Question about Amana NDE2330AY Electric Dryer
Amana dryer ignitor lights, sometimes gas catches,sometimes not
Amana NDG2330AWW dryer...ignitor lights, sometimes gas catches, sometimes doesn't. runs for awile, but then no heat. continues to run with no heat, . already replaced limit thermostat and thermal fuse but found out afterwards did not to . please help thanks, steve from oc
  • Amana Master
  • 1,606 Answers
Replace the coils (2) on the burner valve .
Posted on Aug 01, 2009
I have the An Amana commercial quality stainless dryer and mine just started doing the same exact thing. he replaced the ignitor and nothing. Now they say the gas valve needs replacing, $150-$200. He told me it looked like the roller were starting to wear and the dryer is coming towards the end of life and maybe I should look for a new one, that is B.S. My dryer is 6 years old and we only have 2 people in the house so it gets used about 2-3 time per week. I also have an Amana washer that matches (commercial stainless) and the drain pump and drum seal already went out in that last year. My diagnosis is Amana is JUNK!!! I am going to buy G.E. or something non Maytag/Amana from now on!
Posted on Nov 14, 2009
Amana Gas Dryer NDG2330AWW Will not start at all. Thermal fuse has been replaced. Start button has been checked with OHM meter. What should I check or replace next? Thanks
Did you make sure the power outlet for the dryer is working--test with a working lamp. Do you get any lights or sounds? Do you have a wiring diagram for the machine? Sometimes, they place such information inside the machine in a packet where a service person would find it. If the machine has power, then you will need the diagram to trace the trouble area. Hope this helps!
Jan 07, 2011 | Amana ALG331RAW Gas Dryer
Ignitor glows gas valve opens, burns for a while then gas valve closes and ignitor cycles , if dryer is off a while it will light again. amana
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 24, 2010 | Amana Dryers
I have an Amana LG4319w/l2 gas dryer converted to Lp gas. The ignitor comes on but will not ignite the gas. Theis happened before and the technician replaced the ignitor and said the ignitor must dray a...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Sep 11, 2010 | Amana Dryers
The dryer only gets hot sometimes. The gas line
it could be the igniter or glow coil as it is sometimes called. if it is glowing orange in color it may only be igniting once in a while as it is on it's way out. the igniter needs to glow white hot in order to light the gas every time.
Oct 11, 2009 | Amana Dryers
How to remove lower front panel/amana gas dryer model ndg2330aww
look under the fornt panel 2 5/16 screws holding it on
Jan 15, 2009 | Amana ALG331RAW Gas Dryer
Oven not lighting on Amana model agds902ss
Helloemauldin Welcome to Fixya
My name is Huum,
When you turn the thermostat on your range on it sends 120 volts to the bake valve and ignitor. The bake valve and ignitor are wired in series and the ignitor draws all the current and heats up. As the ignitor heats its resistance changes and when it is cherry red the current switches to the gas valve and it opens. The amp draw on the ignitor needs to be 3.2-3.6 amps for the gas valve to open. The gas valve has gas to it at all times. The gas valve should open within 40 seconds after the ignitor starts to glow.
If the ignitor is glowing red and the gas valve doesn’t open the ignitor is usually the problem. Sometimes the ignitor will glow red but the resistance doesn’t change and the gas valve doesn’t draw the current.
This is not a do it your selfer!
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 24, 2008 | Amana AGDS902SS Gas Kitchen Range
Maytag gas dryer model#NDG2330AWW heating problem
your gas coils are bad. they open up for the first cycle but fail to after. Replace your coils and this will solve your problem
Dec 13, 2008 | Maytag Dryers
Amana NDE2330AY Electric Dryer Logo
574 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
