Question about RCA Universal Remote Control
Can,t find the right one for my zenith
I tried the codes and got the lights to come on once
  • 11,896 Answers
Www.remotecodelist.com
or
www.tvcodes.com
or
www.remote-codes.com
Posted on Aug 01, 2009
I need the code for my new zenith 50" HDTV so that
501, 520, 639, 652, 672, 675, 693, 747 are the codes.
Programming Your Remote Control
Step 1 The codes are above. Note: You may need to try multiple codes before you find one that is compatible with your specific DISH Network remote.
Step 2 Press and hold the correct Mode button (TV) on your remote control for six seconds until all mode buttons flash once, then release the button.
Step 3 Next, enter the three-digit number that corresponds to the equipment. The light will blink off after each digit is entered and then return to a steady light. For AUX mode ONLY: after entering the remote code, press 0 for a TV, press 1 for a VCR/DVD or press 2 for any other type of device.
Step 4 Press the POUND (#) button. If the code entered is valid for your remote, the mode light will flash three times.
Step 5 To verify that the code works, press the mode button. Try several different functions on the remote to make sure it will properly operate the desired equipment. Keep in mind that some codes may not be compatible with your equipment. If this is the case, please try the other codes listed for that device until you find one that is compatible with your equipment.
Nov 04, 2010 | Zenith Televison & Video
Zenith remote will not work tv, need code
hello here is how you get your remote to work...make sure tv is on
step 1.hold down code search button till you see the red light
step2. let go of code search button and hit TV once light should blink
step3. press and release the power button while pointong a TV u ((may have to press the power button several times)) once the Tv powers off press the enter button once
step4. press tv button and hit power
May 16, 2009 | Zenith DBZN-311 Remote Control
I have an older tv remote that requres a 3 didgit code the tv is a zenith and so is the remote
here is how you retrive the code...make sure tv is on
Step1..press and hold code search button till light comes on then release
Step2..press the TV button once
Step 3.point the remote at TV and press and release the power button while pointing at TV((you may have to keep pressing the power button several times)) once Tv shuts off hit ENTER
Step4..Press TV button on remote and there you go!!
GOOD LUCK!!!
May 09, 2009 | Zenith DBZN-311 Remote Control
Zenith TV
automatic code search. this may take a while to do but it works. hold the directv button and tv power until the red light stays on. while its on press the channel up button (this will search for a code). release and test with the tv power button. if the tv does not turn off, press the channel up button again and test with the tv power. when the tv finally goes off, press the enter/last button (bottom right corner of the remote) to store the code
Aug 31, 2008 | Philips DSR708R DirecTV / TiVo DTV...
Need zenith tv codes
with zenith you can only replace the eprom to reset the unit. once it is locked up.
regards,
daniel
Aug 16, 2008 | Zenith C27A24T 27" TV
I need a code for an older zenith tv 13"
Here is what is called a power scan. It will go through all the codes in the remote and find the right code for your tv.
1)hold down tv button next to sat button in top left corner
2) when all buttons illuminate press 500 into remote
3)press pound sign
4)Hello, please help..
5)hold town tv button again.
6)when all buttons illuminate press big red power button
7)press up arrow once a second until tv shuts off
8)press # pound sign
9)try to turn tv back on w/ big red power button
10)if tv doesnt turn back on try again from step 2 but use down arrow instead
Aug 01, 2008 | DISH Network IR Remote Control
Programming
push the tv button then hold down the code search button till the light becomes solid. point the remote at your tv while it is turned on and push the channel up or down til the cannel changes. once it does push the mute key to save. so u know this works like that on all device and if you pass up the right on from pushing the button too fast you can just push the opposit direction rather than waiting for full circle. also be aware that there are multiple codes for some devices and some work better than others.
Jul 21, 2008 | Zenith DBZN-311 Remote Control
Lost the code book
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC6131
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(For replacement remotes visit www.sparky-uk.com)
Jan 13, 2008 | One For All URC-6131 Remote Control
Zenith zn110
1. hold in "code search" till light stays on
2. press channel up until tv changes channel
3. press enter as soon as channel changes
note: if you pass  the  right code just use channel down to get back to it
Oct 21, 2007 | Zenith ZN110 Remote Control
Televison & Video Logo
240 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
