Question about Fender Music
Fender passport sound system: no sound with two 3 pronged mike chords but had sound with 1 mike that had a 3/4 inch end Today nothing Green light turns red when guitar is strummed or you talk
SOURCE:
  • 5603 Answers
SOURCE: My Fender Passport stays in protect mode.
I have one that has done the same. It is the next smaller size. The power supply fried a toroidal inductor in mine. Frankly, these things are a major pain to work on. You have to usually remove the front panel before you can remove the back power supply and power amp section.
If you have warranty coverage USE IT !!!
The protect feature in mine monitors the power supply load and shuts down the supply if it senses overload. They are hard to work on as you have to bypass the protect to troubleshoot and get to the root cause.
Use the old light bulb in series trick to limit the current.
Posted on Sep 24, 2009
  • 1140 Answers
SOURCE: Power indicator light is red and the system does
It is an indication of a bad speaker cable providing a short. If it stays lit with no speaker cables plugged in it is an indication that it needs to be serviced.
Posted on Oct 19, 2009
  • 1140 Answers
SOURCE: i have a marshall avt 100 which was working fine
This is a problem I would recommend for a qualified Marshall amp service person to look at. Worst case scenario is that somehow the speaker out put transformer or the power transformer burned out. They aside from output tubes are the most expensive parts to replace. Add shop labor on top. Ask for an estimate first. Consider how much a new amp will cost and then decide. I would personally go for the repair myself.
Posted on Nov 28, 2009
Testimonial: "thanks for the help about my avt i will get it mended i think as it isnt a bad amp, cheers"
  • 5603 Answers
SOURCE: I have a Frontman Fender 25R, it has a power, the
You actually have the "B" version as the original 25R doesn't have RCA jacks. Anyway, on with your problem...
I want you to do a test: With a set of headphones plug them into the preamp output and then play your guitar... don't expect much loudness, it may be very faint and will ONLY be in one of the sides of the headphones. This tests the preamp section... have the guitar volume wide open.
IF you can hear the guitar that way, then the switch contact on the PA INPUT jack (not the preamp output) is not making contact. These jacks are really poor and the problem is not that uncommon. Fix is to open the unit and increase the spring tension on the contact or replace the jack. Never use the jack as they worsen evertime you plug something into it.
Note that the failing switch symptom MAY be broken soldering in the vicinity of the jack so look for that also. And also check the soldering of the guitar input jack as that is a common problem. Always loop your guitar cable through the handle so tripping over the cable doesn't break the jack by yanking the plug sideways... another common problem.
Posted on Mar 25, 2011
  • 5603 Answers
SOURCE: I had major static sounds from my yamaha stagepas
Chances are there is nothing wrong with the mixer. IF you accidentally turned on Phantom power, that would cause the problem. Phantom is ONLY used with condenser mics and a few DI boxes. Turning it on can create noise unless balanced lines are used everywhere.
Posted on Jun 29, 2011
Fender Passport pro 500 - speaker static temporary, then goes away. Usually occurs shortly after turning system on.
If this system is still under warranty get it to a warranty service center. This is an early stage symptom of failure with the Power Amp IC. Fender has a good warranty policy on this stuff - 1 to 3 years
If not under warranty you may want to wait until it the problem is more persistent - easier for a tech to fix - unless it IS every time right now. A good tech can identify the issue quickly once "on the bench". My 'gut' feeling is the Power Amp IC when the system is first energizing to full stable power.
Oct 26, 2013 | Fender Passport Deluxe 500watt Sound...
With the wireless mike and the 1/4-inch mike jack and the line-in from a CD-player, how can the volumes be separately adjusted?
Adjust the CD level at the CD player itself. Truly independent adjustment is probably not possible on this small system.
Feb 03, 2011 | Fender Passport P10w Personal PA System...
I purchased a Passport 500 less than one year ago, used it maybe 10 times and recently turned it on to use and it would not power up. No lights nothing. Checked the fuse ok. Tried a new fuse nothing. ...
Check that the power cord is seated completely. These are hard to work on and if there is a failure in it, it is unlikely you will get it restored in time. I would suggest renting a system until you get it repaired. You need rent only a powered mixer with suitable cables as your speakers should be fine. The way the Fender Passport is packaged makes them difficult to work on.
Jan 11, 2011 | Fender Passport Deluxe 500watt Sound...
We have a Fender P-250 PA system. We get the protect light on when we turn on the system rather than the green power light. We can not get it to operate. Please advise... Gary
Likely there is either a failure in one of the power amps or the power supply. The protect means excess current is being sensed.
You need to take in for repair... these are really hard to work on due to the packaging.
Sep 23, 2010 | Fender Pd250 Passport Deluxe 250watt...
I have a 250 Fender Passport. When I turn it on I get the green light and can hear the fan. No sound out of the speakers. What is the problem?
if no output from either speaker could be power supply problem. Comment: from my past experience this equipment is not easy to work on suggest you find a good tech
Feb 04, 2010 | Fender Passport Deluxe 500watt Sound...
When i plug it in the power light just flashes green... i get nothing now
This is likely a power supply failure. These are a pain to work on during repair due to packaing arrangement.
Jan 28, 2010 | Fender Passport Deluxe 500watt Sound...
What's the best way to connect a PC (with DJ software) to a Fender PAssport 500 PRO (I want stereo input)?
Best way is to use a 1/8 TRS (stereo) to 1/4 TRS (stereo) cable from the PC into the Stereo 1/4 inch jacks right below the RCA stereo input jacks.
TRS stands for tip-ring-sleeve which means the jacks have the extra "ring" over a mono jack.
Oct 17, 2009 | Fender Passport Deluxe 500watt Sound...
No sound from speakers
Page 8 of the owners manual explains this and suggests that if their procedure fails to take it into an authorized Fender dealer for service. The manual is dowloadable at Fender.com/support.
Dec 15, 2008 | Fender Passport Deluxe 500watt Sound...
Music Logo
80 people viewed this question
Top Fender Music Experts
Michial Gueffroy
rjivaro
Marvin
Marvin
Are you a Fender Music Expert? Answer questions, earn points and help others
