Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
Distortion at the outher left an right positions? approx 2" each side
Purchaced approx. 2 years ago.think its 52" we are on a dish and it does not seem to have the problem with a DVD in operation? is it withthe TV, cables or the system(dish box) ?????
  • 934 Answers
If it's an HCP4752W it's a 47" but what's the problem it's having cables or dish box?? No picture, no sound, poor reception, please elaborate.
Posted on Nov 25, 2007
On 2002 ford explorer,4.6-v-8, when i was changing timing chain guides and adjusters the chains jumped teeth on the crankshaft. The manual says the left camshaft timing mark should be approx. @ 11:oo & the...
Look for some Youtube videos on this repair. If I remember correctly the links on this chain have different color metal for the spots that the cam tooth goes against. When each side is in the proper tooth the right and left colored links will be on the cam mark and the crank mark should be on the timing TDC mark. Sounds like the slack you describe is wrong and a tooth is off because the tensioner is allowing slack.. You need to slip a tooth one way or the other until the tensioner has room to be in a neutral position.
Mar 10, 2017 | 2002 Ford Explorer
Have 67 Ford Mustang GTA 289V8. How do spark plug no. layout on engine left side is 1-3-5-7 and right side of engine is 2-4-6-8. Would that be correct and what is firing order?
The 67 289. Right (passenger) side, 1-2-3-4, left (drivers) side 5-6-7-8. Firing order, 1-5-4-2-6-3-7-8 cc. This should also be cast into the intake manifold in front of carb. Also, dist rotation is counter clockwise as your looking at motor from front, and #1 should be at approx 1 Oclock position. Most dist caps will have it marked.
Oct 20, 2010 | Ford Mustang Cars & Trucks
3 horizontal lines through screen and distortion
Yes this thing start happening to my tv too about 4weeks ago and this goes away in about 15 minutes. TV is only 18 month old and I donot have extende warranty. Please post the solution if someone has got it repaired. Thanks
Dec 28, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Blurry picture on left side double image right side is ok....
Ur convergence is dead,need convergence kit.
U know how to solder right?Tries these websites for convergence kit.Tv Repair,, or
Sep 25, 2009 | Zenith IQB50M90W 50" Rear Projection...
I think you will find the aftermarket Cat Conv. is the source of your problem, but without hooking up to the factory test equipment at my disposal at my Ford dealer this at best and educated guess based on 20 years of emission related work, I am a Ford certified master electronics technician
Jan 30, 2009 | 1997 Lincoln Town Car
Shadows on screen
Try moving a medium powered magnet (not one for picking up heavy objects and not a refrigerator holding one) over the distorted area. If that doesn't work, try a more powerful one. This worked for my Toshiba LCD. Good luck!
Jan 04, 2009 | Sylvania 6626LCT 26 in. LCD Television
Sensor dry timer problem
Clean off the moisture sensor bars. They are the silver curved strips about 4 inches long inside the drum near the lint fitler. If you use fabric softner sheets, a waxy build up will coat the bars. The dyer can no longer sense the damp clothes, so it goes into the cool down and then shuts off. Time dry bypasses the moisture sensor.
Nov 30, 2008 | LG DLE5977 Stainless Steel Electric Dryer
AKAI LCT2662N screen problems -distorted
that sounds like your LCD controller, since the LCD screen is so big, they will "split" the screen into 2 smaller screens, otherwise it would be so outrageously expensive to have one big massive lcd controller. Your lcd controller is most likely a two-in-one card though, meaning that there are 2 controllers on one board. You'll more than likely need a new controller card for your tv.
Feb 20, 2008 | Akai LCT2660 26 in. HD-Ready LCD...
Screen Noise
replace DM or try to fix it.
Jan 03, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Shaded area on tv
Aug 27, 2007 | LG RU-52SZ51D 52" Rear Projection...
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
56 people viewed this question
Jerry Greenberg
Jerry Greenberg
