Question about Maytag Dryers
DRYER RUNS IN OFF POSITION BUT NOT ON CYCLE POSITION
    President:
  • 704 Answers
It could be that the knob came off and someone pushed it back on in the wrong location. Knobs are keyed so they should only go on one way, but since most knobs are plastic and can get messed up fairly easily, you might want to pull the knob off and see if that is the issue.
You might need to get a new knob if yours has gotten a broken socket where it slips onto the control shaft.
Hope this helps. Best Regards!
Posted on Aug 01, 2009
  • Mark
    Mark Aug 03, 2009
    It is also possible that the timer mechanism is faulty and the timer motor is no longer working properly. So when in the last position, right before the "off" position, the dryer will operate. You can try some of the other non-timed settings (if your's has sensor drying option) to see if the dryer runs. If it doesn't work in any other selectable drying cycle, it is most likely that the timer control is bad and needs to be replaced. Hope this helps! Best Regards!
MY DRYER SERIAL NUMBER X073808040 STOPS AFTER 20 MINUTES
Kenmore Dryer - heats & runs but stops mid-cycle - Ask Me Help Desk
https://www.askmehelpdesk.com/.../kenmore-dryer-heats-runs-but-stops-...
Kenmore Dryer - heats & runs but stops mid-cycle. Asked Aug 30, 2006, 12:25 PM - 10 Answers .... Unfortunately it shuts off after a few minutes, I'll estimate about 5.After waiting about 30 minutes, ... New Member. Jun 16, 2010, 09:20 AM ...
Sep 15, 2015 | Dryers
The dryer will not heat up
Instructions
    • 1 Check the cycle selector control to make sure a heating cycle has been selected. The selector should be in an "Off" position when not in use, but it should be turned to a drying cycle when in use. On some models, make sure you are not accidentally running the dryer on the "Air" cycle, which does not use heat.
    • 2 Check the gas supply valve to make sure it is open if your dryer is a gas dryer. If it is not open, just lift the valve open.
    • 3 Look at your house's main breaker box to determine whether a circuit breaker is tripped. The electric dryer runs on 220-240 volts and has a double breaker. If the breaker for the heating element is tripped, the drum may tumble the clothes without heat. Turn the dryer's breakers to off, then back on; test whether the dryer will produce heat.
    • 4 Consult a technician if troubleshooting does not resolve the problem.
Jan 15, 2013 | Kenmore Dryers
I have whrilpool dryer and I am getting no heat, dryer runs but no heat. Sensor and thermo fuse good. Timer keeps clicking if dryer is off but knob is in some cycle position not off position. Open door and...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 12, 2011 | Dryers
My dryer continues to run, it won't shut off. When the dryer door is shut it continues to run. When the timer is in the ''OFF'' position the timer runs through to the next cycle.
Hellow, If your dryer continues to run when in the off position you nee a new timer dial switch. I hope this helped you out. It would be greatly appreciated if you coud rate my answer. Thanks Mike-
Nov 03, 2009 | Dryers
Dryer runs but does not get hot
if timer runs thru cycles then it is the element sounds like timer
Oct 30, 2009 | Whirlpool LER8648P Electric Dryer
Gas Dryer runs non-stop.
Repairing a dryer that won't shut off many seem daunting, but fixing your own appliance is actually pretty easy. The toughest part is figuring out what dryer part is the problem. We've created a list of the most common parts that can cause a dryer to not shut off. Use this list to diagnose the problem you're having and then enter your model number into the search box to find the right part for you. You'll also be able to access even more detailed repair help and tips about your dryer.https://www.youtube.com/watch?v=rXs6cL_prAQ
Mar 16, 2017 | Whirlpool Dryers
Kenmore 80 series dryer stoping after running for 10 to 15 minute
Start any cycle. Dryer runs for 10 to 15 minutes, then stops before cycle is complete. Start again, stops again in 10 to 15 minutes.
Nov 11, 2008 | Kenmore 63942 Dryer
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
