Call Aroma on their toll free number
1-800-276-6286
Free manual:
http://www.aroma-housewares.com/static/manuals/ARC-150SB_InstructionManual.pdf
SOURCE: Need new nonstick pot for my rice cooker TAYAMA TRC-07
Please call 1-866-9TAYAMA and they have all the parts you need
SOURCE: nonstick pan for Rice O Mat Cooker Model No. SR-W06NA
http://www.partstore.com/?s=cjtext1
try this site :)
SOURCE: I accidentally put the rice into the outer pot
The problem has been solved - the bottom cover of the rice cooker was unscrewed and pried off, and after removing the insulation, etc. the rice was removed.
SOURCE: I have an aroma rice cooker model #arc-150sb c1
Thermal Fuse Problem.
If there is no heat/power, check the continuity o the thermal fuse( white resistor type in the internal wiring connections ). Unscrew and open the cooker at the bottom side.
Replace it w/ similar temp. value.
DON'T SOLDER IT!
Hope that helps you out!
