Question about Linksys Wireless-G WRTP54G Router
I haven't used my wireless router in some time, I need to GET INSTRUCTIONS TO SET IT UP AGAIN. i HAVE ALL MY PASSWORDS, JUST NEED TECH. INSTRUCTIONS.
  • 724 Answers
Http://192.168.0.1
rest is read and configure
Posted on Aug 01, 2009
Connect wireless network
You need to reset the cisco E3000 router back to factory defaults; This will allow you to login to the router and set it up again as if it is being setup for the first time.
Most routers have a "reset" button usually requiring a pen or a paper clip to access and press the button. Usually holding this button down for about 30 seconds will reset the router to default settings.
Then you will need to use the instructions manual to setup the router again. This will allow you to set the wireless password again to gain access to the wireless connection again.
If you don't have the instruction manual, usually you can download it from the manufacturer's website for the respective router. In your case the Cisco E3000.
Hope this helps.
Dec 07, 2013 | Toshiba Satellite A35-S159 Notebook
Router pasword
Hello.
- Do you need the wireless password or the router login password?
If you need
wireless password(security key like WEP or WPA) or you would like to setup wireless security for your Netgear router, access the router setup page by typing http://www.routerlogin.net or 192.168.1.1(sometimes it's 192.168.0.1) in the address field of your browser and then press Enter.
Enter
admin for the router user name and your password (or the default, password).
- This image is the login window to access the router's setup page.
- After logging in. Look at the main menu on the left, click on Wireless Settings, from there you can check the Wireless Key(For WEP you need Key 1,2,3 or 4 whichever is selected... For WPA you need passphrase) or you can setup wireless security from there if you haven't done so.
- This image is the router's setup page and this is where you can configure the router and check some settings like Wireless security or password.
**If by chance you are unable to access the router's login or setup page by using the default username &password(admin, password) and you totally have forgotten it, you need to reset the router to factory or default settings then you have to setup the router again.
**To reset the router to default settings:1. Unplug all the cables attached to it except the power cord.
- Make sure the router is plugged into the power outlet, then hold down the reset button at the back of the router for 30 seconds using a paper clip or a pen. You should see the lights flicker momentarily on the front panel of the router.
2. Once the lights are stable, connect 1 computer or laptop directly to the back of the router(Ethernet/LAN ports usually they are labelled by numbers and have the same color, just pick one). If you pick number 1, check the corresponding light indicator at the front panel of the router, make sure light 1 is also lit up if not choose another port at the back of the router.3. Setup and configure the router again.
~~ Hope this helps ~~
Dec 11, 2011 | NetGear Computers & Internet
I need help getting the wireless key from the router
If you need wireless password(security key like WEP or WPA) or you would like to setup wireless security for your Netgear router, access the router setup page by typing http://www.routerlogin.net or 192.168.1.1(sometimes it's 192.168.0.1) in the address field of your browser and then press Enter.
Enter
~~Hope this helps~~
Nov 28, 2011 | NetGear WNR2000 Wireless Router
Get password
Hello.
If you need
wireless password(security key like WEP or WPA) or you would like to setup wireless security for your Netgear router, access the router setup page by typing http://192.168.0.1) in the address field of your browser and then press Enter.
Enter
This image is a sample of the login window to access the router's setup page.
After logging in. Look at the main menu on the left, click on Wireless Settings, from there you can check the Wireless Key(usually indicated as "passphrase") or you can setup wireless security from there if you haven't done so.
1. Unplug all the cables attached to it except the power cord. - Make sure the router is plugged into the power outlet, then hold down the reset button at the back of the router for 30 seconds using a paper clip or a pen. You should see the lights flicker momentarily on the front panel of the router.
~~Hope this helps~~
Nov 27, 2011 | NetGear DG834G Router
I do not remember the password for my wireless router. How can i get it?
Hello.
Enter admin for the router user name and your password (or the default, password).
This image is the login window to access the router's setup page.11_27_2011_1_31_58_am.png
**To reset the router to default settings:1. Unplug all the cables attached to it except the power cord. - Make sure the router is plugged into the power outlet, then hold down the reset button at the back of the router for 30 seconds using a paper clip or a pen. You should see the lights flicker momentarily on the front panel of the router.
Hope this helps. Have a nice day.
Nov 27, 2011 | NetGear Computers & Internet
Need password for wireless roter
If you need the login password for the router's setup page, the default username: admin, password: password.
If you need the wireless key or password, you need to access the router's setup page by typinghttp://www.routerlogin.net or 192.168.1.1 in the address field of your browser(IE or Chrome). On the login use the default username and password(admin, password).
After logging in. Look at the main menu on the left, click on Wireless Settings, from there you can check the WEP or you can setup wireless security from there if you haven't done so.
**If by chance you are unable to access the router's login or setup page, you will have to reset the router to factory settings by holding the reset button on the back of the router using a paper clip or a pen for 30 seconds while the router is plugged in to the power outlet. You will then be able to access the router's setup page using the default username and password.
Hope this helps.
Oct 16, 2011 | NetGear WNR2000 Wireless Router
Forgot the password
If you have forgotten the password and haven't set it, try using no password. The default password is blank and the default username is Admin. If this does not work and you have no way of guessing your password, you will need to reset your router. This should only be done if you know your broadband username and password as it will wipe to blank if you reset and you will need to type them in again.
Aug 09, 2011 | D-Link DIR-615 Wireless Router
My son changed the password for wifi on my router and wont tell me what it is
Connect directly to the router using an Ethernet cable if you haven't already and go to http://192.168.2.1 . Go to the Wireless > Security and input the new password.
Jun 07, 2011 | Belkin Play N600 Wireless Dual Band Router...
I can`t access router setting. I haven changed user name an pass. I tried to shut down the router an wait for an minute. Then I turn it on an tried to access 192.168.0.1 . After than in the username field...
If you cant remember the username and password of your router you can reset it to bring back the default settings of your router to be able to access it. At the back of the router you need to press and hold the small hole using a pen or a paper clip for 10-15 seconds. after that the router will return to its original state. Keep in mind that it will remove all the settings that you've saved. Then access the router using 192.168.0.1 and using its default username and password
Thanks for using Fixya
Jan 27, 2011 | Levelone CP TECH WBR6002 Wireless Router ...
How to set up a password on ASUS RT-G32 wireless router so others cannot access my internet services.
Open a browser. Type in the router IP 192.168.1.1. Login to the router using your user id and password. If you have never set up a user id or password, then use the factory default ones to access. Once into the router settings, change the admin password to avoid anyone later accessing the router and changing your settings. Once you save the admin password change, you will be kicked out and must login again with the new password. Once in, go to wireless settings. Here you will able to set a wireless password (security key) for your wireless LAN. Once you save and exit, you will need to go to all your wireless devices and modify them with the security key in order for them to access the network. Once the key is in the router, your network is secure from outsiders getting in without knowing the key.
Aug 23, 2010 | ASUS Computers & Internet
Linksys Wireless-G WRTP54G Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
