Question about Intel Computers & Internet
What are the steps to enabling the start window on an intel inside nextbook
I can not get to the start menu to be able to get to the control panel. Along with this issue, getting to Administrative tools, Ease of Access or Hardware and Devices because of this issue
SOURCE:
  • 3 Answers
SOURCE: System Restore / User Account Issues
hi there dell dimension 3000 systems are instalt whit symantec ghost if you wana restour to factory settings go to this link it's the best i have found http://www.goodells.net/dellrestore/fixes.htm
Posted on Dec 23, 2007
  • 6 Answers
SOURCE: DHCP Tool not have my Administrative Tools
hi,
just check whether the services are authomatic running or not
ramana
Posted on Jul 03, 2008
rickyostrom
  • 274 Answers
SOURCE: ScanJet 5300c didn't work
Most likely the destination folder for the scanning is a shared folder with limited rights. As the administrator, reset the permissions for that folder or redirect the software to a common folder with read/write/creation etc... access.
Also, make sure you are using the HP provided drivers and not those from Microsoft.
Posted on Nov 24, 2008
wayneard
  • 1901 Answers
SOURCE: I have a new asus p6t motherboard. No audio.
Install your audio driver for your motherboard.
Go to Asus Downloads
In the "Input Model to Search" box in the upper left, type your motherboard model. (P6T)
Click the Search Info button.
You will get a page that has 6 versions of the P6T motherboard. Select the correct one.
A window will open asking for your operating system. Select it from the drop-down menu. Click Search.
The list of available drivers will open. Click the x next to Audio.
There are 3 choices. 2 are for Reatek and 1 is SoundMAX. I would try the top Realtek driver first.
Click on the "Global" link to download it. When the Download window opens, Save it to your computer where you know how to access it after the download. For ease, you can select Desktop and save it there.
After the download, close all programs and run (double-click) the file you downloaded. Reboot after the install.
Should this driver not work, comment back and we'll try the SoundMAX.
Posted on Mar 03, 2009
ajuhere81
  • 256 Answers
SOURCE: Acer Aspire 5720 'quick launch' buttons
it may be due the windows problem , virus in system or not proper driver installed . pls check for all this
Posted on Aug 12, 2009
How do I enable java in win10
Acces the Java Control Panel:
you can find the Java Control Panel through the Windows Start menu.
  1. Launch the Windows Start menu
  2. Click on Programs (All Apps on Windows 10)
  3. Find the Java program folder
  4. Click Configure Java to launch the Java Control Panel
If you don't see the Java folder then assume Java is not installed o your computer, then go to https://www.java.com/fr/download/manual.jsp
  • In the Java Control Panel, click the Security tab.
  • Select the option Enable Java content in the browser.
  • Click Apply and then OK to confirm the changes.
  • Restart the browser to enable the changes.
Hope this help...
Oct 07, 2016 | Computers & Internet
How do i find control panel or start button
Right click on the start bar, select properties, then click the start menu tab, then click the customize button and enable the control panel.
Oct 08, 2014 | Acer C720 Chromebook Gray 11.6" Notebook...
How do I check my Dell 7000Touch Screen Troubleshoot
Run the troubleshooter. Follow these steps:
a. Press the 'Windows + W' key on the keyboard.
b. Type troubleshooter in the search box and then press enter.
c. Click hardware and sound and run the Hardware and Devices Troubleshooter.
d. Follow the On screen instructions.
In addition, Follow the mentioned steps to enable Touch tab if it is disabled:
a. Navigate to Start screen. In the Start screen, click on
b. Control Panel tile.
c. In control panel Window, Scroll down and tap on the "More Settings" option.
d. Old Control Panel window will open.
e. Next, go to Hardware and Sound and after that click on Pen and
f. Touch option. Pen and Touch window will open.
g. Now, in the Pen and Touch window, navigate to Touch tab option. Check whether Use your finger as an input device box is unchecked, if so uncheck it. Then press
h. Apply and then OK.
Jun 12, 2014 | Dell Inspiron One 19 All-in-One Desktop PC...
The touch mouse will scroll and move but won't click.
you might have to reset it
Most modern laptops with touchpads offer vertical scrolling, horizontal scrolling or both. These features are located along the right-hand and bottom edges of the touchpad, respectively, and are activated when you swipe your finger along the touchpad edge. Scrolling functionality is nearly always enabled by default, but some users find the feature an annoyance and elect to turn it off. In most cases you can simply turn the feature back on using the Windows Control Panel.
Click the Windows Start button, select "Settings," and then click "Control Panel." Double-click the icon labeled "Mouse." Select the Touchpad properties tab. The labeling of this tab varies, depending on your computer manufacturer, operating system version and the device drivers installed on your machine. Common labels include "Touch Pad," "Device Settings" and "Dell Touchpad." If you do not see this option, you may not be able to turn on scrolling for your laptop; skip the remaining steps and refer to the "Warnings" section below. Click the "Settings" button within the Touchpad Properties menu and look for the section labeled "Scrolling Settings" or similar. Enable scrolling within this section and define other scroll settings, such as scroll zone width and scrolling speed. Click "OK" to confirm your changes, and then close the Control Panel windows opened in the previous steps. The scrollbar on your laptop is now enabled.
Scroll Is Not Working With Windows 7 b> Certain computer touchpads have a vertical section on the pad itself that is used to scroll through the page or program window that you are currently viewing on your computer. If the scroll functionality suddenly stops working but the actual touchpad is still fine, this means that the part of the software for the device that controls the ability to use the scroll has been disabled. You can enable it again in the Control Panel.
Click "Start." Click "Control Panel." Click "Mouse." Select the "Enable Scroll" option (or whatever similarly named option is available on your specific model of laptop computer). Click "Apply." The scroll bar on your touchpad will now work again.
b>
Feb 15, 2013 | HEWLETT-PACKARD Hewlett Packard HP 6730b...
I accidently disabled my audio devices from my laptop.. i have a Windows Vista basic withh intel pentium. How do i fix this problem?
From the Start menu, either go to control panel=device manager or type device manager in the run box.
In device manager, you can right click and enable your sound device.
Jul 21, 2011 | Intel Computers & Internet
How to enable touch pad
hello,
here are the steps to enable touchpad
Please, Press the "On/Off" button to turn on the touchpad. If your HP laptop does not include an "On/Off" button, press and hold the top right corner of the touchpad for five seconds and then release. A small light turns off and the touchpad icon appears briefly.
Click the Windows "Start" menu and click the "Control Panel."
Select the "Device Settings" tab and click "Enable" to enable the touchpad. Click "OK" to save the changes.
After performing the above steps touchpad will be enable.
if the issue persists, please do not hesitate to contact.
regards
Apr 24, 2011 | HP Computers & Internet
How to enable touchpad I disabled by mistake and
Step 1: Click on Start and then click on control panel.
Step 2: Hardware and Sound......Devices and Printers....Mouse.....Mouse Properties.....Device Settings.....Touchpad.......Enable........(Windows 7).
In Windows XP
Dec 18, 2010 | Dell Inspiron 1545 Notebook
The computer does not show the internet connection in the monitor. Before I reinstalled the windows it shows the message: no connectivity or limitated connectivity. The comcast modem was damaged so they...
Even though it does not show the connection on your monitor, the connection may still be working. Did you post this problem from the same computer? If yes, then you are fine.
Dec 29, 2009 | Dell Dimension E510 PC Desktop
Where is on switch for wifi button??
a lot of computers, like myne for instance, use a proram either natve to the computer like wndows, or something like intel PROSET wireless. i would recommend doing a computer search for these or other programs like these.
Nov 13, 2009 | Gateway 400SD4 Notebook
How to enable lan of intel board lan is not installed showing
If you are using a windows XP as an OS...make you have loaded all your drivers inclucing the LAN. Secondly from the START go the control panel--network and internet connections--network connections--you'll see the LAN icon/s.Right click on it and select Enable/Disable.
Jun 07, 2009 | Intel D845GVSR Motherboard
Computers & Internet Logo
Top Intel Computers & Internet Experts
Alun Cox
Joe Negus
Joe Negus
Thomas F. Schneider
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
