Question about Kenmore 57029 Side by Side Refrigerator
Filtered water My water dispenser has always been very slow to react.  When the switch was hit the light would come on and after a while ~10 sec, you could tell that it was about to dispense when it started humming.  Here lately the the thing doesn't even dispense.  I can wait about a minute and it still won't dispense.  It is a 363.59522996.  I replaced the filter a couple of weeks ago to no avail. Thanks for any help.
  • 213 Answers
The water line that run through the freezer door is frozen. its been a common problem on the GE built refrigerators. (that who built yours for sears) dis connect the water hose hehind the kick plate below the freezer door. use a hair dryer to warm up the inside and outside of the door around the dispenser area to defrost the line. it will take anywhere from 15 to 30 min to get in completly defrosted but it will once it is defrosted
Posted on Nov 25, 2007
How do i get my whirlpool fridge out of demo mode
Exiting the Showroom/Demo Mode: Pressing and holding LIGHT and MAX ICE again for 3 sec OR unplugging and plugging in the power cord exits the showroom mode and returns to normal operation
Sep 23, 2016 | Whirlpool WRS325FDAB 25.4 cu. ft. Side by...
The pump runs for 1 or 2 sec and stops then a min or so later runs for a sec or 2 and stop again
If the water in the pan is slow to drain then possibly a restriction in the pan outlet or the membrane is slow to react to the water pressure, lastly if it is old and noisy the motor windings are damaged so in this case could be time for a new pump.
Feb 02, 2015 | Saniflo & Saniplus& Macerator Pump
Old filter in and water started to sputter, made clunky noises and flow very slow. Removed filter and used plug - water ran fine not filtered.- Replaced with new Maytag filter and water sputtered, flow...
Hello there, when new filters are fitted usually they are expected to spurt for a little bit before they normalize and begin to flow properly. Dispense water continuously for 10 minutes. This usually arises when the flow of water through the unit not being allowed through properly and usually takes the new filter a couple of minutes to get accustomed to the water flow and get water circulating through all its components hence the spurts. Alternatively you can check to ensure that the water supply is turned on full and the filter is properly fitted. If all of these are in place then the dispense mechanism might be faulty.
Hope this support has been helpful?
Thank you for visiting FixYa.
Sep 23, 2011 | Maytag MSD2756G Side by Side Refrigerator
Changed water filter, and now no filtered water comes out. Water had slowed, and it stopped making ice, so replaced the filter like always, and now no filtered water comes out at all Bought the same...
Don't know which filter you use, so this might not work. Try reversing the filter to see if it got installed incorrectly.
If not, make sure the the water line didn't get kinked and that the valve is open.
Jun 08, 2011 | Kenmore Refrigerators
GE side by side refrigerator water dispenser slow starts.
Well, the age doesnt help it, but have you ever changed the filter and had it all cleaned, if not all must be cleaned and filter changed, that should do it
Feb 09, 2010 | GE GSH25JFR Side by Side Refrigerator
I have a leaky spigot what can I do
If the spigot means the end of the water tube in the water dispenser, and it steadily drips even if the dispenser is not used for 10 minutes or so - replace the water valve. If the dispenser drips water mostly wright after you used it - you might have some air bubbles in the refrigerator water tubing.
Oct 17, 2009 | GALAXY Microsystems 25.4 cu. ft....
Slow filter water stream and hollow ice.
You have a mesh screen in the water supply line where it connects to the water inlet valve. It can be stopped up with sediment.
Sep 27, 2009 | Freezers
Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Jul 24, 2009 | Refrigerators
Has anyone successfully fixed his or her water dispenser?
I have had a few where the water switch housing that holds the switch breaks and does not allow the arm to hit the switch to turn water on. that is one thing it could be ethier way not to big of an expence to get fixed
Feb 23, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
Ice Maker Slow Making Ice and Water Dispenser No Longer Dispenses
Try replacing the filters, they might be slowing the water flow.
Jun 12, 2008 | Frigidaire FRS-26DR7D Side by Side...
Kenmore 57029 Side by Side Refrigerator Logo
106 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
