Question about Mitsubishi VS-5059 50" Rear Projection Television
My 62" Mitsubishi Rear Projection TV is Broken: Can you help me.
Hi, my 62" WD-62531 TV is old, but I recently moved and when I hooked it up to my Dish it worked, however recently it flicker's after being on for about 10 minutes. It's driving us crazy. Can you help me?
  • 934 Answers
Guessing that it must be related to the move it could be HV (High Voltage) and probably something like the HV cups coming from the splitter to their respective crts... This is not an area for a novice this is all HIGH VOLTAGE and I refuse to give out the trade secrets we use in the field for detecting HV leaks - they could really ruin your day if they were not performed precisely... However, this isn't an expensive fix for a technician to come out and see if the leads are properly seated in the HV or worked loose in the move...
Bill
Posted on Nov 25, 2007
Picture is dark
the problem is that the lopt is loosing power this can be due to a leak. in it there fore you will hear a hissing sound or the lopt is simply past its time. and will need to be replaced ( the lopt is a unit that sends power to the screen or in this case the globes the less the power the duller the picture)
good luck hope this helps
Jul 12, 2010 | Mitsubishi WD-62531 Projection Television
WD-62531 fan
If the fans aren't operating then the set shouldn't stay on or even turn on. If its the main lamp exhaust fan then you are looking for part number 299P288010. They are relatively easy to replace as they only have a 3 pin connector that will plug into the main board or the power supply. Verify its that fan and as always if you replace it yourself make sure the set is unplugged. Once replaced the back will have to be re-installed or the set will not work as it has a safety switch that detects when the lamp door is off and on.
Jun 29, 2010 | Mitsubishi WD-62531 Projection Television
I have a 62 inch mitsuibishi dlp you hear the sound but the picture is off were can i buy a wd-62531 lamp cartridge
Hi
Thanks for using FixYa. You can buy the lamp from this link:
Mitsubishi wd-62531 Parts
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 25, 2010 | Mitsubishi WD-62531 Projection Television
I HAVE A 65 INCH MITSUBISHI TV WD-62531, WAS WATCHING TV, AND ALL OF SUDDEN THERE IS A BLACK FILM ON THE BOTTOM OF THE SCREEN. CAN ANYONE HELP ME OUT WITH THE PROBLEM, PLEASE EMAIL MIKEKIMA@HOTMAIL.COM
Have a Mitsubishi 65 rear projection menu keeps fading on and off, any ideas of the problem. Bulb just replaced 2 months ago, no problems with bulb. Also a DVD works fine, but tv picture will not come on.
Dec 24, 2009 | Mitsubishi WD-62531 Projection Television
Mitsubishi WD-62531 Replaced lamp 2 weeks ago. Red light flashing again. Same problem but the lamp is fine. Sound but no picture.
You have either a bad ballast (it powers the lamp) or a bad DMD board. Either one of those will result in a no lamp fire issue. Have a technician look at it...
Oct 17, 2009 | Mitsubishi WD-62531 Projection Television
No power to a 65" Projection Mitsibishi.
The inputs may have to be re-soldered this is a common issue with projection screens
Oct 12, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi Model # is WD-62531 cracked screen!
HI, there are no replacement screens available for this model unfortunately. Sorry for the bad news there...
Apr 20, 2009 | Mitsubishi WD-62531 Projection Television
Mitsubishi tv model wd-62531 less than 2 years old
It sounds to me like your bulb has burned out. Look behind your TV for where the bulb housing is and pull the bulb out to check if it's burned out or not. You'll know when you look at it if it's toast.
Dec 10, 2008 | Mitsubishi WD-62531 Projection Television
Mitsubishi 62in tv
You can get the owners manual on-line at mitsubishi-tv.com.
That should give you all that is needed.
Good Luck,
-Bill
Nov 01, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Televison & Video Logo
59 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
