Question about Estate EED4300TQ Electric Dryer
Dryer wouldnt turn off now wont turn on
Last night i turned my dryer on and when i get up this morning it is still running. I opened the door to turn it off and then went to work. Now this evening it wont turn on at all
3 Suggested Answers
ftw1952
  • 10319 Answers
SOURCE: Estate TGDS680EQ3 gas dryer blows cold
The timer is stripped inside and needs to be replaced. The cogged teeth are made of plastic and a tooth or two has broken off keeping the timer from moving while running
Posted on Jul 16, 2010
heatman101
  • 43501 Answers
SOURCE: Whirlpool Estate Eelctric Dryer Serial
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Posted on Aug 14, 2011
Dryer wouldnt turn on its saying door is open
most of the time. its the door switch that causes this. if door is closed and it does not start, its the door switch. try this! unplug power, remove the door switch, hook the wires from switch together. this will make a complete curcuit.put black tape on wires so it wont short out. plug back in. it should work, if it runs ok door switch is bad. good-day !
Mar 29, 2012 | Frigidaire Dryers
Dryer drum is not rotating or rotating VERY slowly. Opened the top last night and it worked just fine, then this morning it was back to a slow turn or no turn.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Dec 22, 2010 | LG DLE5977 Electric Dryer
Maytag dryer used last night tried to turn on this morning wouldnt start vent not clogged, checked power it is receiving power just wont start any clue what could be wrong
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 16, 2010 | Maytag PYE2300AY Electric Dryer
Last night I dried multiple loads of laundry . . . the dryer worked fine. This morning when I pressed the button to turn it on nothing happened. The control panel is completely blank, as if the dryer is...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 24, 2010 | Kenmore Elite HE4 Electric Dryer
My mp3 wont turn on unless its connected to charger, i charged it all night last night and this morning i took it to school and it wouldnt turn on. it only turns on when i plug it into charger right when i...
Reset the player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
Mar 17, 2010 | SanDisk Sansa Clip MP3 Player
Dryer will not turn on.
Could be start switch but unlikely. Check these things first...
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
Jun 04, 2009 | Dryers
Kenmore HE2 Dryer makes three beeps but wont start
What happens is that the door switch gets turned inside. I just took mine apart because of the same problems listed. The switch has a tab inside that has to make contact with the internal switch. I pulled mine apart and turned it so it made contact...put it back together and it works fine now. After doing all that it seems like you could turn the swith from the outside a quarter turn with a pair of pliers and accomplish the same thing.
Mar 22, 2008 | Kenmore Elite HE4 Electric Dryer
Frigidaire Dryer hums wont turn on
motor-overheated. you might make sure the vent is clean.
Jan 05, 2008 | Dryers
Estate EED4300TQ Electric Dryer Logo
29 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
