Question about HP TouchSmart IQ770 PC Desktop
Will not turn on but has power light on - HP TouchSmart IQ770 PC Desktop
  • Chris  Morse
    Chris Morse May 11, 2010
    Well, first off, I am going to ask for you to be more specific. When did this start happening.. what was the last thing you did before this happened. Second, I'm going to ask what happens with your monitor. Flickering? power light? does it say no signal? Anything? If not, make sure the cable is plugged in completely from your monitor to your computers display adapter. If it is, the video adapter may not be functioning properly. Is there another monitor you can try with the computer.. another computer you can try with that monitor? Try these things and rule them out as possibilities, if there is still a problem.. please let me know.. if this isolates the problem please let me know as well :)
  • 596 Answers
When is the last time it worked? What other problems have you had? Thanks
Posted on Aug 01, 2009
Won't turn. on red standby light changes to on but then goes right back red
TV won't turn on - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have the Samsung FP-T5084 50" Plasma tv. I went to turn it on the other day, and it wouldn't turn on. No clicking. No red power indicator light. Nothing. Samsung TV LN52A650A1FXZA won't turn on, keeps clicking
Jun 11, 2015
Samsung TV won't turn on
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
More results from www.cnet.com
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old. ... I have an old type sony tv with the big back and the red power light keeps flashing and ...
How do you fix a television that won't turn on? - Ask.com
www.ask.com > Technology > Television & Video
Jan 03, 2016 | Televison & Video
The power light wont turn off
Does the PC turn off at all or just not the light. If it's just the power light on the tower, Check the connections between the tower to the motherboard and make sure they didn't get moved when the power supply got replaced.
Apr 18, 2014 | Computers & Internet
Adjust brake light switch
The brake light wire leaves the brake switch and goes into the turn signal switch. They often share the same wire: the rear turn signals and the brake lights. When turning, that side is routed through the turn flasher, but you get a steady brake light on the other side.
So you have power to the brake switch. Pull apart the connector for the turn signal switch, and see if you have power in on the brake wire (with brake depressed of course) going into the turn switch. If you have power in, plug the connector together, and see if you can backprobe the connector with test light or voltmeter, looking for power out to the rear brake lights. If power in, but no power out, the turn switch is probably bad.
Dec 31, 2013 | Ford E-150 Cars & Trucks
When I turn power on my acer aspire netbook the screen is black. The only light that lights up is the battery light. Do you know what is the problem and how can I fix it?
Have you tried turning it on using your adapter? If there is still no power light, try removing the power jack in the laptop and the power cable in the adapter and re-insert it both then plug it then test it again. If there is still no power light, try bending slowly the power jack cable in the laptop while inserted and slowly bend and move until you reach the power adapter. Observe the power light while bending the cable. If the light turns on while bending, the wire/s on the cable might be cut where you bend and see the power light turning on. If there's still no power light, your power adapter or the laptops power supply might be defective.
Sep 25, 2011 | Acer Aspire One Netbook 8.9" Notebook
My linksys wrt160n wireless router light is blinking
Welcome to FixYa
Indication of Router Lights:
  • Power light blinks. If LAN or WAN cable is plugged in, their respective lights will flash on activity.
  • Power light turns off for several seconds.
  • All lights, except power light, turn on and then off.
  • Power light blinks slowly, then faster, and WLAN light will turn on.
  • Once Power light and WLAN light are on solid, the router is fully rebooted.
A working router should show solid green power light. upgrade the firmware of the router.
If this Helped you-Rate me..Thanks for Using FixYa
Jun 30, 2010 | Linksys WRT160N Wireless Router
Epson r290 no power after i turn off because 2 red light appears
while printing the two red lights turn on and stop printing,i press the power to off.. i turn it on so many times but still no power.. in the morning, i press the power to on and the 2 red lights appears again, then i turn it off, ..i try to turn it on many times but still no power. help me pls...
Aug 07, 2009 | Epson Stylus R290 InkJet Printer
Power Light Is Red, Internet Light Is Green, Other Lights Off
Check cable connections.
Try unplugging router from power for five minutes.
If that does not work call Internet Service provider to check if there is a problem with their server.
Apr 10, 2009 | Actiontec GT704WG Wireless Router...
Samsung flat screen wont turn on red light just flashes..
wont turn on red light just flashes?
On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
Jul 20, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
HP TouchSmart IQ770 PC Desktop Logo
93 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
