Question about LaCie 120GB Little Disk USB2/FW400 120 GB Hard Drive
I have a 120GB external hard drive. it's saying that i have 111.78GB used and only 3.4GB remaining available. this is IMPOSSIBLE. for many reasons, but mostly because no matter what i do - including removing everything on the drive - the numbers don't change. help.
  • clsbear Aug 01, 2009
    thank you. i should have mentioned that this is hooked to my mac. so i'm still not sure how to format it..
    Brigadier General:
  • 4,090 Answers
If you just removed everything and Windows is still showing this value empty your recycle bin its still linked.
Reboot and check again
Posted on Aug 01, 2009
  • 952 Answers
Thanks for using FixYa!
What you need to do is to format your hard drive. Go to "My computer" right click the hard drive.. then select format. Do not use the quick format procedure. This should solve your problem.
Have a nice day.
- HotRatchet
  • Jac Lawrence Pimentel
    Jac Lawrence Pimentel Aug 01, 2009
    1.Open the system drive, usually titled "Macintosh HD." Open
    Applications, then Utilities and double click the "Disk Utility"
    program to open it. A window will open giving a list of all the drives
    currently mounted on the computer.
    2. Select the disk that needs to be formatted on the left. It is not
    possible to format the startup disk unless the system has booted from
    the Install Disk. It is important to note that formatting the startup
    disk will permanently erase the data stored on the disk. If you are
    planning on erasing the startup disk, back up all important files and
    applications.
    3. Click on the "Erase" tab to the right of the list of drives. The window
    will now display the options for erasing the hard drive and formatting
    it to work on the Macintosh computer.
    4. Select the Volume Format from the pop-up list. In most cases it's best
    to leave it at "Mac OS Extended (Journaled)" as this is the default.
    This setting is the best option for running MAC OSX. If there are other requirements for the disk, then select the format
    that best suits your needs. If you have questions about the formats,
    refer to the Apple user's manual.
    5. Name the hard drive. Type a name for the disk in the field where it
    asks for the name. This name will always appear when the disk is
    mounted on a Macintosh computer.
    6. Click the erase button. A window will open asking to verify the erase
    procedure. Click the erase button in this window to start the process
    of erasing the disk. Once the process is complete, the drive will
    appear with the name it was given on the left side of the window with
    the list of drives and on the desktop of the Macintosh computer.
I have a simpletech 120 GB external USB hard drive with NO power supply. Do you know what the power rating is (ac or dc, how many volts, amperage...) or where I can get a new power supply for it? -Thanks
12VDC, 1.5A external power adapter Well that is what this page says, it's not your 120GB drive but unsure if it's no the same model maybe. However all external HDD that need a power supply should be needing 12 volts, as they are just internal drives mounted in a shell and some simple circuitry to power and connect it.
May 22, 2011 | SimpleTech 120GB SIMPLEDRIVE PORTABLE USB...
Do you have a Maxtor One Touch 120GB Users Manual available online?
Yes. Here you go - link.
To view this you'll need a pdf reader installed or use Google Chrome browser that has pdf reader built in.
If you need a pdf reader, you could try this one - http://www.foxitsoftware.com/pdf/reader/
Mar 15, 2011 | Maxtor OneTouch 4 Mini 120GB External USB...
I have a 320gb toshiba external hard drive, i've been using it around 3 years without any trouble. A few days ago i lost the cable connecting it to the PC. I bought a few cables but no use. Doesn't...
This is because there is a connection problem between the external drive and the computer. If you have changed cables to no avail, you can open the casing of the external drive where you will find the hard disk inside. Unplug the two cables connected to the harddisk and replug it after a minute. Then try again. If it still does not work, then you need to buy just a usb enclosure and plug the harddisk there to be able to use it again.
Hope this helps. Thank you for using FixYa.
Jan 13, 2011 | Toshiba 120GB USB 2.0 Portable External...
My computer says it does not recognize the external hard drive after i have used it for several months. If i use it on another computer, will it recognize it or should i download something first?
Install the hdd in another PC, If run well,think your OS has corrupted.
Then you should re install the OS again.Or you can restore the system
http://www.microsoft.com/windowsxp/using/helpandsupport/getstarted/ballew_03may19.mspx
If the HDD is not run run in that another pc ,think external hard drive, has damaged and should change.
Hope it will help you.
Dec 29, 2010 | Maxtor OneTouch 4 Mini 120GB External USB...
I have a Maxtor One Touch 4 Mini 120GB External USB 2.0 Hard Drive, I've previously used it multiple times in the past, importing AND exporting data. For some reason though after using it on one computer...
try testing it in another computer. if you have the same problem. then there might be an issue with the drive.
to recover your data. unplug external drive from the computer and open the external hard drive case. remove the hard drive inside. with you computer off and disconnected from the wall open the case to your computer. look and see how the hard drive inside is connected in your computer and add the external the same way. you might need a cable to connect it. you can simply disconnect the cdrom and plug the hard drive instead. make sure the external hard drive is not touching any electronics inside the pc. now you can turn on the computer. give the computer a minute to detect the new drive and assign a drive letter. navigate to my computer and select the newly added hard drive. copy and paste all the data you want to save. after everything has been backed up format the external drive to clear any bugs that may be causing it to be recognised in its case.
when finished remove the hard drive, plug in the cdrom, close the case, plug back into the wall, and return external drive to its case.
Feb 28, 2017 | Maxtor OneTouch 4 Mini 120GB External USB...
Disk does not show in explorer window
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jan 11, 2010 | Maxtor OneTouch III Mini Edition 120GB...
HDD upgrade to extensa 6601 Wlmi.
The BIOS determine the maximum size hard drive that can be installed in the laptop. Put a smaller hard drive in the laptop say 120Gb hard drive, you will lose approx 10% in the formatting process.
Use the 180GB in another laptop or put it into an USB hard drive adapter case and use it as a portable external hard drive.
Jul 18, 2009 | Acer Computers & Internet
Misreading as local disk
can you give more details
such as, what drive letter does it assign it, what error do you get when you try to read it, does it say 120GB when you look at it on "My Computer" and so on.
Jan 15, 2008 | Western Digital Passport WDXML800UE...
LaCie 120GB Little Disk USB2/FW400 120 GB Hard Drive Logo
57 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
