Central air conditioner leaking water somewhere. Water is going through furnace filter (furnace filter is wet) and ductwork and wetting the ceiling below. What should I look for?
  • 398 Answers
Look for a cover that covers the a A coil.take the small 1/4 in screws out and carefully remove the covers or cover if you have access do both sides. my basement has enough room to get to both sides. my house tlr you can only do one side. look for a drain hole blow it out with a air hose or garden hose run a wire if you have to.
Posted on Aug 01, 2009
Ceiling leaks
coil is dirty or frezing up allowing water to leak.
Jul 07, 2013 | Ruud UBHC Air Conditioner
I have a Carrier furnace and noticed water on the floor. I saw it was coming from the filter housing. I pulled out the filter which was wet only on the bottom And noticed the pan/track it sits in had water...
Hello, there might be a crack in the condesate pan. Usually if the leak is concentrated in one area that is the cause. If the water would be leaking all around then a blockage in the drain line would be a problem. Have the drain pan inspected.
Jun 18, 2012 | Heating & Cooling
Leaking water thru the ducts on thru my ceiling
Hello
Your condensate drain pan is clogged.This is at your inside coil or airhandler.There is a drain also attached to the pan that is probably clogged.
Shut the unit down and pull the covers off should be near where the filter goes.Find the drain hole and get the debris out.
You may need to get a new filter also its probably wet too.
Jun 25, 2011 | Heating & Cooling
There is water in the living room floor after the unit runs even for a short time. Where do you locate the stopped up drain. Where would I begin my search?
If your furnace is in the closet or laundry room, the coil that's leaking is either(1) on the top of the furnace if your ductwork is in the ceiling,(2) on the bottom of the furnace if your ductwork is in the floor. The drain that may be stopped up stubs out of the bottom left or right hand corner of the coil box. Sometimes you can flush it out with water but the best way is to find the end of the drain and get a shop vac and stick the shop vac hose on the drain, seal it real good and try pulling the junk out of your drain. Your drain may drain outside somewhere on maybe to a floor drain.
Apr 12, 2011 | Heating & Cooling
Water dripping from furnace while air conditioner is running.
you need to have a drip line that take away the water when the ac is on so the water does not goes into the furnace ,also check for leaky line that could causing water to leak back
Aug 20, 2009 | Heil Sound PR-40 Professional Microphone
Central A/C unit has a leak
The air handler has either a drip pan with exit pipes on the side or a drain pipe and any of which could be clogged.. Find out were the water is supose to exit,, and at that end - tape a strong wet vac to suk out any clog or debris..
Rate well ;o)
Jul 22, 2009 | Heating & Cooling
A/c unit leaking underneath onto floor, puddle in the hall!
from the evaporator coil, the drain maybe clog. clean the unit to fix it.
Jun 11, 2009 | Ruud Central System Air Conditioner
Furnace leaks water on floor when air conditioner is running.
Okay, let do this;
get a wet/dry vaccum set the suction into the drainage and let it **** it.
it should solve your problem.
nguyen@ite.net
Jun 09, 2009 | Intertherm P3RA-048K Air Conditioner
I THINK THIS IS THE RIGHT MODEL. FREEZING UP. NEED TO FIND COILS.
The condenser coil is in the outdoor unit. Turn off the power. Take a garden hose without the nozzle. You want to use gentle pressure. Just simply using your thumb to control the spray. Spray the water up at an angle under the slanted lovers. use a generous amount of water. you should see the dirt coming our. You will have to take the cover off to clean that side of the coil. Be careful so you do not get the electrical controls wet when the door is off. The Evaporator coil is located in the supply air plenum downstream of the airflow. ( the top if its in a basement). You probably will need to open the ductwork.
Good luck.....
May 02, 2009 | Ruud UAKA042 Air Conditioner
Mobile home furnace with central air unit water coming out of fur
You had the condensate from the furnace come loose look for a pvc pipe coming off the furnace it drains the high efficiency heater. I would really check out your hot water heater too.
Nov 25, 2008 | Heating & Cooling
Heating & Cooling Logo
210 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
