Question about IBM (31P4103) Motherboard
THAN SYSTEM REMAINS BETTER IN THE CARD MOTHER FROM IBM 6188 (31P4103)
IBM thinkpad r30 keeps telling me that theat system batery is dead and transfer me to bios utility
There is the back up bios battery which is on the mother board and it could be low on the voltage- 3 V-
You can find it from the outside near the memory card or in the slot by removing the bottom hatch screws.
Remove and replace.
Oct 01, 2010 | IBM ThinkPad R30 2656 Notebook
Volume port in ibm mother board 1.00ghz
There is no volume port. Volume is controlled by your operating system. An operating system is software, not hardware.
Jul 14, 2009 | IBM (25P3294) Motherboard
IBM Lenovo doesnt start. Fans are ok Ram and Graphics card attached with the system is ok( I checkd with another system). The led on front , the keyboard leds and cd driv leds turns on as soon as I press...
Sounds like your graphics card and display are not properly communicating. If the card doesn't sent out a signal to the display, you will see nothing on the screen. Did you check the graphics card on another machine using the same display? If so, something different may be wrong. I am assuming your display is powered on and plugged in properly. If there is more than one video connector on the machine, you may have it plugged into the inactive video connector. If all of this checks out I suspect you have some hardware problem with the system unit.
Jul 03, 2009 | IBM Lenovo ThinkCentre M55e PC Desktop
Sound card driver is not installed in my computrt
http://www-307.ibm.com/pc/support/site.wss/MIGR-4MVU6G.html#audio
then go down to the audio and download the driver for your operating system then upgrade the sound card driver from file.
Jun 12, 2009 | Altinex DRIVER/GLI CARD, 2-IN 2-OUT,...
Ibm thinkpad r40 windows xp-pro after formatting and re-installing the system, all updates and SPs downloaded and installed, the wireless "disappeared"! the radio led wouldn't lit, in the connection list...
if drivers installed device is looking for wifi manager which is the software package for wifi.
you can goto control panel open administrative tools select sevices and scroll to wireless zero config and press start.
this will then use windows settings.done
Jan 24, 2009 | IBM ThinkPad R40 Notebook
Bought refurbished dell optiplex 260 w/o operating system
The problem might be with the video card of the system as it might have gone bad. & as far as my knowledge about DELL Optiplex series is concerned they come with a integrated video card. So the problem might be with the mother board...
Jan 13, 2009 | Dell OptiPlex GX620 PC Desktop
ASUS A8S-X beeps sometimes on startup!
Hi 1 Long, then 3 Short Beeps: Video error The BIOS is unable to access the video system in order to write any error messages to the screen. Diagnosis: This is usually caused by a problem with the video card, or the memory on the video card. Remove your video card inspect it for damage and then re insert it. Try rebooting and see if the error remains. If so replace the battery on the mother board and try a different video card. If you have a video card built in then remove 1 srick of the RAM and re boot. Do the same with the other stick. If the error still remains then there is a fault in the Mother Board I hope this helps!
May 11, 2007 | ASUS A8S-X Motherboard
Computers & Internet Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
