Question about Toshiba MD13Q41 13 in. TV/DVD Combo
My Toshiba md13q41 does not power on. Fuse is good
    Sergeant:
  • 269 Answers
Check the regulator and the horizontal output transistor.
Posted on Aug 01, 2009
My Toshiba tv has no power. I took apart and the main power fuse tested no good, is there anything else i should test, and where can i get a replacement fuse
You should look at the capacitors. If the top has bulge out, or there is stuff comping out of them replace them. Look around for any signs of burnt or damaged parts.
Mar 27, 2017 | Toshiba Televison & Video
Toshiba laptop does not turn on
Check the power switch button, fuse,defective components in primary power supply circuit.
Sep 03, 2014 | Toshiba Satellite 1130-S155 Notebook
TOSHIBA 40G300U3 will not power on, chaged fuse when I plugged it in it blew
Good day!!!!
if the fuse blew continuously when you plug it...
that problem is cause of shorted parts on the power supply board...the regulator (transistor)..
or you can buy a new power supply board...
Jul 30, 2011 | Toshiba 40G300U TV
No power or red led fuse good .toshiba 27df46
Hello Hloggins, hi, your power supply is not producing the pulse needed to start the switching. check for the IC on the oscillator part of the power supply, you need an Oscilloscope to test this. if there is no scope. i suggest you replace the IC.
May 20, 2010 | Toshiba 27DF46 27" TV
No Power. Checked cord with voltmeter. It is good. Might be fuse.
It might be the fuse. Try replacing it with the equivalent fuse. Also check the circuit board for faults. Good luck to you!
Nov 30, 2009 | Toshiba W607 VHS VCR
How to change a fuse on toshiba 5793 when a power surge occurs
hello yes there are fuses. the main one is located in the power supply it glass type it might be black where it has shorted if you replace it and it blows again then you have a dead short in the power supply good luck. ps on the main there are wickman fuses these are solder in to the board
shaun
May 26, 2009 | Toshiba 57H93 57" Rear Projection HDTV
NO POWER AT ALL on Toshiba Satellite A105-S2101. PLEASE HELP!
Try disconnecting the power outlet and removing the battery for about 10 seconds.
Hope this helps
Alex
www.CAS411.com
Jan 01, 2009 | Toshiba (K000002020) Motherboard
Toshiba rd-xv47,got no power.does it have a internal fuse?gegards d.fuhrmann
No. It has a nasty switch-mode power supply. These fail often - usually for no good reason. They're just poor quality.
Apr 13, 2008 | Toshiba Televison & Video
Toshiba SD-V393
It's blowed up REAL good.
Do you have a volt meter? If so, measure the power outputs of the power curcuit.
This won't really help, since if you measure the power and it's good, something on the rest of the board is bad. If the power is not good, you have to repair the power supply. If you don't know anything about electronics troubleshooting and soldering, there's no point to trying.
There is no simple owner doable solution to a problem like this.
Dec 26, 2007 | Toshiba SD-V392 DVD Player/VCR
Toshiba MD13Q41 13 in. TV/DVD Combo Logo
90 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
