Question about NEC Computers & Internet
One way audio on NEC ITL 12 button IP Phone at remote site. Main site has IP Phones which are working fine. IP Phone connected to Cisco 3560 24 port poe switch. Switch connected to 2801 router. Point to point T-1 connects remote site to main site. 2801 router at main site is connected to sonic firewall which is connected to Cisco GB switch, which is connected to a cisco 3560 POE switch where the SV8100 system is connected too. IP to IP call, main site can here remote site, remote site can not. TCP is working fine, UDP is not. Firewall is wide open. I do have VLAN setup for main site. Which device do you think is causing the blockage? VLAN, or routing?
This is likely a config problem on the NEC or a hardware/software issue on the NEC. Do a Wireshark capture on the NIC on both ends. Examine the RTP streams and see if they are intact. You may have to decode the stream from UDP to RTP depending on if it is a peer to peer call or if it is going through the 8100. Plenty of documentation on how to do that at Wireshark's website.
Posted on Nov 24, 2009
People can not hear the caller on Cisco 7945G
Could be a bad hook switch on the phone if you plug a different phone in does it work as it should?
May 07, 2014 | Cisco 7945G IP Phone
Tip
Cisco IP softphone - one way audio - fix
Using the Cisco IP soft phone via VPN can sometimes cause audio to drop. To fix this:<br /><br />Right click the Cisco IP Phone and select Preferences...<br />Select the Audio tab<br />Click on the Network button<br />In Audio IP Address select Use this address<br />then set it back to Detect Automatically<br />Click OK and OK again.<br /><br />Give it 5-10 seconds and this will auto reset the audio on the IP phone and will correct the issues with one way audio.<br />
on Mar 08, 2011 | Cisco IP Communicator (SWIPCOMME1CH1)
Why can't I connect my corporate Cisco IP Phone 7941 to a switch? I can connect a switch to Cisco phone switch and connect multiple devices. But the phone will only work when connected directly to the wall...
Connecting a hub or switch to the "PC" port on the back of the phone is not a recommended best practice by Cisco as the IP phone does not support spanning tree protocol.
Sep 28, 2010 | Cisco 7940 IP Phone
Hello, my cisco ip phone does not start
Confirm if the Phone has power supply. and If it's connected to a POE switch confirm that it connects to the Switch port on the phone.
Oct 14, 2009 | Cisco Computers & Internet
Cisco IP phone 7941-- No power on the phone just a blank screen after I installed a headset, I did unplug the headset but is not coming back on.I also tried a new Ethernet cable but no luck. What can I do...
Is the phone connected to a POW (Power Over Ethernet)Cisco Switch? Check the model number of the switch with the Cisco web site www.cisco.com
Have you check whether there is power available on the switch?
enter "show power inline" at the command prompt.
Does the phone work without the head set?
Does the same thing happen when you plug in the head set on another phone?
Jun 18, 2009 | Cisco 7940 IP Phone
7906G Home VOIP installation Problem
Then you need power adapter for Cisco 7960 IP phone ( -40V DC).
Cisco phones work best with Cisco, and sometimes ONLY Cisco switches.
One question which voice gateway you will use for your 7960 VoIP phone calls to go through ?
(AT&T probably supports only their IP Phones with special and usually hidden settings from end user)
Jan 17, 2009 | Cisco 7906G IP Phone
Not able to getting video from Remote far end.
Is the Indian site within the firewall? If so, I would focus on the firewall. Does the US site have a firewall? They may be blocking outbound traffic. If you are connecting but no video, it sounds like UDP traffic is still being blocked somewhere. If you can, you may want to assign public IPs on the units and test outside of the firewall.
Hope this helps..
May 06, 2008 | Polycom VSX 7000 Video Conference
Inline power problem: cisco ip phone 7941G
You need to ensure that each port that has a phone plugged into it is configured with power over ethernet configured switched on.
Mar 20, 2008 | Cisco 7940 IP Phone
My client has Cisco 7940 IP phones and wants assistance with feature programming
This phone can be access through a menu/ setting buttons.
Useful link on how to navigate through the phone:
http://www.cisco.com/warp/public/779/largeent/avvid/products/7940/7940_topic3.htm
I think the main problem is to determine the intergrated router or Call manager configuration
You can also connect on switch and type:show cpd neighbor This will show the physical port connections
Nov 27, 2007 | Cisco 7940 IP Phone
Computers & Internet Logo
555 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Martin Murray
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
