Question about Sharp (BQC-XGE1000U1) Projector Lamp for XG-E1000U, XV-S95
I was using my SHarp xg e1000u projector today and I turned it off, and when I turned it abck on a few hours later, no power. I checked the outlets, plug etc. I just doesn't turn on when I hit the power button. Advice?
  • 36 Answers
May be a loose electrical connection inside may need to send it to a shop to be fixed
Posted on Aug 01, 2009
I have a sharp xg-c55x. I put a brand new lamp. It worked once for about 20mins. Since then it starts warming up & then it turns off. How do i fix or reset? Thank you
Have reset the lamp hours after installing the new lamp? If, not the projector has treated the new lamp as old lamp & refusing to light further. So, reset the lamp hours to zero. To reset the lamp timer do as follows. Plug the power cord into the AC socket of the projector. Switch ON the power of the socket. (not projector) While pressing simultaneously INPUT, ENTER & UNDO on the projector, press ON on the projector. "LAMP 100%" is displayed, indicating that the lamp timer is reset.
If this does not correct your problem then the problem lies in other area. Let me know so that further I can provide you solution. Above things are preliminary.
Jul 07, 2011 | Sharp XG-C55X Multimedia Projector
Hı sharp xg xv2e lamp tımer reset?thanks
hi
Do the following for resetting the lamp hour
1.Attach the power cord to the projector and plug it into an electrical outlet.
2.Locate the buttons on the top of the projector and simultaneously hold down the "Enter", "Menu" and "down arrow" buttons, then press the "Standby/On" button. 3.Continue holding all four buttons depressed until the lamp indicator light begins flashing green.The counter is now reset. Zero hours will now be displayed on the screen.
ok
Feb 04, 2011 | Sharp Office Equipment & Supplies
SHARP NOTEVISION XG-C50X LCD PROJECTOR: Does this work for laptop presentations as well as DVD projections
Hi there, Sharp makes light and compact projectors with low fan noise. Set the projector up in areas subject to minimal humidity and dust to avoid having to clean the lens too often. Remember that colors will get washed out if the screen is in direct sunlight. Learn a few troubleshooting techniques to get the most out of this work horse projector.
No Pictures, Sound or the Projector Fails to Start
  • If you have no pictures, sound or the projector fails to start, check that the power cord is plugged into the wall and that all the cables are connected to the rear panel. Make sure the remote control batteries are fresh. If you are using a notebook computer, make sure the screen output is correct. Check the Input Mode on the projector. Check the projector physically--is the lamp and cover in place? Check the key lock.
  • Jul 31, 2010 | Sharp Notevision XG-C50X Multimedia...
    Light on my sharp xg-nv4su projector comes on for a few seconds then goes off. how do i reset the lamp timer?
    To reset the lamp timer you:
    1. Turn off the main power button on the back of the projector.
    2. Hold down the down, right, and enter buttons on the projector.
    3. Turn the main power button on the back back on.
    4. The projector should come on, hold down the buttons for at least 3 seconds after it comes on. If it doesn't come on, repeat the steps.
    5. Turn the projector back off using the sleep button on the top of the projector. Then turn it back on. If it comes on and is functional, you have successfuly reset the lamp timer.
    Jul 25, 2009 | Sharp BQC-XGNV4SU/1 Projector Lamp for...
    Sharp XG-P25X - only white screen, no OSD, no response
    It sounds like you tripped the tamper switch? Factory or authorized service center and reset via rs232 Sorry.
    Apr 02, 2009 | Sharp Conference Series XG-P25X Multimedia...
    SHARP XG-P25X PROJECTOR PROJECTOR RUNNING THEN IT IS AUTOLOG OFF AFTER 2MIN. WHEN PROJECTOR IS RUNNING ITS SHOW GREEN LED AFTER LOG OFF IT IS SHOW RED LED ON LAMP AND POWER LED
    either the lamp hours are close to or exceeding 1400 hrs and the lamp needs replacing, or the ballast is starting to fail. with the projector on, check the lamphours in the menu. after you replace the lamp (if it needs it), reset the lamp timer by holding down the down arrow, right arrow, and enter buttons, then press power.
    Jan 10, 2009 | Sharp Conference Series XG-P25X Multimedia...
    Projector turns on then shuts off after a few seconds
    Sent projector to V3 Systems & Services Pte Ltd 64522679
    1st independant Projector Service Centre (SINGAPORE)
    Chip & Component level service on board level electronics
    Dec 04, 2008 | Sharp (BQC-XGE1000U1) Projector Lamp for...
    Sharp XG-C50X
    Did you reset the lamp hours?
    Aug 21, 2008 | Sharp Notevision XG-C50X Multimedia...
    Sharp XG-P10XU lamp problem
    power supply or lamp ballasts, both are pretty common to produce results as you describe, looking at $600.00 or so to repair. if those are the only things wrong.
    Dec 07, 2007 | Sharp Notevision XG-P10XU Multimedia...
    XG-C50 Problem
    Hello
    Replace the fly-eye lens of projector.
    Viren
    Nov 09, 2006 | Sharp (BQCXGC50X1) Projector Lamp for...
    239 people viewed this question
    Top Sharp Office Equipment & Supplies Experts
    Anthony Karuku
    k24674
    jasbo
    jasbo
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
