Question about Dryers
Crosley Dryer Model CEDX463RQ1 no heat
Crosley Dryer Model CEDX463RQ1 at one point had heat but not enough to dry clothes. Now no heat at all. Opened back removed heating elements now WHAT??? Single mother needs Help.
    Brigadier General:
  • 4,090 Answers
Take elements to a dealer and have them checked, unless you have a digital multimeter and can DIY.Otherwise get a replacement element
Posted on Aug 01, 2009
Our Crosley CDE6000 electric dryer would shut off midway through a timed cycle w/ clothes not dried. I removed the door and front , then cleaned out a fairly good amount of lint from trap in door. Rep
sounds like your stat (Tod) for short has gone a Tod is what tell the dryer to heat and when to turn off you will have to replace them OK they are right on top of the heater OK hope this have helped
Oct 22, 2012 | Crosley CDE6000 Electric Dryer
My dryer works but does not heat
ihave a crosley ele. dryer works will not heat take out the drum or take the belt loss and it heats
Apr 08, 2010 | Kenmore Dryers
Crosley Model #CDE22B7V. Clothes dryer only gets
I used to work for a Crosley dealership. The number one problem is gonna be the blower wheel.709b43d.jpggo ahead and pop the top(after unplugging the machine) f11ef2b.jpgGet the front off and then get the drum out. Clean out all the lint. 31001043 is the part number
Apr 01, 2010 | Crosley Dryers
Bosch axxis wtl 5410 dryer takes too long to dry.
You should have a cycling thermostat. this is most likely bad or your dryer vent may be clogged. Something is cutting the heat off before it gets hot enough. Both these cause this problem.
Nov 17, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Dryer runs and tumbles clothes but there is no heat therefore does not dry the clothes
the first thing to check is heating element if it checks good then it will be the thermostat
May 09, 2009 | Crosley CDE6000 Electric Dryer
Electric Dryer, heating el works, exh not blocked, clothes no dry
double check your element temp t-stat and recheck continuity on element. I have known them to work but have shorts in them
Apr 09, 2009 | Crosley CDE6000 Electric Dryer
No heat not drying clothes
for safety reasons it has its own fuse and that may be your issue (new fuse $5)
To be safe i'd also get new thermostat ($15)
Apr 02, 2009 | Crosley Dryers
Crosley heavy duty giant capacity plus auto dry control wont dry
Get putty knife and start by popping the top then take the front off and check the heater mounted on the rear bulkhead.
Jan 05, 2009 | Crosley CDE6000 Electric Dryer
My dryer is taking too many times to dry my clothes!
hello tmivie,
When you say you took the dryer apart and cleaned out all the lint, did you also check the vent system all the way to the outside and at the end where the duct exits your house? If you are getting heat and limited or restrictive air flow, your drying time will be excessive.. There may be other problems such as the blower itself isn't functioning properly to move the air out.. Since your dryer is electric, you can detach the vent line from the dryed and turn it on.. feel the exhaust flow to make sure it is pretty robust then reattach the vent and check for about the same flow at the exit point of your duct system. Let me know if that solves your problem or not so we can look at other ideas..
Regards,
Rick
Dec 01, 2008 | Crosley CDE6000 Electric Dryer
Dryers Logo
171 people viewed this question
Top Dryers Experts
