Question about Pool & Spa
Keys backyard spa manual - Pool & Spa
    Problem Solver:
  • 16 Answers
3 Suggested Answers
PartsCenter
  • 125 Answers
SOURCE: have 3 person keys backyard spa, misplaced book
http://www.uspartscenter.com/balboaerrorcodes.aspx
Posted on Nov 15, 2009
  • 2468 Answers
SOURCE: Hi there, I have had a Key's Backyard Spa for
Hi Donna:
I believe you can find both of your inquiries at (www.SpaCare.com),type in VS-500 in the search box and below the picture of the board you can download the troubleshooting manual free in PDF form,I will also call you in case you have questions,Thank You for usinf Fixya.........Daniel(608)214-5632
Posted on Feb 20, 2011
Keys backyard spa, model KPR466DVS. Where is wiring access panel located?
open up control box inside unit there is a schematic for voltages and component location
Nov 24, 2015 | Pool & Spa
Does anyone know the right filter for a Key Backyard Spa 331?
Key backyards went out of business.
Most common filter was a standard 50 sq. foot cartridge element.
Unicel C4950 is a common filter. Pleatco and Filbur are other brand manufacturers of replacement filter cartridges.
FIT Pool spa C4950 UNICEL 4950 PLEATCO PRB50 IN FC 2390
if you think this is the one, we got lucky. If not, please go to the comment section of this thread and provide the information of where your filter should go. Maybe even upload a picture of this area and we would be able to help you better.
Apr 09, 2015 | Pool & Spa
Why should I use a filtration system for my pool?
I have a pool in my backyard and could not imagine living without a filtration system. It filters out all debris and algae, leaving my pool clean and clear.
Jul 15, 2012 | Blue Wave NFC0131 4-5/8 x 9-3/4 tsc filter...
I dont know how to turn on my jacuzzi in the backyard.
You should have a button that looks something like this??? If this does not turn on the unit, posible breaker tripped, bad switch, disconnected tubing from button to switch???
Aug 23, 2011 | Pool & Spa
We have a keys backyard sauna and when you turn it on it only comes on for a split second than goes off. I cannot find any information on keys saunas online anywhere.
I had the same problem,I bought a used one and during assembly thought it didn't matter where I plugged the cables at the top power board, but it does or else once you try to turn on the heat the sauna shuts down.
INSTRUCTIONS: I fixed mine by connecting the cable that runs from the interior light to the last port, then comes a sealed port, then on the next port connect one of the two cables (the largest one) that comes from the temperature controller from the front wall, the rest cables don't matter which port you put them.
Good luck I hope it works, theres little information out there about fixing this problems. the manual doesnt say the order to connect the cables and to top it off the manufacturer went bankrupt.
May 21, 2010 | Garden
Keys backyard spa kbsb 4395 there are two pumps one does not work..i winterized it ..and now number 1 pump appears not able to be primed...just hums...then goes off and i get a ''dy'' signal......the...
Shut off the power...Each pump should have 2 valves associated with it. Close the valve on the outgoing side of the pump (not leading to the end of the pump). Use a strap wrench or large pair of Channel lock pliers to loosen the union nut counter clockwise on the outgoing side of the pump (not the end of the pump) listen for air escaping... water will leak out... tighten the union nut when the air sound stops and just water is leaking out. open the valve back up and restart the spa at the breaker. Press the up temp button to override the prime (PR) cycle and start the system. If this does not work, feel free to contact us at info@coastsideservices.com
Apr 11, 2010 | Pool & Spa
Pool & Spa Logo
2,681 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
