NEC NW 892 Errror E9
Washing machine comes up with E9 after a few seconds of switch on then does nothing!
    Brigadier General:
  • 4,090 Answers
This error is related to the pressure sensor
check connections or replce pressure sensor
Check at the water source end of the hose and make sure the filter is not occluded. Both hot and cold. more likely the cold side as the hot water may disolve the particles more easily.
If all else seems good you will have to replace the sensor
Posted on Aug 01, 2009
My NEC Millennium 892 is displaying E9 and sounding alarm when I start operation. Can you tell me what this means pls. Adam Pinner
You can read up on it, its a pressure sensor,, check the connection around pressure sensor or replace it, if you can't call a repair man.
Jul 09, 2015 | Washing Machines
My NEC NW 652 washing machine is showing an E9 fault. When I hit the power button the E9 message appears?
Sounds like the water level pressure sensor is not working. The code (E9) means the switch is open.
You'll need to replace the pressure switch. Check the manual for the repair procedures.
Apr 25, 2014 | Washing Machines
Washing machine not spinning, stops & the letters LE flash, washing machine is a NEC NW-892 Millenium
It sounds like your lid switch is not working correctly, look to see if there is supposed to be a finger that protrudes from the bottom of the lid and enters a hole in the top of the washer, this is a safety switch to ensure the lid is closed, it is possible the actuator finger is broken or missing, If this is the case, I have heard of people manually actuating the switch to finish the load, I am not suggesting that because there is a safety issue, but it has been done. Your washer might not have an exposed actuator,it could be hidden under the washer top, but the LE error code indicates the lid is open.
Nov 10, 2012 | Washing Machines
Hi I have an NEC NW 892 and when I plug it in there is no indication of any power getting to the machine Any help would be appreciated. Thankyou Dr Bob
Sorry but with such a 'basic' fault it is virtually impossible for anybody on this forum to remotely guess what is wrong with your washer.
It could be internal wiring/plugs sockets, control panel switches and/or control PCB.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
Sorry again and good luck,
John C
Mar 29, 2011 | Washing Machines
My NEC NW 652 washing machine is showing an E9 fault. When i hit the power button the E9 message appears
E9 means the waterlevel sensor is defective or the pipe connected to it is faulty.
Jan 13, 2009 | Washing Machines
The NW - 891 NEC washing machine does not finish the third cycle or drain?
Our nec washing machine nw 891 leaks water into drum when finished , I think it needs new washers, is this hard to do?
Aug 06, 2008 | Washing Machines
Washing Machines Logo
559 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
