Question about Sharp LC-19SB25U 19 in. LCD HDTV
My sharp has smoke damage.Is it worth fixing?
  • 269 Answers
Depending on what damage has it made, if its the panel. i suggest you should buy a new one. because an lcd panel will half the prize of the actual unit.
Posted on Aug 01, 2009
Why is my car losing oil?
Hi..That is a lot of oil you are losing, The engine is definitely toast.
Blue/Gray Smoke: Blue/gray exhaust smoke is an indication of oil burning in the combustion chamber.
Valve Guides: Excessive clearance between the valve stem and the valve guide allows oil to leak past the gap into the cylinder.
Piston Rings: Worn or damaged piston rings will cause blow-by resulting in blue/gray smoke.
Worn Cylinder Walls: Worn cylinder walls cause blow-by resulting in blue/gray smoke.
PCV System: A stuck closed PCV valve will cause excessive crankcase pressure resulting in blue/gray smoke.
Is it worth fixing? Depends on how much this car means to you, Mileage of vehicle, and just how much money you want to throw into a 20 year old car..The engine will need to be completely overhauled or change out with a used engine probably close to 800- $1000 either way..Probably have a lot more into this than you can live with I'm guessing
Is it worth fixing?
Jan 16, 2015 | 1996 Geo Prizm
Sharp R402JK-T sparking on starting
Unplug the unit and do not plug it back, I can almost picture someone doing this, watching the sparks and smoke and oh the lights dim--Be smart here===either replace it out of hand or take to a repair shop to see if worth fixing or not and do not attempt to turn it on again.
Dec 12, 2012 | Sharp R-9H66 Microwave Oven
Looks like a spider web on my screen how much to fix??? pls itsa lc-37gd8e
Not fixable or worth fixing.The LCD screen panel is broken or damage,will cost the same to replaced the LCD screen same as a new tv.The LCD screen panels or any screen panels for that matter.The tv screen panels are limited produced by the the tvs corporations.Tvs are damages or boken screen panels are only can be salvage for it electronic boards for parts,not worth as a whole tv anymore.
Aug 16, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
How much will it take to fix a cracked membrane with vertical lines on it
Not worth fixing,if the LCD screen panel is damage or broken.Because LCD screen it limited produce it will cost the same as a new tv.Might even cost more after the LCD screen panel part and labors.The LCD screen panel is 90% of the tv,broken or damage LCD screen panel not worth as a whole tv anymore.The tv now only worth as salvage electronics boards parts.
Apr 20, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Cost to repair an LCD tv screen
In today's electronics devices there isn't much to repair specially if the screen is damage. The cost of the repair might exceed the price of the LCD. A cheaper way to get it fix is to try to find a defective LCD(same model) with intact screen.
Sep 28, 2009 | RCA P52960 52" Rear Projection Television
Daughter plugged a 12amp vaccuum into protected
replace the part it is not worth cost to fix and not like to perform properly. As you fix on part it ill likely be a cascade effect of repairing more and more as you fix one part and insulation is damaged and will not be safe to provide power protection or back up.
Aug 22, 2009 | Computers & Internet
Sharp lc-46d64u broken screens
if the screen is broke its not worth the repair
Dec 07, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos 15 LCD TV
Maybe. Unplug the unit and disassembly it. Look for damaged parts or cracked circuit boards. You may also find the buttons you push to turn it on and activate the menu ect. may be damaged. In most cases the board can be repaired but because that would be time consuming and the repair man charges 60 bucks an hour it is usully not cost effective. You might get lucky and find a wire that fell off in the fall. Good luck.
Apr 20, 2008 | Sharp 15" AQUOS LCD Flat-Panel LC15B4US...
Sharp LC-19SB25U 19 in. LCD HDTV Logo
124 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
