Home | Kenmore | 54351 Dehumidifier | 543515 humidifier run...
Kenmore 54351 Dehumidifier
Problem for Kenmore 54351 Dehumidifier
543515 humidifier runs but doesn't collect any water.
By conniebreed on Aug 01, 2009
It's never worked. I brought it back to be repaired. Supposedly was fixed but still didn't work.
Comments:
Aug 01, 2009
- How do I do that?
Aug 01, 2009
- No, but it's a basement. It's very humid and we've had lots of rain so it's really damp there. What do I check on the humidifier? There's nothing on the outside.
Solution #1
posted on Aug 01, 2009
Not Rated)
rhozel2010
Rank: Wiz
Rating: 83%, 111 votes
try checking the setting of your humidifier, if the actual humidity level matches, what is set on your unit.
Comments:
Aug 01, 2009
- do you have a hygrometer to check the humidity of your room
Was this helpful?
Yes
No
Popular Solutions for Kenmore 54351 Dehumidifier
Questions and Unsolved Problems for Kenmore 54351 Dehumidifier
Do you recommend Kenmore 54351 Dehumidifier?
Answer
Answer
Dehumidifier fan runs lights turn on but only get about a cup of water after all day running.... (More)
Answer
Mine has stopped running because it has reset itself to 01% from 50%. But you can't manually change... (More)
Answer
i have a kenmore and it frost over all the time when it running.
Answer
Kenmore dehumidifier model 580-54351400- replaced fan motor but overheaqts and does not collect... (More)
Answer
ran fine for a couple of weeks. emptied bucket several times. Then would not start for several days.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kenmore 54351 Dehumidifier:
Top Dehumidifier Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dehumidifier Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
