Window unit haier a/c (sorry, not sure model type, but it has a remote) isn't blowing cold (cool, but not cold) air and it sounds like the motor is just running in a 'fan' capacity. what can i do to get cooler air out of this unit? CAN i add freon?
    Sergeant:
  • 269 Answers
Have your unit cleaned first, if it is cleaned and still the trouble persist. check if the compressor works. if not check the running capacitor for leak. if all are working fine have your unit system reprocess.
Posted on Aug 01, 2009
Haier window ac constant red light? No label next to red light. Turns on and off fine. Cleaned filter, no change. couple years old. Still cools down the room but not as cold as it used to. Help?
Sounds like the unit is just dirty. The AC pulls air through coils and contains dirt, pollen, grease and all type of pollutants. These contaminants will cling to the coils, reducing the AC ability to transfer heat.
Here's a great YouTube video explaining how to properly clean a window AC. How to Clean Window Air Conditioner
AC units should be cleaned every year (including the whole house units), to maintain their ability to cool efficiently.
Aug 13, 2016 | Haier Heating & Cooling
Haier esa410ke manual
my haier air conditioner won't blow cool air just took it out the window like last 5 months ago it was blowing cool air now i put it back in the window now don't blow cool air just hot air.
Jul 14, 2012 | Haier ESA410K 10,000 btu ECO-Friendly...
Window / through wall unit made by haier, i can't find a model number. but it's making an awful racket like a blade or something hitting something. also slightly blows out a light fine mist of...
Where the unit drains is clogged it sounds like so your fan blade is hitting the water and scooping some of that water indoor. look where the condensate drains and clean that and it should be fine
Aug 14, 2011 | Haier ESA3125 Wall/Window Air Conditioner
My air conditioning united seems to be blowing cold air, but its not cooling down my room? Plus the temperature reading never lowers. Thank you in advance.
Sounds like the rear coil may be stopped up with dirt, etc. If it is, the unit will not cool properly. You may just be able to unplug it and wash it out with a hose and sprayer from the back of the unit. If its real dirty, you will have to pull the unit out of the window, take the case off and clean it real good. If you wash it out from the back, be sure you can do it when you can leave the unit off for an hour to dry. Let me know if I can help you any more of if this doesn't work. Stay cool. mark
Jul 10, 2011 | Haier HWR05XC7 Wall/Window Air Conditioner
My room a/c unit wont blow cold air i have already replaced my filter and closed the door correctly so what can do i check now?
check the remote control to be on cool and 18 degrees and then check if the outdoor unit works.
Jul 03, 2011 | Haier Heating & Cooling
My haier a/c model esa3067 wont turn whit out the remote but i have lost the remote how can iturn i tryed pressing the power botten on the ac but didnt work
It have the same one, but pushing thr power button does work. Are you sure there isn't a blown circuit? Double check your outlet with another device...like a lamp. Sorry I can't help more.
May 26, 2011 | Haier ESA3067 Air Conditioner
HAIER CPN11XCJ new, doesn't blow cold
There are three settings. If you have it on FAN, it won't blow cold. The raindrop picture is for dehumidifying, and the snowflake picture is the setting for COLD. If you shut the unit off and on too quickly, it takes a minute or two to cycle back to cool.
* Make sure the 'snowflake' setting/picture is selected...
Ours works too good! We sleep with 2 blankets! Nice...
Jul 25, 2010 | Haier Heating & Cooling
The Exhaust fan is not working, the unit still cools air then cuts out.
the unit is blowing cold air then tripping out, is it blowing hot air out the back? im sure you mean exhaust air as in hot air so the reason your unit is tripping out is that its overheating and the pressures in the rerigeration system are to high, so the safety trip cuts the unit off.
replace the motor
all the best
Jul 05, 2010 | Haier CPRD12XC7 Air Conditioner
No longer blows cold air and the unit is only 15 months old
First please clean the air filter and ensure that there is no dust settled on the filter which could chock the circulation of air.
To throw cool air the unit got to **** the air from the room and in case the air filter is blocked with dust then there will be no cooling at all.
Please ensure the thermostat knob is turned to the desired cooling level and try running the unit.
Ensure there is no escape route for the cool breeze.
Minimize the frequency of the door or window opening in the area to retain cooling efficiency.
I am sure your unit will work on taking the above precautions before operating it.
Jul 08, 2009 | Haier CPRD12XH7 Air Conditioner
HAIER 1 YR. OLD A/C UNIT BLOWS ONLY WARM AIR
well it sounds like the compressor is not turning on. does it have thermostat? if so turn it way down. clean any filters. is it a window unite or portable most of them are too costly to repair unless you do it your self.
Jul 06, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
