Question about Garden
Simple diagram showing gas lines connections
Where can I get a simple diagram showing how gas lines are connected in poulan 2150?
  • 37 Answers
    President:
  • 2,220 Answers
This is Poulan.com
Select "POULAN-WEED-EATER" then enter your model number.
You may have to experiment a little but your IPL is there. It will aid in determining how your fuel lines run.
http://www.ordertree.com/cms/illustrated-parts-list/9788.html
Lou
Posted on Sep 05, 2009
  • 1 more comment
  • dontbother10
    dontbother10 Sep 15, 2009
    This is as good as it gets:
    This is Poulan.com
    http://www.ordertree.com/cms/illustrated...
    It can be enlarged. If this detail isn't enough to anwswer your question contact Poulan @ 1 (800) 554-6723. They will recommend an authorized repair facility or try your friendly neighborhood chainsaw seller/mechanic.
  • dontbother10
    dontbother10 Sep 16, 2009
    How To Contact Poulan
    At Ordertree.com we are committed to providing you with outstanding customer service. We take all of your requests seriously. You can contact us in the following manners:
    E-Mail - Contact us at service@ordertree.com. We will respond to your e-mail within one business day*.
    Telephone - You can talk with one of our Customer Service Representatives by calling us toll free at 1-877-500-7499. Our Call Center is open 8:00 am - 6:00 pm EST Monday through Friday.
    Handheld (Chainsaws, Trimmers, Blowers, Edgers)
    1 (800) 554 6723
  • dontbother10
    Contact Poulan… They will tell you there is no other illustration!!!
  • 157 Answers
Go to the poulan chainsaw
Posted on Sep 18, 2009
Wich fuel line goes were
Find the one that supplies fuel to the carb. That line connects closest to the middle of the carb.
Mar 03, 2015 | Poulan Garden
Poulan 2150 fuel line diagram
you can start by adjusting the air fuel intake by turning the adjustment screws in all the way then out 3 full turns then do half turn adjustments until its right
Jul 23, 2014 | Poulan 2150 Chainsaws
Diagram for fuel line routing for a poulan 2150 chainsaw?
The 2150 has a remote primer, so there will be three pipes, the pipe coming from the fuel tank with the fuel filter on the end is the main fuel tube, this fits to the connection on the carb nearest to the pump cover on the carb ( alluminium cover held with a single screw ) the other connection on the carb has a pipe to the shorter of the two connections on the back of the primer ( suction side ) the longer connection on the back of the primer ( pressure side ) has a pipe back to the fuel tank, so the primer pulls fuel from the tank, into the bulb, and dumps it back to the tank, it does not push fuel into the carb, this way you can depress the bulb as many times as you like without flooding the engine.
Jul 05, 2012 | Poulan Pro Chain Saw 46cc 20"
There are 3 fuel lines on my Poulan 2150, 2 - 1/8"...
The 'vent looking device' should be the fuel filter--remove it and make sure it is not plugged. The other end of that line should go to the carburetor inlet port near the top. When you get the line connected, pump the primer several times (tank is filled with fuel mix and the small line returning to the tank is pulled loose from the primer port) to see if it pumps fuel through the carburetor into the primer bulb. If it does not, swap the line from the carburetor to the other primer port and retry pumping again. If fuel fills the bulb, then plug the line from the tank to the vacated port on the primer. This will pump excess fuel back into the tank. Hope this helps!
May 17, 2010 | Garden
I have a Poulan 2150 2.1 chainsaw. I have no manuals. All of the fuel lines are dry-rotted and need to be replaced. How can I do this myself?
An IPL containing fuel system parts with very little detail can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
“2150 Gas Saw Type #” (the dash number from your serial number). May also be Predator or Woodsman.
The fuel system parts can be found on the "Engine Assembly" and "Handle & External Assembly" illustrations.
Take good notes and a some digital photos with as much undisturbed detail of hoses and routing as possible.
Try your local chainsaw seller/mechanic for fuel hose. Take a short length sample, there may be different size hoses. All need be fuel resistant.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs will help with reassembly. HTH
Lou
Oct 30, 2009 | Poulan Garden
I NEED A DIAGRAM OF THE FUEL LINE TO THE CARBURETOR FOR A POULAN PREDATOR SERIAL#03296D300154-6 MODEL#2150PR
What you request doesn't exist. An IPL containing fuel system parts with very little detail can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/PWE/2150-Predator-Gas-Saw-Type-6/75.2150-Predator-Gas-Saw-Type-6.1.59.1.html
e17de8d.gif Fuel Line Replacement by SmallEng.com
  • If the saw is equipped with a primer, the output line from the carburetor connects to the suction side of the primer bulb (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as it inflates).
HTH
Lou
The serial number you provided allowed me to find the correct IPL for your saw Type 6 (-6 from serial number). Thank You.
If you feel Poulan should provide better illustrations please contact them here: http://www.poulanpro.com/node4033.aspx There is a toll free telephone at the bottom of the page.
If you contact them and aren't satisfied with their reply, please elevate your concern to their parent company (Husqvarna) here:
http://www.husqvarna.com/us/homeowner/support/customer-support/
Oct 29, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I need the fuel line routing or diagram for a Poulan Predator 2150 LE. I have parts list but it does not depict the fuel detail I need.
Jimmy there are no Poulan drawings with fuel system detail worth the ink it takes to print them, but that is all there is.
Routing runs from fuel tank to carburetor, (if equipped) through carburetor to primer bulb (once compressed bulb draws fuel as it returns to normal) , bulb (as it is compressed) returns displaced to fuel tank. HTH
Lou
Oct 22, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Need a diagram of the fuel lines on a poulan 2150. what lines go where?
You can View a Diagram of the Chainsaw here http://hayward.arinet.com/scripts/EmpartISAPI.dll?MF&app=ASP⟨=EN&TF=Mainfram...
Select the Catalog Poulan/Weed Eater. Then Select Poulan. Then Select Gas. Then Select Saw. Then Scroll Down to your Model Saw i.e 2150.
Regards
Marc
Apr 17, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Garden Logo
1,306 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
