Question about Refrigerators
Hot mulion strip - Refrigerators
  • Refrigerators Master
  • 1,606 Answers
Fan motor cooling the compressor not working , OR , very dirty coils under the fridge .
Posted on Aug 01, 2009
Why is the strip between the two door very hot
perhaps it is the defrost heater . it could be the door seal is bad in that area .
Aug 30, 2015 | Refrigerators
Why would my turn signals quit working when its hot outside
If it is hot outside it is hot inside. The turn signals are controlled by a bimetallic strip which heats up and when it gets hot enough the straightening strip breaks contact and turns the lights off, the strip cools down then turns the lights on again etc etc. so if the canister is quite old and the strip is fatigued it may no longer be working in that manner and may be jammed on?
replace the flasher unit with a new one, they are cheap and easy to replace.
Please get back to us with your solution to this problem as it may help someone in the future. Thanks.
Jul 20, 2014 | 1993 Nissan Pathfinder
Model 106.56239400 not cooling. Center bar between doors is warm. Suspect defrost timer. Can I jump out the timer before just replacing it?
using a blade screwdriver; turn the timer until it goes off jumping it just keeps the mulion heaters on if the heaters go off replace the timer
Jun 23, 2010 | Refrigerators
Hot strip between doors
First , remove the bottom kick plate , and vacuum the coils . They have to be clean of dust , lint , pet hair , etc . Then pull the refrig out , and remove the lower panel , to expose the compressor and cooling fan . This fan HAS to be working , to cool the compressor AND the coils . If not running ( fan ) , check for an obstruction of paper , insulation , etc , and remove the cause . If not being obstructed , and not running , replace the fan motor . Afterwards , be sure to reinstall the back panel , as this panel , helps pull the airflow across the coils , and compressor . The strip between the doors , has part of the coils behind it , and will get hot , if the coils in front are dirty , or , the fan behind the refrig is not working .
Dec 04, 2009 | Whirlpool Refrigerators
REFRIGERATOR MODEL 106 IS HOT ON THE OUTSIDE. RIGHT FRONT SIDE WHERE FREEZER MEETS FRIDGE.
Make sure the condenser fan underneath near the compressor is running when the compressor runs. How to test it. http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 24, 2009 | Refrigerators
My Subzero bar frig feels quite hot around the edge that touches the rubber and it is making the rubber warm as well. Everything inside is cold, and it is making ice as usual. I think I sense a smell of...
as with alot of refrig units the rubger strip has a warming coil that keeps the door from sticking they keep an even warm temp so as opening and closing the door easy there could be a burn spot in the strip and causing the strip tp be warmewr than it should be almost hot should call a fridge expert after you convince your other half there is a prob normally most fridges have a plan magnetic strip to seal the door
Aug 22, 2009 | Refrigerators
Kitchen Aid Fridge KSRF25FRBL00 - Hot Panel between doors
This strip is warmed to prevent condensation forming here during humid weather. Some models use a refrigerant pass of the compressor to warm this strip other use a heater that can be controlled by a 2 position switch in the refrigerator control panel that reads something like "Turn this on if moisture appears on cabinet exterior". If you have no such switch you should be aware that the strip is ALWAYS warm but barely noticeable until you develop a problem in the cooling system.
Check temperatures in the freezer (Zero Degrees approx.) and refrigerator (Approx. 30). If these are normal don't worry about the heat from that strip. If you find a temperature not normal you have the beginning of a cooling problem unrelated to that strip.
Aug 20, 2009 | KitchenAid Superba Architect KSCS25IN Side...
Front metal , top heating element very hot
This should be OK. There are heat strips placed behind the door frame to prevent sweating around the door frame due to the metal being cold normally without the strips. Thanks, Sea Breeze
Jul 21, 2009 | Refrigerators
Hot center strip
when the center mullion is hot then it means your units condensor fan motor is out. the fan is located by the compressor. this fan keeps the condensor coils cooled off. if the fan is not running then the unit vents through the cabinet.
Jun 24, 2009 | Whirlpool ED5FHEXMQ Side by Side...
30amp breaker labeled heat strip trips and no hot water
That 300 amp breaker must be controlling both your hot water tank and some heat strip somewhere in your house which is designed to either prevent a pipe from freezing or melt ice on the eves of your roof.
please mark this answer as a fixya
Mar 05, 2009 | Weather King 10AJA2501AH Air Conditioner
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
