You can close the text document and go back to the Gui Interface where you will click REMOVE SELECTED RESULTS. The objects will already be selected for you. When I finishes removing the objects click ok and it will sometimes reboot your mach
May 08, 2012 | Computers & Internet
After bootup only Ease of Access and Shut Down buttons visible
Buttons where? Are you saying there are no icons on your desktop and the start menu is missing? If so try this: Click Ctrl+Alt+Del to get the task manager to come up. Press and Hold each key (Ctrl+Alt) until you hit the Del key, then you can release them.
When the task manager opens up click the Processes tab. You can click the Image Name column to get them in alphabetical order. Look for explore.exe, if you see it listed click it once to highlight it then click the End Process button at the bottom right portion of the task manager window.
Next click File at the very top portion of the task manager window on the left and select the option New Task (Run). When the Create New Task window opens type: explorer.exe and press OK. Your items will start populating and appearing on the desktop.
You need to run a virus scan because something might have caused this to happen.
Mar 26, 2012 | Acer Aspire One PC Notebook
Toshiba Satellite Pro L300 keeps locking up for no reason. After turning it on for awhile the mouse won't scroll anything or select anything and the only thing I can do is turn off the power and take the...
Open the "Task Manager" by (right ) click in the Statusbar, located in the same (level as the start button). Next see how many Processes are running? If the (number) of processes running are between 75-80, the Computer is running very slow, this could be a ("Low") Memory problem, you can check the "memory usage" in the "Task Manager" as well. Try to "Shut-down Non-essential programs from "start-up."
Jan 22, 2010 | Toshiba Satellite Pro L300 Notebook
Laptop got stuck!
You can end the Not Responding Application to task manager, just press ctrl+alt+del then click on task manager, or ctrl+shift+esc to go there directly, click on task that is not responding then click on End Task.
If you want to shutdown your computer that froze just press on the power button of your computer for 10 seconds or more to force it to shutdown.
Dec 17, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Shut down problem
somthing is running in the background ... maybe spyware ... maybe just some application ... try shutting everything off manually in ur taskbar and then shutting down ..
or Else You can also right click the task bar and select "task manager" from there go to "user" and above that you find the shut down selection in one of the menus.
Mar 15, 2009 | Dell Inspiron 1525 Laptop Jet Black (15.4"...
How to rebot acer 4220 laptop
usually holding down the power button for a long time will force a reboot. I am not sure if that is what your asking
Dec 05, 2008 | Computers & Internet
My computer is locked up with the Roxio media manager unable to shut down or cancel out and I cant delete my blackberry install etc??
well when an application is locked and (not responding) try to force it to shut off by going into task manager (rick click on the bar at the bottom of your desktop on any unused area and a menu will show the task manager then select it by clicking on it, or to type ctrl+alt+del and select task manager) and go into applications and select the application an click on end task, and click ok on any other window that comes up thereafter.
if that does not get your application to shut down, try to do it by looking for the process that runs the application and go into the processes tab in task manager and end any process related with the application (you may need to know or guess what process to end as the names sometimes may be acronyms of short versions of the actual name of the program you're running on the system.
Oct 08, 2008 | Computers & Internet
Computer will not shut down
I have not switched to Vista, but I would try starting the Task Manager (right click on the task bar and select task manager). Then I would select the Processes tab and start killing processes to see if you can track down which one is causing your problem. Assuming you can narrow this problem down to a single process you'll at least have a fighting chance at solving fixing this.
Good luck.
Nov 19, 2007 | Acer Aspire L100 PC Desktop
Microsoft Windows XP Home Edition with Service Pack 2b for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
