Question about Pondmaster Pond - Mag 18 Pump, 1800 Gph
Pondmaster 1800 is slowing down pump is clean of any debris it is approx 3.5 yrs old runs 24/7
This is from Danner:
SERVICE AND MAINTENANCE
The housing should occasionally be removed to clean and inspect the impeller assembly. The impeller is the only serviceable item and can be pulled out of the body. If it is worn or broken the entire impeller assembly should be replaced. This will restore the pump to original capacity. Pumps taken out of service for an extended period with fluid inside run the risk of forming a crust which may prevent subsequent starting. Saltwater should be flushed out with fresh water.
IMPORTANT: FOR PUMPS USED IN SALTWATER OR HARDWATER.
Magnet impeller assembly must be removed approximately every 3 months for cleaning in white vinegar to remove accumulations of scale or calcium. Disassemble magnet from impeller by pulling them apart (it may take a strong pull). One end cap will come off. To clean the calcium scale off of the shaft and bearing inside the magnet soak in white vinegar for a few hours and scrape it off. Reassemble magnet/impeller assembly. Do not loose (sic) any washers located between end cap and impeller.
Hope this helps!
Bill
Posted on Sep 22, 2009
    President:
  • 1,486 Answers
Change the brushes in the motor.If its running 24/7 then thats your problem.
Posted on Aug 01, 2009
Why is it not pumping?
Pondmaster pump repair part 1 - YouTube
? 3:12
www.youtube.com/watch?v=KFbe0xmk2tk
Oct 29, 2011 - Uploaded by Asianleful Pondmaster pump repair part 1 ... How to build a simple PVC Hand Pump - the Peters Pump - Duration: 20 ...
Aug 07, 2015 | Pondmaster Garden
Water is draining from pool iwth Rike 1800 pool pump, but flow is very slow and weak and definetly nothing like 1800 GOH
How long is the hose the pump is connected to?
What is the inside diameter?
With no hose, the pump gives 1800 gph, 30 gpm
with lots of small hose, that could drop to 5 gpm.
Ensure no debris in inlet or hose.
Gary
Sep 24, 2011 | Rule 1800 H53SP-24 Swimming Pool Cover...
Kitchen aid dishwasher, 3 yrs old, dishes on top rack do not get clean
On your model, upper rack cleaning issues are most often linked to debris in the inlet to the pump. I have put some instructions together on cleaning this. If you follow the link it will explain how to check and clean this.
Sump Clean Out
Aug 22, 2010 | KitchenAid Dishwashers
The programme is stopping with about 40mins left and the tap symbol appears . I have read a few blog articles and ... removed the front plinth , cleared any filters, checked hoses for blockages (none) but...
using a tx20 driver remove the pump cover (remove filter and looking down into sump you will see screw at approx 10 o'clock), check for obstruction, may be a piece of glass etc so go careful, remove any debris and check the impellor turns ok. The unit will not drain without this cover refitted but you can check impellor is rotating whilst it is off. Check all outlet hoses, particularly the spigot connection under the sink if this is how it is fitted, Good luck
Jun 21, 2010 | Neff 24 in. S5555X0GB Built-in Dishwasher
Stylemaster 4217142 drain pump leaking - pump nos.: assy 3363892 underneath 3352493 green felt nib marking 10112 leaking from impeller back bearing. where can I source a replacement pump for this model?...
I would try to go to a scrap yard and look for similar machine to remove the part you need the only alternative is find the local washing machine engineer and get a similar pump to fit or take the pump apart and clean the motor shaft of cotton or other debris, reassemble and just maybe that's all it needed good luck eric
Jan 15, 2018 | Whirlpool 3.2 cu. ft. Plus Washer
GE Profile washer will not drain. (DOES SPIN)
take the front off the washer take the two hoses off the pump youll probably find where its stopped up
Apr 24, 2009 | GE Profile WPRE6100G Top Load Washer
Pondmaster 250: Impeller or motor broke?
pondmaster 250 comes with a 3 year manufacturer warranty you should just exchange it for a new one. Overheating from low water sounds like the issue but as long as the shaft and housing are not scarred from debris they will replace without any questions
Nov 29, 2008 | Danner Pond Pondmaster 250 Gph Mag - Drive...
Aquascape 3000 Pond Pump
I have had similiar experiances with these. My most durable pumps are 1. Atlantic water Garden Tidal wave 2 pumps. - ( 1 pump repaired in the last few years out of hundreds sold) 2. Pondmaster - most models. The pondmaster (Danner Mfg. customer service is fantastic- no hassle problem resolution). The pumps get better every year and THREE year warranty.
Nov 08, 2008 | Garden
Pondmaster Mag 3600gph pump
Is power to the pump insides; if the best thing is to re place it; I couldn't repair my same pump.
Oct 31, 2008 | Danner Pond Pondmaster 500 Gph Mag - Drive...
Pondmaster Pond - Mag 18 Pump, 1800 Gph Logo
278 people viewed this question
Top Pondmaster Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Pondmaster Garden Expert? Answer questions, earn points and help others
