Question about John Deere Garden
Noise, idler pully rubbing against middle blade
John deere 261 grooming mower: noise, idler pully rubbing against middle blade pully, this don't look right? I can't see that anything is bent, but there should be clearance there I would think. bought used, don't have a manual. have been using 3 yrs now. first time I have taken top safety belt guard off and saw pulleys touching.
  • Anonymous Mar 25, 2014
    mower vibrates
    driveshafter looks good.
    could it be one of the three blades or pullies?
    Genius:
  • 1,114 Answers
Unless there is some other means of placing tension on the deck belt, I would say that the idler pulley does. If the idler pulley is on a pivot arm, there is a spring that typically is attached to the pivot arm, near the pulley, that attaches to a post or some other part of the deck, that creates the tension on the belt. Check the belt for proper tension.
Posted on Aug 01, 2009
Why does one blade spin after mower is stopped on my John Deere LA135?
check your blade brake for that blade,supposed to rub against top blade pulley when blades are disengaged,if its a manual engage vs electric clutch
Jul 30, 2014 | John Deere Garden
I have a John Deere LA105 Riding Mower and when I mow it leaves a strip of grass in the middle. Left and right sides are cutting fine. I have taken the blades off and shaarpened them and have leveled...
jack the tractor (using a tractor jack) or remove the deck, measure the blade tips against each other where they meet in the center of the deck and see if they are the same tip to tip. Bearing wear, a bent deck or blade can make them cut at different heights in the center.
Sep 25, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
John deere l118 belt adjustment
There are two things to check first. First is that you have the right belt on there and it is not worn. Second would be that all the springs are on the proper tensioning pulleys under the deck. After that then you need to look for an adjustable pulley that is manually tightened and held in place by a bolt. That will be your idler. You will also want to check the track of the belt to make sure nothing is bent.
May 15, 2012 | John Deere Garden
I HAVE A JOHN DEERE 135 RUNS WELL ..BUT WHEN THE BLADE IS ENGAGED IT STOPS THE MOWER.. WHAT IS THE PROBLEM ?
Sorry to say it but someone probably hit something and the blade, pulley or deck is bent. You will need to measure the blade on one side and see if the measurement is the same one the other side of the mower but the same side of the blade. if the measurement is not the same or wont move check to see if the blade is against the deck if it is and the blades are not bent your pulley and shaft could be bent and you can measure both right and left sides of the pulley on top not blades side of the deck, if the measurement is different it is bent and you will have to take it to a service repair shop . You would have to check with the service or warranty company. If I can help further please contact me. Thank you.
Jul 01, 2011 | Garden
42 inch jd la115, hit stump in yard, changed blade cause I thought I bent the baldes still cuts uneven. Could the shaft be bent or broken? It appears to be cutting properly on the right side but the left...
try pushing the blade up into the deck,,,if there is any lift in it there is the fault,,the top nut has come off the blabe drive pully and let the drive shaft drop a little this will lower the cutting blade,,,fix it before the blade falls right out
Aug 15, 2010 | John Deere Garden
I have a john deere 4110 tractor with a 261 grooming mower attachment. Yesterday while cutting the grass the mower just stopping cutting. What are some possible solutions. thx
Hello. These mowers have a soft metal pin which breaks rather than break an expensive part. Check to see if you have broken a pin in the power takeoff or in the mower. J.
Jun 03, 2010 | John Deere 420,1020,2010,2020,2510,2520...
BLADE DRIVE BELT ADJUSTMENT
Well, most riding mowers have a "pully idler", meaning once you have the belt on there (and it is the RIGHT size), the idler automatically gives the belt tension when you engage it (in fact, the idler pully is what IS engaged when you engage the belly mower).
Couple things to check (super simple):
The Belt. Look to see if she is wore smooth out.
Sometimes....they WILL stretch on you, instead of busting/coming apart, and give you noise (when she is engaged, but wore out enough to flop around a little)
The Deck Blade Bearings. Straight away, that is what it sounds like, or bent blades.
Check your Blade Bearings (super simple):
1. Pick up your deck to the highest high setting (mower off, just sitting).
2. Reach under, and grab your mower blade (do this for both sides), and TILT your blade UP (meaning, don't LIFT the blade straight up).
Seriously, jiggle it at a TILT. If you feel some slack in the bearing, the bearing IS shot. Straight up and down is most of the time OK, IF it is VERY little play on your blade bearings. As you do it, look at your belt pulley directly on top, if you see that pully bobbing....
However, if you grab one side of the blade only, then tilt the blade up, and she moves.....
Bearings need replaced, both the upper AND lower bearings PER blade.
They are not hard to replace, and not expensive either! (Though unfortunately, most are "sealed" junk nowadays!)
Bad Bearings show up (make themselves known) in only a few ways: Tons of Noise (grinding, squealing) & Vibration.
Go check them thar Bearings!
May 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
490 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
