Question about Endless Summer 153100 Open Flame Patio Heater
Burner goes out
Pilot lights easily and main burners start too but go out after 1 to 3 minutes. Restarts easily and reignites main burners instantly just to repeat problem. Gas bottle just filled.
  • 154 Answers
Sounds like a bad gas valve
Posted on Aug 01, 2009
Bryant plus 90 intermittent start-up
That's an intermittent problem. Could be: dirty filter, dirty blower wheel, dirty secondary heat exchanger, dirty evap. coil, weak or damaged high temp safety, loose wire connection, fault at control board, poor air flow. Just about 100 guesses! Could be's don't solve anything. Check for cleanliness. Clean flame sensor(flame rod that burner flame comes in contact with). These are the first I would try.
Mar 10, 2017 | Heating & Cooling
Janitrol GUPS075-3 Furnace burners will not stay lit
The first thing I would do is make sure the flame sensor is clean, this is a metal rod immersed in the burner flame on the opposite side of the igniter. If too much oxidation builds up on it, it will not allow the burner to stay lit. To clean, just turn off furnace and remove flame sensor and clean with steel wool and then reinstall. If this does not solve the problem there may be a problem with the gas valve.
Nov 08, 2012 | Heating & Cooling
Raypak 403A, burners will not stay lit for more than a few minutes.
i'm thinking after the main valve opens the pressure could be dropping in the pilot tube. this could be due to a dirty, plugged and sometimes spider web inside the pilot tube. rare but does happen, nice warm home for a spider. good luck. if not let me know. could also be weak pilot coil.
Jun 09, 2017 | Pool & Spa
Pilot will stay lit but burner goes out about 1 minute after it lights
Sound like the flame sensor you could scratch around on it and try again.Possibe venting issue
May 14, 2010 | Water Heaters
I have the DESA CBN20T Wall Heater. The pilot
take your gas lines off and blow compressed air though the lines blow out all the dust and stuff too
Nov 06, 2009 | Desa International CBN20T Heater
I have a Intertherm furnace model MMHA with United tech controller 1018 HSI. Flames starts up , fan runs but flame goes out and restarts after a few minutes. Keeps doing this, I don't see a proof of flame...
Maybe. There has to be some sort of flame sensor with this HSI module. Look on the wiring diagram for where it may be. If this model has a pilot that starts before the burners, it may be part of the ignition electrode or glow bar. If the burners just light, look at the far end of the burner box to make sure the flame is traveling down the entire length and hitting the sensor. If you find it, clean it off with a small tooth brush. Blow out the flame rail where the flame travels from burner to burner. Clean off the pilot assembly if it has one.
Oct 17, 2009 | Heating & Cooling
Keating fryer won't stay lit
You might want to see about getting your money back or swapping it for another. I'm guessing it is a natural gas model. If so check and make sure you have between 4 and 5 water columm gas pressure. If so I would start by checking the thermopile and make sure it's producing around 700 milivolts. If your not able to measure this or have the tools to do so, I would start by replacing the thermopile. (This is not a thermocouple.)If this does not fix the problem. You have a bad gas valve. Thermopile cost around $60.00. Gas valve runs around $30000You can go this web site for more info http://www.tmeinc.biz/xkeat.htm
Please rate solution
Sep 05, 2009 | Keating Instant Recovery 14CMG Deep Fryer
Pool Heater Light main burner then goes out
take millivolt reads while main burner is on.i suspect you will see a drop in voltage until you get to point where it will no longer operate burner(around 200mv).if this is the case you probably have poor pilot characteristics due to dirty pilot,pilot out of adjustment ,obstruction or insufficient gas pressure
Jun 21, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
How to reignite pilot lite
no pilot light on boiler only main burner
Jan 05, 2009 | KDS Valiant 6380iPTD-01 Notebook
When the gas boiler comes on the pilot light goes out after about 60 seconds then reignites itself a few minutes later.
This is caused by a weak flame sensing device. As main burner ignitin occurs this creates a roll out condition , when this condition occurs it derives oxygen from the pilot light thus reducing flame signal and causing the pilot to drop off momentarily.
Nov 09, 2008 | Heating & Cooling
Endless Summer 153100 Open Flame Patio Heater Logo
208 people viewed this question
Top Endless Summer Heating & Cooling Experts
paulcarew
Tim Whalen
Are you an Endless Summer Heating and Cooling Expert? Answer questions, earn points and help others
