Question about Fisher PC-25R20 25" TV
Older Fisher TV PC2525 works fine but the color just went out :-(
Older Fisher TV works fine but the color just went out, I switched tv's and the other one works fine, so it's not a connection problem. Does this tv have a inexpensive replaceable tube, or something I can replace on my own?
Any help would be much appreciated.
Thanks Darren
  • darewood7 Aug 01, 2009
    WOW, talk about FAST!!!!
    Awesome, I'll check it out and get back to you.
    Thanks Again
    Darren
  • 269 Answers
Try to check if their is any cold solder in the crt socket or one of it's rgb drive transistor. or any loose parts on the main board.
Posted on Aug 01, 2009
Colors are bleeding into each other
Go into your menu on the TV and set the color in the contrast and brightness and sharpness of the picture!
Feb 25, 2013 | Fisher PC-27S80 27" TV
Wd65738 flickering
I had a TV do that about a year ago, the repair man said it was the color wheel inside the tv. I changed the bulb to see if he was BS'ng me and eventually got the manufacturer to send a color wheel and I change it myself, was very easy...TV works fine ever since. Hope this helps
Jul 10, 2012 | Mitsubishi WD-65738 DLP TV
XBOX NOW PLAYS IN BLACK AND WHITE WITH OLDER TV DID WORK FINE AND DOES ON NEW HDTV ALL CABLES GOOD NOT SURE WHAT TO DO TO GET COLOR BACK
There is a switch that changes the video cable from SD( for use with older TV's without high definition connectivity) to HD (used for newer HD TV's with high definition.
If your older television is using a composite (yellow) connection for video, make sure the switch is in the SD position and NOT hd.
Mar 02, 2011 | Microsoft Xbox 360 Console
Just got dish a week ago everything fine. Yesterday the power went off and now the main TV has arch screen and three different colors on everything on the TV and TV 2's screen is just blue
wvpotts0,
Are you still having problems with your receiver? Depending on the type TV you have, TV 1, on an older TV will use channel 3 of 4. A newer TV will have an input setting. If you have the TV remote, press either the "input", "source", or "tv/video" button to cycle through the input settings till you find a picture. Make sure the green, blue, and amber lights are lit on the receiver. TV 2 should be on channel 60 or 73. I hope this helps.
Ray Calo
DISH Network
Aug 21, 2010 | DISH Network ViP722 DTV Receiver /...
I have a aiko set top box receiver, installed, we have pictiue, sound but no colour only black and white, what wrong?
Hiya Margy,
I know your query was 6 months ago,but I had a similar problem with connecting an Aiko SD set top box to our second older tv set & after 3 months only recently found the solution!
Our problem? When connected the tv picture went green! Nobody,including Tandy staff,knew what to do! (We also have an Aiko STB connected to our newer tv and it worked fine from day one.)
Anyway,it took 3 months but I finally worked it out.
Our problem was settings on the TV,NOT the STB.
Go to your TV's COLOR settings,pick a setting called 'COLOR SYSTEM' and change from 'ntsc' or 'pal'(depending on what country you're in) to AUTO.
It isn't enough to change the tv system on the STB's SETUP menu,or to change it on the TV's SYSTEM settings,you have to change it in the TV's COLOUR settings as well. Change colour system to 'auto' and see if that helps.(And of course,change all system settings on both the tv & the STB to AUTO or the right system for your country if you haven't done so) Hope this helps! Good luck!
Jul 30, 2009 | Televison & Video
Old TV can't scan for cable channels
it depends on how old the set is. some of the older sets would only go as hi as channel 120. some really old sets only went to 36 on cable. how high do the numbers go?
Jan 05, 2009 | Televison & Video
Cant get convergence board settings
I suspect that the convergence board may be defective. If the convergence was okay before and then went out, this is a fault and not an adjustment! Adjusting only compounds the fault.
Look up the Sanyo home page on the net, and get their tech support. You can order a new convergence board, and the service manual to start.
It may be more practical for you to let their authorized service rep service the set for you. It is possible that you start buying the parts, and end up needing to troubleshoot for more faults. You will need the proper tools and training to get involved in troubleshooting your set.
Jerry G.
May 19, 2008 | Fisher PC-27S80 27" TV
Colors out of Whack on HD input 4 only
May need higher quality component HD cables? Tried switching Blue on Red? Just some thoughts.
May 02, 2007 | Philips 60PP9202 60" Rear Projection...
Fisher PC-25R20 25" TV Logo
139 people viewed this question
Top Fisher Televison & Video Experts
matt martin
matt martin
Mike
Are you a Fisher Televison and Video Expert? Answer questions, earn points and help others
