Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
The door will not stay shut when it gets down
    President:
  • 3,197 Answers
Not much information here. Is the main light flashing 10 times when the door reverses? If so you have a sensor problem. If the light is not flashing 10 times and the door reverses when it hits the floor you need to adjust the down limit which is on the side of the motor unit. Turn it in the opposite direction of the arrow printed on the cover.
Posted on Aug 01, 2009
Grand am, battery is running down because when door is shut radio and dome light are staying on?
Pull the kik panel off and disconnect the white wire from the button. Replace the button and connect the wire.
Oct 12, 2014 | 2004 Pontiac Grand Am
Freelander rear door window
The glass slides down slightly before the door is opened and stays down slightly until locked shut. This is to stop the glass from popping out when the door is slammed shut.
I would check for corrosion in the rear door panels.
Feb 05, 2018 | Cars & Trucks
Interior lights run battery down when car is turned off.
Are you saying the interior lights don't shut off after the door is closed, or that the interior lights, when they're on for a short time, run the battery down?
If the lights stay on when they should shut off, there could be a bad door switch that's not registering that the door is closed.
If the lights being on for a short time when the car isn't running is running the battery down, your battery may be getting close to the end of it's lifespan & need changed.
Aug 17, 2010 | 1999 Dodge Intrepid
Rear door won't stay shut
Check the latch mechanism on the door. There is a piece of the latch that closes around the clasp on the door frame. sometimes this closes when the door is open and you can't shut the door. Take a screw driver and flip this latch piece open and close the door.
May 29, 2009 | 2008 Chevrolet Hhr
Dome light and reading lamps stay on and will not cut off.
your door close switch is non-functional. its located in the door jamb. its a black button the size of a shirt button. usually held in by one or two screws.
there is one for each door.
Apr 11, 2009 | 1997 Chevrolet Cavalier
What would make the interior lights in my 2003 Lincoln Navigator stay on after it gets shut off? They will only shut off when you drive down the street, once you shut it off and get out, they stay on and...
you may have your dim switch on and this cause the lights to stay on but they don't stay on all night or day they have a 10 minutes delay switch after 10 minutes they go off but yes there is an open circuit can be a door can be the trunk or the dim switch look for it and try to find the source of this open circuit like a mention before it's on the doors or the dim switch
Mar 27, 2009 | 2003 Lincoln Navigator
Door on driver side won't close- latch hitting
Pull on the door handle as if to open the door and pop the latch back open with a screwdriver and you should be good to roll
Mar 02, 2009 | 1997 GMC Sierra
Sub-zero 550 reefridgerator top freezer bottom - refridgerator door not staying closed
Just a guess, but I would check the gasket on the door. They can go bad or get distorted and bunch up and cause the door to bind and not close properly. Also check that the fridge is leveled properly. Will the door close if pushed? Will it stay closed?
Dec 25, 2007 | Sub-Zero 650 / O Bottom Freezer...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
246 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
