Question about Pegasus Technologies Home
Double black sinks w white areas developing in corners closer to bottom.
  • 117 Answers
Sounds like hard water, try alittle vinegar or lime away let it sit on there for a bit it should take it off for you
Posted on Aug 01, 2009
My Fisher & Paykel double dishwasher won't drain completely
It may be a blocked hose. First point to check is under the sink where the thin corrugated drain hose joins the sink drain. If it is a double dish drawer there will be two hoses, one black and one white. The black hose is usually from the top drawer. They are held on by spring clamps.
If this is not the problem, post again.
Feb 07, 2014 | Fisher and Paykel Dishwashers
I bought a new kitchen sink and pipes with a garbage disposal. Over night the smell in the garbage disposal is like rotten eggs! How can I make it smell good?
Use hydrogen peroxide and/ white vinegar to safely deodorize disposal.
Clean out drain line under sink, and bottom of disposal under cutter blade.
Copy following link for clogged disposal, and drain line tips.
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Oct 18, 2012 | Swanstone KSLS-3322 Double Bowl Kitchen...
Hello, my dishwasher doesn't drain
hi,
check for a stuck float inside corner, there may be a cover over newer models, its a round white thing in the front corner, it should move up and down and click once you get the cover off. if thats not it next to the sink is the aerator, pull the chrome cover straight up and off and unscrew the inner white part and look down in there. if that still doesent do it, have to go under the sink and undo the black or clear drain hose coming from the dishwasher into a bucket and study where its clogged under the sink. if its not that then it may be inside the trap inside the drain in the dishwasher, take the bottom rack out, undo the wash arm, unscrew the drain cover, undo the next drain cover, (theres usually 2) and then down in there may be the obstruction. shut the power off if you go digging into the pump of the dishwasher.
good luck
jm
Jan 03, 2011 | Dishwashers
White strips in black area only after muti clean
please check for foreign particles in your developing unit and charge and transfer units
Dec 02, 2009 | Xerox Office Equipment & Supplies
How do you clamp down sink?
there should be clamps with threaded bolts in the box or already attached to sink one for each corner they over lap to catch counter just line them up and tighten if you dont have you can get replacements at hardware store
Aug 02, 2009 | Franke Kindred DP2233/90/1 Granite Double...
Switch connections
I have a Jenn-air, and the switch for blower and light is on top, front. the switch has 4 connections on the bottom, and viewed from the bottom, the white wire goes at 12 o'clock, the red and brown wires are in the top left corner (paired with the white one) and the black wire is at 6 o'clock, and the blue (double wires) goes in the lower right corner (paired with the black one). If you have a continuity tester, the switch is a dpdt, and white is connected to red-brown (double wires) OR black is connected to blue-blue( double wire).
Hope this helps.
Aug 26, 2008 | Kitchen Ranges
Flashing shadow area on olympus e500
While in playback mode, image is blinking, the word shadow appears in lower right hand corner, use the info button repeatedly until all disappears and image is pure.
Mar 25, 2008 | Olympus EVOLT E-500 Digital Camera
Black stuff in the bottom of the dishwasher
That black or gray stuff you're talking about is actually a combination of old food particles and soap deposits. The stuff builds up in the corners of the lower front areas of the tub and right under the inside of the door where it closes over the tub front. These areas can develop "scungy" deposits because these are areas that the dishwasher doesn't always clean and/or water remains pooled. A little routine cleaning about once a week around the bottom lip of the door and the door gasket with a damp sponge will prevent this build up. Hope this helps you.
May 11, 2007 | Whirlpool 24 in. DU920PW Built-In...
Home Logo
65 people viewed this question
Top Pegasus Technologies Home Experts
john h
Jim Goldsmith
Jim Goldsmith
Paul Carew
Are you a Pegasus Technologies Home Expert? Answer questions, earn points and help others
