SOURCE: Carrier Gas Furnace runs fine randomly stops blowing LEDs flash
That blinking light may be the diagnostic light. Count the blinks next time it fails. Carrier units will have two different blinks depicting the error code such as one blink followed by a pause than 3 blinks giving you an error code of 13. Then look at the wiring diagram, it will have an error code chart telling you where to start with your diagnosis. You already know that if you remove the cover it erases the error code, so look thru the small window first.
SOURCE: inducer motor runs cont. and
Hi, Here is a tip that wrote about how to buy heating and air conditioning parts online.
The relay on the circuit board for the inducer is stuck closed....
The reason you have to turn down the t-stat or recycle the power is that for the system to refire the pressure switch must open and then close again, which it does in either of those cases....
To fix the problem you will need to repplace the circuit board....
Check with your dealer for a new board or you can buy it on the internet...
How to find Air Conditioning, Heating and Furnace parts online.
heatman101
SOURCE: Need a quick fix for a Carrier that won't heat. Ac works, fan works, auto for heat doesn't.
Filter has nothing to do with anything.
What you can do is take wire out from thermostat and put W and R together and if heat comes on then thermostat is bad .
Testimonial: "Thanks, appreciate your reply! Thermostat seems to be stuck around 70 degrees but that is not actual temperature, what does that mean? Is there a way to get it working temporarily? Below freezing, need heat! Thanks."
