Question about Philco (R) 841.205 CD Shelf System
Turn tABLE won't atart
The turn table will not turn. My husband said the belts are on> I turn it to Phono and turn the sound on and move the arm till it clicks and nothing?
How do I put the belt back on?
Posted on Jan 02, 2011
Crosley turn table is not spinning. Tried replacing belt and moving cue lever to right then left. Think it might be the arm or cue lever. Does anyone have an idea what the problem is or a solution?
Since it is new, you should probably return for refund or exchange.
My guess would be it is the micro switch controlled by the arm.
Make sure the power is turned on and the unit's function selection is set on PHONO and then gently move the tone arm to the right until you hear a "click". Remove any cassettes that might be in the cassette player. Lift the tone arm and carry it over to the beginning of the record.
TroubleShooting
Jan 27, 2016 | Crosley CR49 Portable Traveler 3-Speed...
Using turntable (audio technica at-lp 120) with built in pre amp the sound is distorted and broken up. the turntable requests phono turned on to use. Does the receiver have a pre amp or boost signal...
A turn table produces sound voltage in the millivolt range. If you have it connected to a receiver that has a phono input and the turn table is pre-amplified, you are overdriving the receiver and it is clipping the audio and making it sound bad.
Jan 17, 2015 | Yamaha RX-V592 5.1 Channels Receiver
How do I turn my turn table on. POWER button is on. What other button do I push. I have phono, mono/st, cd, tape, tuner??
Phono button is turntable selector. May be the turntable switches on when you move the arm to the edge of the record.
Dec 17, 2014 | RCA Spirit Of St. Louis Radio/Cassette/CD...
HELP: Stopped spinning
It's likely the belt has slipped of and probably needs replacing. You can do this yourself. It will be found under the turntable matt. The trick though is fitting it back on. But you might find the instructions on-line (enter the model number into google search). Some people have even put YouTube video's on how to replace the belt on popular turntables.
Jun 11, 2014 | Crosley CR74 Turntable
Turn table arm will not move freely, table wont turn, cueing light bleaking
I would need more information, starting with make and model number. For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 25, 2013 | Audio Players & Recorders
I HAVE PHILIPS AMP FR931 AND I HAVE A HITACHI HT4 TURN TABLE THAT PRODUCES A LOW VOLUME SOUND WHEN THEY ARE CONNECTED.
I can't find anything about the HT4 but it should be connected to PHONO (nowhere else) if it has a moving magnet cartridge and you should set the PHONO/LINE selector to PHONO.
http://www.p4c.philips.com/files/f/fr931_p00/fr931_p00_dfu_eng.pdf
Mar 26, 2011 | Philips FR931 Receiver
It doesn't work. I have followed the instructions though i couldn't find the EG switch but the table doesn't turn when its plugged in turned on and started.
hi,
check whether you have inserted the belt or not. in new turn tables you hvave to set the belt in proper position before starting use. u have to make the belt engaged with the motor pulley.
I have added here a video which demonstrate the installing of belt in a turn table.
In your turntable you can see the belt under the plater when u remove the plater.
remember one thing after installation of belt before plugging it mains , do the following
1. lock the arm in the arm rest
2. rotate the plater 10 times with you finger (for resetting the start position
Then connect the power release the arm lock insert a record press start
If you need any further assistance from me , feel free to contact me through fixya
ok
Jan 17, 2011 | Sony PS-LX250H Turntable
I have a new Yamaha RX-V365 receiver and an older technics turntable, regardless of input setup I cannot get any volume from the turntable, yet all other inputs like CD, Tuner are fine....amp issues in...
Some turn tables do not have a built in amp, especially the older ones, the sound goes from the needle to the output. If the amp your are using does not have a designated phono, turn table, input it may not have the turn table pre-amp built in. Some turn tables have to be grounded to the amp to work properly.
Aug 30, 2009 | Teac DC-D2800 Shelf System
Sherwood RX 4105 no input for a turn table
Check for a line level switch on the turn table, it may be under the turn table itself lift the rubber mat and spin the table by hand, it may not have one or it could be on the back.
You can buy a phono amp that will boost the phono signal. Check at Radio Shack or google it.
Jan 31, 2009 | Sherwood RX-4105 Receiver
Hoe do operate the turn table
Lift the arm off the stand and manually move it to the center of the player. You should hear a click and the turntable will begin spinning. To turn it off move the arm to the outside until you hear a click.
Nov 13, 2007 | Philco (R) 841.205 CD Shelf System
Philco (R) 841.205 CD Shelf System Logo
186 people viewed this question
Top Philco Audio Players & Recorders Experts
 Grubhead
Grubhead
jason
Steven Wander
Steven Wander
Are you a Philco Audio Player and Recorder Expert? Answer questions, earn points and help others
