Question about Garden
Motor is free but the starter wont turn the motor
  • jlcarty5 May 11, 2010
    What type of engine is it,model number? ohv?
  • blacktophero May 11, 2010
    does the starter engage
  • 162 Answers
Low voltage in the battery or bad starter
Posted on Aug 01, 2009
Put a new starter in and it wont start but it engages.
Hi, Anonymous your starter motor is not/was not the problem that dubious title goes to the starter drive/Bendix/clutch is a separate component that is activated by the starter motor it is a mechanical gear driven part that engages the clutch pack to turn over the engine. It has an internal mechanism that allows the gear to turn in one direction and once the engine starts allows the drive gear to free spin. If gear free spins in both directions then the drive gear has failed, it is not serviceable and needs to be replaced. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Starter Clutch Problem
Starter spins but doesn turn over the engine Yamaha Star Forum
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2000/LIT-11626-13-36_96.pdf
Jun 23, 2014 | 2005 Yamaha V Star 1100 Custom
My yamaha thunderace wont start you press the start button and the celenoid just whines the starter motor spins ok when direct power is supplied
Hi, Anonymous your starter motor is not/was not the problem that dubious title goes to the starter drive/Bendix/clutch which is a separate component that is activated by the starter motor it is a mechanical gear driven part that engages the clutch pack to turn over the engine. It has an internal mechanism that allows the gear to turn in one direction and once the engine starts allows the drive gear to free spin. If gear free spins in both directions then the drive gear has failed, it is not serviceable and needs to be replaced. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Troubleshooting bike that wont crank
Starter motor won turn
Yamaha YZF1000RJ Service Manual
YAMAHA YZF1000R Owner Manual
Nov 09, 2012 | 2000 Yamaha YZF Thunder ace 1000 R
I have an 03 Tahoe. The engine cranks but it wont turn over. Even with a jump. I put a new battery in, banged on the starter and it still wont turn. Before I go through the entire process of elimination I...
Try to turn the motor at the flywheel with a screwdiver to see if it frees up the starter. If not it sounds like the starter is out. If that doesn't work check to see if the starter gear is not jammed against the flywheel. Also you can try to turn the belts to free up the starter.
Feb 20, 2011 | Chevrolet Tahoe Cars & Trucks
My XL-7 was working yesterday, came home and now it won't start, it sounds like the starter is working but it won't turn over. We put it on a charger all day and it still wont turn over. Any problem...
ya sounds like the starter is bad if the motor wont turn over the starter is junk have it tested a auto parts store can test them for free.
Dec 26, 2010 | 2006 Suzuki XL-7
Starter motor wont turn over the engine
My name is Dane and I'll try to help you with your problem. First attempt to turn the motor by hand to make sure it's free. Make sure you battery is fully charged, and all safety devices are in their proper position for starting. If you have a voltmeter, set it up for DC volts and place the red lead on the starter terminal, and the black lead to a good ground. turn the key to the start position and verify 12VDC. If you have that, check that your starter gear hasn't jammed onto your flywheel. If your battery is indeed good and the starter is free, then you have a bad starter. If not then you have to trace your safety switches and selenoid to see where the circuit is failing. Keep in mind that you can have 12VDC to the starter but if your battery is low, you may not have enough amps to turn the motor. I hope this helps you.. Thanks! Dane
Dec 02, 2010 | Husqvarna Garden
Car wont start without pushing keypad, key turns and lights,radio etc appears but car wont start. its a 1996 model
check the earth wire from the battery, if it is a poor connection the car will not start but you may still get lights etc.
The starter motor could be completely jammed. put the car in gear with the keys not in the ignition and push the car forward until you feel the engine turn over, this may free the starter motor up.
Jan 28, 2010 | 1996 Toyota Camry
Starter wont turn over battery good
Could just be sticking, give it a tap with a hammer if you can get to it, otherwise put the car in 2nd gear and get someone to help you push it forward until you feel the engine turn over, it wont start or anything it just forces the engine to make a revolution and frees the starter motor off. you dont need the keys in the ignition just hand brake off and push. that will most likely fix it. If it keeps doing it then you may need a new starter motor or a selonoid.
hope this helps.
Jan 15, 2010 | 1999 Cadillac DeVille
Pontoon wont start.The starter is good the cylonoid is good.the starter will come up and start to turn the flywheel and stop.I can hear the starter whine.but wont turn over.I have charged the new battery.
I have worked on many outboard motors. Since your motor almost starts, do these things:
1. install new spark plugs unless you are certain that the ones u are using are good.
2. Add a product called seafoam to the gas tank. Check to be sure but I recall that you add one ounce per gallon [this stuff is great].
3. At any auto parts store get a can of electrical connection spray. Spray all of your contact points.
4. Also get a can of starter fluid. Give the air intake a couple of short blasts and start the motor. if it runs real rough continue with the startere fluid until it runs smoothly.
5. Be sure that your battery cables are corrosion free where they slide over the battery terminals and that the connections are tight.
Enjoy your boat ride.
Sep 07, 2009 | Sport & Outdoor - Others
Car wont start
Does the battery have enough capacity to turn over the engine though? Even flat car batteries will still power the radio. The best way would be to jump start the car uing a set of jumper leads. If it starts you know it is the battery that needs replacing.
If it still wont turn over then it is most likely the solenoid in your starter motor. You can often tap the starter motor with a hammer and free the solenoid as a temporary fix. The starter motor is loacted at the back of the engine on the bell housing if rear wheel drive, or around the tranmission if a front wheel drive.
Jul 25, 2009 | 1998 Ford Contour
03 Hyundai elantra wont start
it you can hear the starter motor spining but is not engaging into the fly wheel then the starter motor will need to be re-conditioned or replaced
Feb 26, 2009 | Hyundai Motor 2003 Elantra
Garden Logo
54 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
