Question about Magic Chef CGR3725 Gas Kitchen Range
A BEEP COMES ON - F 1 READING - HAD REPAIR MAN OVER 3 TIMES- CHANGES PART KEEPS ON HAPPENING
  • 15,935 Answers
Usually if the symptoms stop with the touchpad disconnected from the clock, that touchpad is often the cause. If the error continues even with the touchpad disconnected, the clock itself is usually at fault and will need to be replaced to correct the problem. On some models it is not possible to disconnect the two in which case the electronic control/clock would have to be replaced regardless.
There is a tool that allows testing of the touchpad (on models where they're separate parts) but is kind of expensive for a homeowner to purchase them self. If you contact a technician so equipped, they should be able to test the touchpad before replacing any parts.
BTW. On most models, the control keypad is only sold along with the whole control pane.
You have either a bad ERC (clock) or a bad touch pad.
1. Disconnect power to stove
2. Gain access to the back of the clock (electronic range control or ERC).
3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
4. Make sure everything is clear and will not short out when power is turned back on.
5. Turn power back on to stove.
6. Watch for the F1 and listen for the beep.
7. If you get the F1 and beep, replace the ERC.
8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor - check carefully the wires to and from the oven temp sensor!! This has been a new occurrence to us in the last 2-3 years or so
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Posted on Aug 01, 2009
My Janome MyStyle 16 keeps jamming - thread bunching in the bobbin cavity. Have tried everything but keeps happening... How can I fix this??
PDF]INSTRUCTION MANUAL - Janome
janome.com/siteassets/support/manuals/.../inst-book-7318-english.pdf
making any other adjustments mentioned in this owner's manual. ..... 16 q w e r t. SECTION 3. BASIC SEWING. Straight Stitch Sewing. Machine setting: q Stitch ...
How to Thread a Janome Sewing Machine - YouTube
? 6:55
https://www.youtube.com/watch?v=NUsT0plWt6Y
Mar 1, 2013 - Uploaded by Easy Sewing for Beginners
In this video I show you how to thread a Janome sewing machine ... I've unwrapped it and started reading the manual and it wasn't easy to see ...
Nov 26, 2015 | Janome Sewing Machines
Keeps going out of line "main motor block". Had it repaired 3 times in last 6 mos.
Guess you should change repair service and ask them some warranty for repair?
Nov 06, 2015 | Sewing Machines
Tv keeps turning off
This is probably due to failing PSU capacitors. It is fixable.
May 19, 2014 | Televison & Video
I have a 03 pt cruiser turbo. For the past 10 mos the car engine light comes on and then is misfires on 2 cylinders. I have had the crank sensor replaced 3 times, cam sensor 3 times, map sensor, harness...
I don't profess to be able to solve this over this keyboard. But push come to shove I would replace the coils that are setting codes. As far as the dealer goes unless they can confirm the problem they will write NPF (no problem found)
Mar 13, 2014 | 2003 Chrysler PT Cruiser
RMT-D2580 keeps changing channels back to D001
1) clean the contacts batteries.
2) retight the spring contact batteries.
3) Solder again the wires from contact batteries.
4) Open the remote control, and resolder all contact point solder.
5) If the problem continues. go the remote control to the repair shop.
sincerely. God bless you
May 09, 2012 | Televison & Video
My new heater keeps going out, the heater man comes over lights it, then leaves, we turn it to the off. We go to turn it on later and the pilot light is out and we can't light it. This has happened three...
he should check the conection to the thermocouple or check the size of the pilot , but new heater 3 times then there is a fault that he should fix , could be a loose connection
Oct 27, 2010 | Cozy (W352E) Heater
My PS3 has had the YLOD 3 times now and I've repaired every time myself. Each time I repaired it last about 6months before it gets hit by the YLOD again. After repairing the console for a 3rd time I was...
Thank You..... Thank You... Thank you.. for answering your own question :) I was going through the exact same thing and couldn't figure it out for the life of me. Only difference was this was only my second re-flow. I know I did everything perfect too. Because like you mine last 6-8 month's. Not two weeks some some who don't put the added tlc needed. After reading your solution I noticed that because of the way that ribbon bends. Some of the beads were protruding from the ribbon. So I pushed them down with a plastic fork prong so I wouldn't rip it. Then flipped the ribbon so it wouldn't bend over the end again. Thank you again Chilled....
Sep 01, 2010 | Sony Playstation 3 (PS3) Console
I have had to have my appliance repair man unthaw and unclog my condensation drain 2 times in the last 3 months. The bottom of the freezer freezes and water drips into the fridge. My refrigerator model #...
Three things. First is that your defrost element is faulty, replace. Second, if the defrost element is working there is usually a thin filiament of aluminium which is attached to the element and inserted into the drainpipe, this keeps the drainpipe from freezing up by radiant heat conducted from the element. Thirdly, your main pc board defrost side is faulty and needs replacing.
Mar 09, 2009 | Refrigerators
Magic Chef CGR3725 Gas Kitchen Range Logo
202 people viewed this question
Top Magic Chef Kitchen Ranges Experts
paulcarew
Dan Webster
Dan Webster
Mike Carew
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
