Question about GE Profile PDW8400J Built-in Dishwasher
I keep getting a washer arm blocked error.
I have a GE 2800 dishwasher (old). It works but now I keep getting a washer arm blocked error but the arm is not blocked. Is this just a case of simple deterioration -how can this be addressed?
I have had the same problem for a couple of years. When it tops without opening the door just press the start button and it will resume and finish the load.
Posted on Sep 17, 2009
Dish washer is about four yrs old and is leaving dried particles all over dishes and glasses I have tried cleaning solutions and it still continues.
Either there is some error with the pump or the switching valve that switch the wahing water between the upper and the lower rotating water ejecting dishwasher arm. There is no longer water enough in the dishwasher to turn on both dishwasher arms at the same time. Had the same problem with a ASKO DW20.3. At the moment the ASKO is disassambled to change the motor driven valve. Kind regards. Henning
Mar 05, 2011 | GE Nautilus 24" Built-in Dishwasher
GE Dish Washer GSD 2800 DO3 runs a partial cycle...(even empty) and then beep and gives a message on control panel "washer arm blocked". Even ran without dish rack in washer still got the...
the rotating arm has a magnet in it to let the controls know if it is turning. Yours is not turning so
  • check the jets for blockages... you might have to remove the arm to clean them properly
  • make sure there in nothing stopping the arm from turning...spin the arm manually to see if it rotates freely.
  • knives etc sticking upward can stop the arms from rotating on the top rack
  • if you run without the rack the arm will obviously be not telling the electronic it is not blocked because it is not there. the rack must be in the machine with the magnet and the magnet passing correct messages.
  • If there is really no blockage then there is a elect fault that need to be sorted professionally.
  • PS have you taken the arm off anf squirted a hose up the inlet to see if water comes out all of the jets????
Mar 01, 2011 | Dishwashers
I have a GE Profile, GSD4930X73WW, dishwasher. The upper wash arm is not spraying well at all. I checked the water line from the pump to the upper arm and it's fine. I cleared the filters and cleaned...
Most likely the cause would be a blocked screen entering the pump. There is a small "shredder" spring immediately in front of it which shreds soft food waste. Many times plastic wrap gets into the unit and will block the round holes in that screen, thereby reducing water supply to the pump. Low supply means loss of pressure and that means no water to top wash arm. Access is done by removing the large white coarse filter, located behind the lower wash arm, lifting the oval plastic screen just below that and reaching in to the bottom reservoir. BE CAREFUL OF GLASS AND OTHER SHARPS! Gently clean out that area and feel for the final round screen that leads to the pump. This is the one that gets blocked with debris. Some can be "scrubbed" with an old toothbrush, but if there is plastic wrap in it, you will have to scrape it with fingernails and pick it out. Another, more time consuming way, is to remove the entire motor pump assembly and dismantle it.
Good luck. Let us know if it helped.
Apr 13, 2017 | GE Dishwashers
My deceased parents have a GE dishwasher (don't know the model number - can't find it on the machine and can't find the paper work) that stops working shortly you start it and displays a message on the...
Could be false sensor input, could be that the arm is not turning, I am not sure how old your machine is, but age could play a part if the arm is "in fact", not turning. If you are not mechanically inclined, I would suggest that a qualified repairman check it out. Assuming that it worked ok..Prior to the several months of inactivity, it is hopefully a simple fix. Although I have repaired many a dishwasher, to give an accurate diagnosis on a machine that has not operated in some time, and without knowledge of what it was doing prior, and examining this particular problem...it is hit and miss. I would advise that you examine the wash arm, make sure that it turns freely, If you cannot find an obvious obstruction, or a glitch in its rotation...then you should have it checked out. Could be many things causing this condition...up to and including the water pressure and supply lines...Good Luck! Ihope you find this to be helpful!
Dec 31, 2009 | Dishwashers
Noise when spraying
The wash arm(spray arm) is not a tight fitting item,as for the noise the when spraying have a look at the spray arms the are a few holes on each side and top and bottom of each arm,you will need to remove the arms of possible they normally have a quik release system where you push two small fingers together and the arm releases,then inspect these holes and you will probebly find that some are blocked this cuases a uneven flow of water and thus makes the arm rotate un even and make a noise if you find there is food of sorts in these holes remove and put the arms back and that should take care of the increased noise.
Feb 05, 2009 | GE 24 in. GSD2030Z Built-in Dishwasher
Rotory spray arm
The most likely cause is that some of the holes in the spray arm are blocked. Candy wrappers, tooth picks, seeds, nut shells or other food objects can get into the spray arm and block up the holes. If you can't get them cleaned out you may have to replace the spray arm.
Nov 08, 2008 | GE Tritonr XL GSD6260JCC Dishwasher
GE Triton arms don't spin
Peace,
Cut off the power at the breaker for 5 minutes and then turn it on and see if the system resets!
How old is the machine?
Other wise you need hands on service! And a new machine will pay for itself in only a few years!
Bless You!
Sep 06, 2008 | GE 24 in. GSD6660GSS Built-in Dishwasher
GE GLD6500LOOBB
Open the door quikley while the washer is running. Is the spray arm spraying up and rotating. If not you may have a bad seal under the spray arm or a cracked one.
May 08, 2007 | GE 24 in. GLD6500L Built-in Dishwasher
GE Profile PDW8400J Built-in Dishwasher Logo
330 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
